Question about Zebra Z4Mplus Label Printer
Can i insert Two different coloureds Tag Rols in the Machine
I have to print Tag in different colours, instead of changing the Rols i was thinking if i can insert two different coloured tag rolls. & how do i then command to print one coloured tag at one time?
you can reply me @ deep9_4@hotmail.com
    President:
  • 2,976 Answers
If you put 2 rolls in, the labels will float around, since there is no way to keep each loose end in place.
Posted on Feb 05, 2009
Why won't my printer print purple?
Your Cannon printer is not the problem. You will get different print color depending on the paper you are using, For example you will get different print result if you print on color paper than on white paper and a different print if you print on photo paper. Another alternative is to lighten the tone of your purple. I don't know what your objective is and what project you're working on but I hope this might help.
Apr 26, 2014 | Canon MG5150 AllInOne Printer
We use our fax-1840C machine for black/white only, never for colour. we have installed both b/w and all 3 colour cartridges, but quite soon the fax says the (unused)colour cartridges are empty or dry and...
try by buying a new cartridges like the one you use before and clean first the print head to remove the smodges. see also you manual for compatibilites and instructions. ill find another solutions if this wont help you.
CHARCOIS
Oct 09, 2008 | Brother Office Equipment & Supplies
Printer HP Deskjet D1460 prints pink"..Instead of Black
The printed colours are an "additive" mix of the "primary" colours in your printer.
So, when the colour ink-jet cartridge is "out-of-ink" on one (or more) of its colours, the "mix" will be off, and the "wrong" colour will be the result.
Change the colour cartridge.
Before changing it, run a "deep-cleaning" cycle, using the HP Support software that was installed when you installed from the CD-ROM that came with the printer, to "clean" any/all "clogged" ink-jets -- i.e., a clog could be preventing one colour of ink from being sprayed onto the paper.
Apr 08, 2010 | HP DeskJet D1460 InkJet Printer
Canon S520 printer colours not correct
i think its time you replace/refill that ink cartridge. some of the colors must have run out.
Sep 06, 2009 | Canon Pixma iP6600D InkJet Photo Printer
The ''odometer'' shows greyscale as colour
Any machine I'm familiar with has a default colour setting that you can set to either colour or black & White. Check in your printer properties. If the machine is set for colour, even if you are printing all black text for example, it will "make" the black from the colours, thus registering it as a colour document.
Jun 22, 2009 | Canon Office Equipment & Supplies
Hp psc 1350 colour printing problems
Sir,
Check this link to solve the problem
link 1
Link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
Apr 28, 2009 | HP PSC 1350v All-In-One InkJet Printer
Prints light purple instead of grey
I think your Black Cartridge is Empty. Check it and replace it with the new one.
Your Printer is trying to produce Black Colour from your Colour Cartridge with a mix of Cyan, Magenta and Yellow.
Apr 23, 2009 | Canon PIXMA MX850 Multifunction Printer
Difference between ''Auot Color'' and ''Full Color Mode
Most Colour machines have three settings.
Auto Colour, Machine will determine if the original is Colour or Black and White from its scan. Then print in the format that best suits the original.
Full Colour, Machine will copy in full Colour regardless of Original type.
Black and White, Machine will copy or scan in B & W regardless of original type.
Hope this is of some help.
Ed
Apr 17, 2009 | Kyocera Office Equipment & Supplies
Black colour ?
Thats because it's using the other colours to mix what it thinks to be shades of grey. Due to the black ink being pigment based and the colours inks dye base, when printing onto glossy paper the machine will use the colour dye based inks to make up black.
If you were to print on plain paper, set to greyscale, then the machine will just use the black as the pigment ink sits onto of the plain paper and will not run should the paper get wet.  With glossy paper the ink has to be absorbed into the paper ad the Black pigment ink will not do this so the machine will use the coloured inks.
Sucks but true.
Aug 06, 2008 | Lexmark X3480 All-In-One Printer
Zebra Z4Mplus Label Printer Logo
81 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
