Question about Ovens
Fan working grill working just no heat in siemens oven
When we switched on the oven the circuit breaker went in the house - now all parts of appliance working except heat - Siemens HB12320GB/05fd7906500382
  • Anonymous Mar 26, 2014
    We would like to replace our Siemens double oven with a new one model HB 905 With one that will fit into our existing housing unit colour pref white /black Thank you
  • 700 Answers
Hello the first thing that we need to look at is the electrical box thats is outside and see if there are any more braekers tripped. the clue is that everything work except the heat. thats 208/230 volt and the rest of the oven is 115 volt. e sure to take the breakers and push them all the way to off then back to the on position. if thats is the problem now you are going to have to call a service man to check out what is shorting and causing the breaker to trip.
Posted on Dec 23, 2008
Hi, I have a belling electric oven and separate grill. The two hobs on the left don't work, the grill doesn't work and the front elements in the oven itself has stopped. Is it fixable? Thanks.
Go to the circuit breaker location on your house and locate the one for the oven. Try flipping it on and off a couple of times. If the breaker only supplies 120 volts the heating elements won't work but the light and clock will. If resetting the circuit breaker fixes the problem, it will happen again, so replace the breaker to do a permanent fix.
Dec 14, 2015 | Belling Ovens
Why is my double oven not working but fan is working?
Good Afternoon Friend,
I understand that your Electrolux double oven is not heating up, even though the fan is running. I suggest resetting your appliance, be either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please leave me your model number, so I am able to better assist. Hope this is helpful.
-Best Regards-
WP
Jun 22, 2014 | Electrolux Ovens
AEG double oven/grill stopped working
It appears the oven has shorted out. Try checking the breaker box and see if any switches have been flipped. If this is not the case a new oven is in order.
Jan 24, 2014 | Ovens
Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
regards
richard saupe
appliance repairman
Mar 14, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Oven not working - rest of appliance fine
It is most likely that the oven heating element has failed and will need to be replaced.
This not an overly expensive part to have replaced and should be much less than the cost of buying a new oven although you would need to compare actual costs in your area.
Jan 17, 2010 | Ovens
Oven problem- grill works but the fan assist wont heat up
possibility is that the wire that link the oven element and that of grill is loose or burnt
Sep 25, 2009 | Ovens
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
SMEG Oven won't heat up
This is late response but this fault is your fan element. You have two of them, if heating slower than usual, it is only one that has failed. When replacing one, it is recommended the other one be replaced. Tripping the circuit breaker is the symptom. These elements 2100 Watt each are anywhere between $70 to $110.
Service Tech.
Dec 10, 2007 | Ovens
Ovens Logo
219 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
