Question about Microsoft Windows XP Professional
Flexcube the problem is just that tghere are some system in my office that if we trying to make use of flexcube it take enough of time before it's display the customers account.and there have been enough compliant and it i diable the pop blocker after executing the job,it's automatically enables it back.please what can i do to it
3 Suggested Answers
APremkumar
  • 564 Answers
SOURCE: ELIMINATING UNWANTED SOFTWARE
http://www.revouninstaller.com/revosetup.exe
Here is what you need!!! Click on the Above Link and install the Revo Unistaller. Will unistall any applications.
Hope This Helps!!!  Please Rate my Response!!! Thanks!!!
PREM
Posted on Feb 23, 2009
jepoyPH
  • 93 Answers
SOURCE: Cannot initialize Microsoft Office shared
try re-installing your office.
Posted on Aug 16, 2009
Microsoft office drivers
Please post the error code if any. Also, I need the info of the:
1. MS Office version (2013/2010/2007 or older version) and the media (DVD, flash drive),
2. The installed operating system (Windows 8/7/Vista/XP)
3. The remaining hard drive space (the system will display warning if the hard drive space is not enough)
Feb 28, 2014 | Samsung Computers & Internet
Avaya phone 5410 how can I manually change time
The IPO should get its time from the VM Pro server. The time server should be
set to the IP address if the VM Pro pc. If there isnt a vmpro pc, you can set
it manually.
http://mfurrer.dyndns.org/?p=224
For IP Office systems without access to a time server, a number of methods to
manually set the system time exist. These are available in the IP Office 4.1+.
The following method is only supported on these phones: 2410, 2420, 4412, 4424,
4612, 4624, 4610, 4620, 4621, 5410, 5420, 5610, 5620, 5621, 6412, 6424. It is
supported on any analog, T3, T3 IP or wireless (IP DECT, 3600, 3700 Series)
phones.
Note: If the IP Office system that is still configured for automatic time
updates (on by default), any manually set time and date will be overridden on
the next automatic update. The use of automatic updates can be disabled by
setting the System ' System ' Time Server IP Address to 0.0.0.1.
Enabling a User Button for Time and Date
Select the user who can adjust the system time and date.
If necessary create a new user who can be used to log in and set the
time and date before logging out.
On the User ' Telephony tab, ensure that the option System Phone is
selected.
On the User ' Button Programming tab select and double-click on an available
button.
Select Emulation > Self-Administer as the action.
In the Action Data field enter 2.
Enter an appropriate label for the button.
Adding another button set to the Emulation > Time of Day action is
recommended as this will allow the user to view and confirm the systems current
time.
In the User tab, Change System Phone Rights to "Level2"
Send the updated configuration to the IP Office.
Using the Programmable Button
Press the programmed button. If the user has a Login Code enter it as
requested, and press Done
The options Date and Time are displayed.
To set the date press Date.
The current system date is displayed.
Enter the new date, using two digits for day and month. Use the * or #
keys to insert the / separators. The format for date enter matches the locale of
the IP Office system.
During entry the key labeled <<< can be used to backspace.
When the full date has been entered as required, press Next.
Press Done.
The phone will return to idle.
To set the time press Time.
The current system time is displayed.
Enter the new time using 24-hour clock format. Use the * or # keys to
insert the : separator.
When the full time has been entered as required, press Done.
Nov 05, 2012 | Avaya IP Office 5410 Terminal - New
The display says "CHK SPKR"
It's telling you it thinks tghere's a short on the speaker outputs. With NO speakers, that is bad.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 24, 2011 | RCA RT2500 System
My brand new DW317 jigsaw will not accept the blade that came with it. I can't get it to seat far enough down to get the catch to close. Thanks
If so what happens Go back in a hurry and change your tool in between 8 days to change for an other model if this happens after 8 days and tghere is a problem you can only be helped by garantee repair. no quick change for another new one.
Jun 25, 2010 | Dewalt compact Jig Saw kit DW317K
Hi, I am trying to install the free version of microsoft office 2oo7 but am unable to do it.
Your system must meet the following requirements before you can install office 2007.
1 Processor Speed 500MHz (Megahertz) or Higher
2 Free hard disk space must be 1.5Gb (Gigabyte) or more.
3 RAM size must be 256Mb (Megabyte) or higher
4 Display resolution must be 1024x768 or higher
5 Operating system must be Windows XP service Pack 2 or new Operating System.
If the system does not meet this basic system requirement you have upgrade the system and try installing Microsoft Office 2007 again.
Dec 28, 2009 | Microsoft Office Professional 2007 Full...
Ms office won't open gives there is not enough memory disk space full message but memory no where near full
Depending on how much disk space you have left onyour hard drive, Microsoft Home and Student requires at least 1.5GB offree space. I've posted the minimum system requirements below, you willneed these to run Office Home and Student 2007.
Minimum Requirements: (View on Microsoft Website)
  • 500mhz Processor
  • 256 Memory (RAM)
  • 1.5GB of Free Space (Hard Drive)
  • CD/DVD Drive
  • Display: 1024x768 or higher resolution monitor
  • Operating System: Microsoft Windows XP with Service Pack (SP) 2, Windows Server 2003 with SP1, or later operating system
Mar 15, 2009 | Microsoft Office Professional 2007 Full...
Arabic display
Try downloading a new Arabic character set for Office 2007 using Vista.  Should be able to get one on microsoft.com
Oct 27, 2008 | Microsoft Office Professional 2007 Full...
Display clock
These phones are part of a phone system. The time is set in the control unit and not in the phone. A system administrator (or whoever does the programming in your office) needs to set the time through one of the phones designated for system programming.
Sep 17, 2008 | NorStar M7208 Corded Phone
Microsoft Windows XP Professional Logo
47 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
