Question about Microsoft Xbox 360 Console
Ring of death on xbox360
I have 3 red rings on the xbox
  • 767 Answers
Ring of death , well 3/4 ring of death
If the unit is still under 3 year replacement ,
SEND IT BACK NOW before it does something
that MS will not cover. But if you broke the seal
then get an proper x clamp mod and that will
Fix it and it should run a little cooler and be
far more reliable.
Hope that helps a little
Posted on Jul 03, 2009
  • 50 Answers
First of all there is only one ring on the console,
technically there is no three red rings,
just three red lights, if it is still under warranty just send it to microsoft to have it repaired
  • 30 Answers
Turn it in to xbox. they will fix it.
Posted on Jun 29, 2009
Red rings causing fan to shut off
Red ring on the power button? If so your xbox is srewed. Its called the Red Ring Of Death Achievment. Its the best xbox achievment avalible.
Dec 16, 2011 | Microsoft Xbox 360 Console
Part of the outer ring is coloured red and the game wont work
Yikes! red ring is not good, if the whole ring is red you need to check your AV cables, three sections is the Red Ring of Death and you need to send your Xbox in for repairs(http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/flashinglights.aspx). Off the top of my head I can't remember what the two or one red sections mean, I do know their not as serious as the three. my girlfriends freezes from time to time and red rings, but when we restart her system it all goes away (sometimes it still jams at the Xbox load screen)
Jan 20, 2011 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Red ring in player 4 position???
the red ring on your xbox in called the red ring of death if you go on youtube they have lots of solution and i mean lots!! go there and i promise you that u ill have your xbox fixed
Sep 05, 2010 | Microsoft Xbox 360 Console
My xbox will not switch on it had red rings on then it just went off and i cant switch it back on
hi there
the red ring is the mother bound on your xbox that pack up that y you got a red ring on your xbox
Dec 22, 2009 | Microsoft Xbox 360 Console
2 red rings playing for 40 min
2 Red rings is caused by the Xbox 360 overheating. This should not be happening after 40 minutes of play.
You can check your warranty status here.
If you'd like to repair it yourself check out:
www.xbox-experts.com
Nov 20, 2009 | Microsoft Xbox 360 Console
3 red rings xbox 360
thats the Red Ring of Death send it in to xbox,call18004myxbox the red rings are a hard ware failure
Oct 15, 2009 | Microsoft Xbox 360 Console
Power button is blinking red
if 3 of 4 lights are blinking red, you have a red ring of death and need to contact microsoft. this is distubingly common on some of the older 360 models.
Jul 11, 2009 | Microsoft Xbox 360 Console
Four red rings on my xbox
my xbox 360 has four red rings
May 01, 2009 | Microsoft Xbox 360 Console
Xbox 360 Red Rings
call 18004myxbox and tell them it has the red rings. they will guide you through the rest
Jun 27, 2008 | Microsoft Xbox® 360 Core System Console
Microsoft Xbox 360 Console Logo
117 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
