Question about Iomega HDD External Desktop (32660) 80 GB Hard Drive
No Power to External Hard Drive
Have Iomega DHD250 external hard drive. Hardly used. Last used about 4 months ago. Now I can't get the drive's power light to go on. The AC adapter between the power source and the drive has a green light, but not the drive. An adapter problem? A drive problem? My power supply has the green light and seems to be working but the Hard Drive is not ???
  • Anonymous Apr 10, 2009
    iomega 500 G won't power up.  overheated a week ago, was fine the next day and through the weekend.  now no power.
2 Suggested Answers
antiochpc
  • 1314 Answers
SOURCE: No Power to External Hard Drive
Do you have access to a multimeter or voltmeter? If you do you can check the voltage coming out of the adapter and make sure it matches what the power adapter says it is. If it doesn't, then it is the power adapter. If it does, then it is the drive or enclosure.
Posted on Jun 21, 2007
My Iomega external hard drive was working this morning but now will not open. Thgere is power and seemingly activity but my desktop either does not see it or does not recognise it. it also sounds as though...
My Iomega external hard drive was working this morning but now will not open. Thgere is power and seemingly activity but my desktop either does not see it or does not recognise it. it also sounds as though the drive is beeping
Aug 09, 2010 | Iomega Silver Series 320GB 3.5 External -...
Iomega 320 external hard drive computer wont recognise
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 15, 2010 | Iomega Portable Hi-Speed USB 2.0 40GB,...
My iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
Nov 08, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Iomega large external hard drive doesn't show up on computer desktop. All cables, ports, power source, etc. tested (standard troubleshooting process and testing with other functioning external hard...
Well this is a tough one. I am assumeing that you have done all the normal things.
Most external hard drives are just a standard internal hard drive with a case and a IDE/SATA to USB adapter built in. When you plug in the drive and it powers up listen to the drive if you hear a clunk. Not a the happy ticking of a normal drive but a bad clunk. This can mean that the controller on the hard drive itself is bad.
If everything sounds happy then I would try replacing your power adapter. I know that the blue light goes on but most of that runs off the 5 volt leg of the power supply (I have has some hardware manufacturers actually pull the power light voltage from the USB port Grrr) most of the Large sized external hard drives use a 12 volt adapter and it can have no problem with the step down to 5 volt it may have a problem with the 12v.The 12v is what it uses to spin the drive. Unless you have one of those little drives. They use a laptop hard drive that works of a lower voltage. Most of the time you can get an adapter from Radio Shack. Be sure to bring the old one so they can get the Volts, amps, poleartity and the type of connector. It is worth a try and keep the reciept. If it is just bad I am sorry but the only way to get the data off is to break into the unit and pull the hard drive out. Then use another USB to IDE/SATA adapter to pull the data off.
Hope this helps a little.
Sep 13, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Iomega 500gb power supply failure
if it's 6 months old, you should be still having warranty, suggest you take it back to where you bought it from.
Jul 18, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
I bought a iomega external hard drive from future shop a few months ago. I was using windows XP. I recently bought a windows vista. It does not recognize this external hard drive. It is asking for...
do you have a drive for your external hard drive when you bought it? windows vista is very delicate operating system. some manifacture products can't not be recognized by windows vista.
Jun 04, 2008 | Computers & Internet
Defragmenting external drive
run the command prompt, by going to start run and entering "cmd" then enter "defrag" followed by the drive letter.  if this doesn't work, enter "defrag /?" with the space for more options
Jan 08, 2008 | Iomega (33090) 250 GB Hard Drive
Jun 21, 2007 | Iomega (33090) 250 GB Hard Drive
Iomega HDD External Desktop (32660) 80 GB Hard Drive Logo
364 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
