Question about Watches
Need help to repair Westclox office clock fallen off wall. Still intact but need to know how to secure back to the outside casing. Seem to have 4 metal clips but can't see how this works. Can anyone help - Thanks
  • 2,334 Answers
Usually these clocks are assembled using clip-on type of assembly. Sometimes metal staples, pins or clips are used. You have to unbend or extract these(depending on what type of clips are used). If clock parts are made oft brittle plastic, it may crack,so, you should be carefull.
If the clock hands came off, try to find out if you can get the glass off without dismantling whole clock.
Hands mostly are friction fitted (push-on).
To align hands correctly, pull them off hub and then push them on pointing exactly at 12 o'clock.
Posted on Dec 23, 2008
Are Westclocks made in the usa?
Westclox clocks--and, at one time, watches--were once made in the United States. However, especially since the purchase of the Westclox brand and assets by a holding company in 2007, and the general disorganization that followed that acquisition, it's likely that all production has been moved offshore.
From about 1919 through the early 1980s, Westclox products were also made in Canada at their factory in Peterborough. Westclox also had a large factory in Scotland that manufactured over 50 million clocks between 1948 and 1988.
Jul 15, 2011 | Watches
Casio ws 300 How do i change the digital clock, can only seem to change alarm. How do i use the lap timer and memory, eg switching between #1, #2 etc. thank you
Hi,you need to look at the user manual..
just in case ,if you need soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Jul 02, 2011 | Casio Watches
I have a Westclox, Calander Model 70026. I have set the clock several times to the correct time,(with the time zone at the proper setting) but, after a day or so, the hour reading, reverts back...
It's most likely because of Daylight Saving Time. Your clock receives a signal through the air once a day from the actual atomic clock, much like a cell phone receives the time from your cell phone service provider, and it automatically resets itself to the exact time each time it receives this signal. Remember that the middle of the year (the second Sunday in March until the first Sunday in November in the US) is Daylight Saving Time for much of the United States. The clock has an option that allows you to set whether you are observing Daylight Saving Time or not. If this is set to "off", the time will be one hour behind until Daylight Saving Time ends (November 7th). Make sure this is set properly, and your problem will be solved.
Sep 27, 2010 | Watches
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 | Watches
    Westclox model LTX271 instructions for setting day
    mcdevito75 here, The stem on your westclox has 2 positions, First pull the stem out to set the time of day, keep cycleing the watch until you come to 1 day before the day you want. NOW! push the stem back in. NOW! slip a finger nail just under the crown and gently, gently kift the crown to it"s first position, it may take a little practice so be patient, once in it's first position you can change the DATE easily, change the DATE to 1 DATE before the DA you want, push the syem back in and pull the stem back out and set the day/date and time of day. Your watch is set and will change on time a little past mid nite.
    Jul 22, 2010 | Bulova Watch
    I have a Westclox battery operated wall clock with chicken on face. The battery is new. The second hand tries to move but just "clicks" How can I fix this?
    Sounds like it is just worn out.
    Sometimes you can replace the generic clock works in these type of clocks. Go online and do a search for battery powered clock works, and see if you can match yours. They are removed quite easily after popping off the clock hands, and removing a nut under the hands that holds the clock works in the chicken.
    Here's a link to a site that sells the clock movements... http://www.clockworks.com/
    Jun 09, 2010 | Watches
    Quartz president wall clock, I need to set the chime
    I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
    *Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
    *Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
    If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
    John
    Apr 21, 2010 | Watches
    I have a forestville wall clock with the pull down weights. when it chimes it is behind in time. example nine oclock chimes seven oclock, it is a made in germany clock but what year i do not know. there...
    Stop the pendulum of the clock exactly at any even hour. Lets say at 6.00. While clock is steady and not working, pull off the minute and hour hands off the pinion, but do not brake them. You have to pull without any twisting action. This will leave pinions exactly in place they were when you stopped the clock. When it is done - push the hour hand back onto the pinion and make sure it is pointing at 4 (not 6, as it was when you stopped the clock). When hour hand is back in place and pointing at 4, push back minute hand as it was when you pulled it off - pointing at 12. Make sure hands will not catch when passing each other (you can bend them slightly if needed). Now swing pendulum to start the clock and adjust time (clockwise only). Never adjust time when clock is chiming. Rate me, plz.
    Feb 02, 2010 | Watches
    Where can i go to get my watch fixed? two of the numerals have come unstuck and need fixing back to the watch. i love in london. i wnt to harrods byt they wouldnt help. it was a present so i dont know...
    I presume that you mean the the numerals on the face of the watch have fallen off.
    This being the case, then try your nearest watch repair shop, as the only special bit is getting the watch apart, which should be within the ability of any watch repairer.
    After that it is only a matter of a very small amount of glue and great care, not really a case for sending it back to the suppliers.
    Feb 01, 2010 | Jacques Lemans Watches
    Repair of battery-operated wall clock
    We had the same problem with our wall clock, but it was due to corrosion from a dead battery. The battery acid leaked inside and disrupted the connection between the metal contacting the batteries and the circuit (the one with the copper coil). We took everything out cleaned the contact points with acetone (nail polish remover). After that we had to bend the contact heads up just a little bit so they would contact the circuit again (I guess we bent them down a little when we were cleaning it). It worked just fine after that. I know it sounds intimidating to take apart a clock and put it back together but you're going to throw it out anyway. Just give it a try. It was kinda fun. Think of it as a puzzle. If you can't fix it, I imagine you can get a new motor at any hobby store or Michaels.
    Jun 24, 2008 | Kenneth Cole 1213 Wrist Watch
    Watches Logo
    373 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Marvin
    Marvin
    Are you a Watch Expert? Answer questions, earn points and help others
