Question about EliteGroup P4VMM2 Motherboard
P4VMM2 Motherboard problems with RAM Cards changing fron SDRAM to DDR
Hi, guys. I've decided to upgrade my memory and bought 1G 266Mhz PC2100 DDR card instead of an current SDRAM cards. The problems staring at boot - the comp is on but does not boot, the monitor gets in standby mode and nothing happens. i'm novice to all computer stuff, so it'll be great to see a simple advice as possibly can be anyway. Thanx! Daniel
    President:
  • 2,961 Answers
Depending on your version of motherboard, it may only take ddr when you change the motherboard jumpers, as i assume you have 2 SDRAM and 2 DDR slots, but you will need to refer to your manual
Posted on Apr 10, 2007
  • 3 Answers
I believe this particular mother board cannot use both DDR RAM and SDRAM together. you can only use one or the other and also you should specify that you are using DDR ram in the bios when you install your new ram and for safe measures you should disable SDRAM.
Posted on Jun 04, 2007
Can an old HP Workstation xw8000 Computer that is currently using 512 RAM (PC2100 registered 184 PIN ECC DDR SDRAM DIMMs) be upgrade using 4GB Kit (2 X 2GB) PC2100 Registered 266MHz 184 pin DDR SDRA
According to a couple of people I have conferred with, that RAM should work.
Take a stick of the old ram out and make sure the the cut out, in the new RAM, is in the exact place as the old sticks. It cannot be off by a micron, or it will not fit.
Understanding Identifying and Upgrading the RAM in your PC
Dont click on any of the ads in that article, just read it and you will be able to judge for yourself.
Mar 11, 2014 | Dell W4201C 42 in. Plasma HDTV
Memory settings for ddr
http://www.motherboards.org/mobot/motherboards_d/ECS/K7AMA/
Since the Processor Front Side Bus (FSB) support is 200 or 266MegaHertz (MHz), the ram memory will be DDR Sdram at either 100Megahertz or 266MHz.
That is PC1600 and PC2100, respectively.
2GB's maximum TOTAL amount for motherboard.
1GB per ram memory slot - Maximum
If you have a Socket A (Socket 462) AMD processor with a 200MHz FSB, I suggest DDR Sdram at 100MHz. (PC1600)
AMD processor with 266MHz Front Side Bus = either PC1600, or PC2100. I would go with PC2100.
Voltage in BIOS Setup is 2.5 Volts. That is is the JEDEC standard voltage, for DDR Sdram.
Ram timings will be dependent upon what the ram memory supports.
IF you have just ONE ram memory module ('Stick'), it goes in Slot 1.
(DIMM 1)
This is the ram memory slot the Processor reads first.
http://www.cpu-upgrade.com/mb-ECS/K7AMA%28V1.5%29.html
http://www.ocinside.de/go_e.html?http://www.ocinside.de/html/workshop/ecs_k7s6a_vcore.html
http://8000.hillbillyhardware.com:8000/Reviews/ecs_945gcd-m/ecs_945gcd-m.html
"When it comes to innovative motherboards ECS is not a company that first comes to mind. Not since the days of the K7AMA that offered DDR266 and PC133 memory options for AMD's K7 line of processors has ECS released a motherboard that has filled a gapping hole in the PC hardware market space. Lets just hope that the failure rate of the 945GCD-M is nothing like the failure prone K7AMA."
Hmmmmm,
Not doing it for you? Then post more details in a Comment.
Regards,
joecoolvette
Jan 03, 2013 | EliteGroup K7AMA Motherboard
System reguirements to inrease ram memory
Ram Memory typically operates at half of the frequency rate, ('Speed'), that the Processor's -> FSB does.
Your motherboard supports Processors that have either a 400MegaHertz Front Side Bus, (400MHz FSB), or 533MHz FSB, or 800MHz FSB.
(Northwood Core for 400MHz FSB. The rest is in the other solution I provided)
Processor has a 400MHz FSB?
You can use DDR Sdram ram memory that is 266MHz.
(PC2100)
Processor has a 533MHz FSB?
You can use DDR Sdram ram memory that is either 266MHz, Or 333MHz.
(PC2100 and PC2700 respectively)
Processor has an 800MHz FSB?
You can use DDR Sdram that is either 266MHz, or 333Mhz, or 400Mhz.
(PC2100, PC2700, and PC3200, respectively)
NOTE*
When using a processor that has an 800MHz FSB, and using PC2700, (DDR at 333MHz), the PC2700 ram memory will run at ->
320MHz.
JEDEC has set the voltage requirements for DDR Sdram at 2.5 Volts.
'Performance' ram memory that is DDR Sdram may use higher voltages.
Not recommended unless you know how to overclock.
Although the motherboard, and the ram memory module may have SPD, it doesn't always work,
http://en.wikipedia.org/wiki/Serial_presence_detect
A lot of times you are faced with going into BIOS Setup, and changing the ram memory voltage, IF BIOS Setup has this feature.
This is why I say overclocking experience helps tremendously.
You want Low Density, Unbuffered, Non-ECC, and a CL of 2.5 for PC2700, and a CL of 3.0, (3) for PC3200.
[Why would anyone want to run PC2100> Lol! ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 11, 2012 | Computers & Internet
What type of ram can I add to my Compaq EVO 510 CMT and what is the max amount?
DDR SDRAM type Ram i.e. DDR1 with 266mhz speed with DDR266/PC2100 compliance. You can simply ask for DDR SDRAM 266Mhz or you can find online with the similar compliance, DDR266/PC2100 Compliance.
I hope you still have the old one which was installed on the system, if so look at the white sticker, it should be labelled there...
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 15, 2010 | Compaq Evo D510 Minitower (Open Box)...
2G RAM's for Elitegroup (ECS) L7VMM2 Rev 1.0A Motherboard
You're board can handel; DDR SDRAM up to 200 or 266MHz DDR SDRAM memory module. Accommodates two "unbuffered", 2.5V 184-pin slots. Each slot supports up to 1 GB with a total maximum capacity of 2 GB. Return the Kingston memory you have installed if it is less than a year old. They should allow you to trade up to the MB's supported memory.
Two reach the MB's max memmory of 2GB. Buy two Kingston DIMMS of, "unbuffered", 2.5V 184-pin
DIMMs. Here is one site that sells Kingston memory;
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=235786&CatId=548
The next link is Kingstons site; http://www.ec.kingston.com/ecom/configurator_new/PartsInfo.asp?root=us&LinkBack=http://www.kingston.com&ktcpartno=KVR266X64C2/1G
Here is another site; http://www.buy.com/prod/kingston-1gb-ddr-memory-pc2100-266mhz-184-pin-dimm-kingston-1gb-ddr/q/loc/101/10348796.html
If you decide to search for you're self, use this as the basis for the correct model: Module - KVR266X64C2
Link to ECS web site; http://www.ecsusa.com/ECSWebSite/Product/Product_Detail.aspx?DetailID=62&CategoryID=1&MenuID=50&LanID=9
Mike
Jun 02, 2010 | EliteGroup L7VMM2 (L7VMM2 NO CARD READER)...
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Can i install 1GB ddr2 on P4VMM2 Motherboard? i want to upgrade my pc; board is: can i P4VMM2 Motherboard; cani i use 1GB ddr2 on this and a 512 MB if vid.card? -jayvee_yao@yahoo.com
Unfortunetly you cannot use ddr2 memory on this motherboard. The motherboard supports only PC2100/PC1600 DDR memory if you have version 8.1 of the motherboard. If you have v5.0 of the motherboard than you can only use sdram or ddr 266Mhz RAM. The same goes for the video card. The p4vmm2 motherboard is a rather old motherboard so I don't think it will payoff to upgrade the computer. It will be probably the best if you buy another computer.
best regards
Mar 23, 2009 | EliteGroup P4VMM2 Motherboard
Ddr not detected
if you want to use ddr ram with p4vmm2 mother bord you must replace the jumper near by the ddr2 slot
then your computer starts to work with ddr ram at 266Mhz also 400 Mhz too.
Feb 09, 2009 | EliteGroup P4VMM2 Motherboard
Upgrade of ram
Your board Support 168-pin SDRAM DIMM and 184-pin DDR DIMM (Can't Use DIMM & DDR SDRAM memory Together).
I would run the 184-pin DDR. Supports PC1600/PC2100 DDR DRAM up to 2BG Max. Since you have four memory slots 2x512mb of DDR PC2100 = 1GB would be plenty. You will notice programs load faster & games run smoother. Personally, 2Gb. may help but you will not see the difference. To see a difference it is not all about memory. Mb bus speed, CPU, chipset & speed of video memory all play a part with regards to Pc overall speed. You can download your manual here.: http://www.jetway.com.tw/oldweb/evisn/download/manual/index1.htm
You can download the specs of your board here.:
http://www.jetway.com.tw/oldweb/evisn/product/amd/v266b/v266b.htm
And below is a link for some good ram.:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=302039&CatId=548
This should all help you decide, best wishes!
Please vote.....
Jan 23, 2008 | Jetway V266B Motherboard
RAM upgrate
you can upgrade to a max of 2gb on that board. These are your 1gb options: 1GB PC2700 333MHz DDR Memory, 1GB PC2100 266MHz DDR Memory, and 1GB PC3200 400MHz Non-ECC Unbuffered 184-pin DDR DIMM Memory. Install a set of any of these and your off and running.
Dec 22, 2007 | FIC P4M-800T Motherboard
EliteGroup P4VMM2 Motherboard Logo
270 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
