Question about Sony Handycam DCR-PC101E Mini DV Digital Camcorder
Spare part number needed
Hi, any one please help me the spare part no: of lense unit or iris unit.
    Sergeant:
    Champion:
  • 326 Answers
Hello, here it is: 884875601 Best regards, Arpi
Posted on Apr 10, 2007
  • thanigai muruga Feb 19, 2013
    Thank you very much Arpad
The camera is booting on ok but it does not show any response from half pressed autofocus. The lense does not move and neither does the photo, if it is blurry, it will remain so.
sir,
Canon PowerShot SD850 IS / IXUS 950 IS Digital Camera in this both models usually this problem appears, open the camera then take out the lens unit, below this unit you can see the iris control stepper motor and related small wheels this may be worn out or may be misplaced, correct it. if still problem,open the lens unit to check the possible break on the iris lens connecting cable.
Jan 28, 2016 | Canon PowerShot SD850 IS / IXUS 950 IS...
Rear optic came off unit. lenses cam loose. Need
have got one of these going for spares if your interested?
fenderlogo@gmail.com
Feb 21, 2010 | Tasco NV200 Monocular
White line on all photos
problem on lense iris . iris is not working .chaing iris
Jul 10, 2009 | Canon PowerShot A530 Digital Camera
IFlashing F--
are you using this on a nikon camera if so the iris ring may have moved you need to move the ring to the red number you will see a bump on the iris ring there is a swich you slide to see a orange dot this will lock the iris ring
Jul 07, 2009 | Sigma 70-300mm f/4-5.6 DG APO Macro Lens
My Sony Cybershot w120 camera and now the lense won't pop out
Hi, there is no need to buy a new camera. The lens is avaible as a spare part. If you get a help from an authorized service they will solve your problem
Apr 08, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Records no picture as if the lense cap is on but its no I am just curious what part would be broken
Couple of things can be bad in this symptom.
Either CCD Imager is defective and not producing image signal or IRIS control is no working.
CCD Imager would be replaced in case its bad.
IRIS control can be repaired by qualified camera tech.
Need further info, let me know.
Mar 26, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
How do i clean the iris blades?
This is for Sanyo VPC-HD1, VPC-HD1A black screen problem how to clean auto iris unit.First you have take apart camera : remove 4 screws from right side (in battery compartment) 2 screws from bottom, 2 screws from top (there are different short one is from rear) and last screw from front, now pull left cabinet from top and take appart.Be carefull !!! there is flash capacitor you need to discharge it before doing anything else.You can discharge with  1Kom 5watt resistor . After that remove 1 screw holding speaker, disconnect and remove speaker.Now pull power board PW-1 there is a screw holding lense ring remove that screw, disconnect 2 connectors from lense assy (from ccd just pull, from lense unlock and pull flat cable now you can remove lens assy. Next remove 3 small screws holding heat sink (rear of lens assy) after that remove spacer (black tape from top of lense and another small tape at rear top of lense. Now you can see 7 white screws and 1 black screw remove all of them.Black screw holding iris unit.Now carefully lift zoom motor focus motor 2 sensors nd filter assy and iris unit they came out all together.Next thing main thing you have to open iris unit it is easy to do with sharp blade on the edge of iris unit you will find 2 locks holding  metall casing of iris unit put blade between metal and plastic case and pry to remove metall case. Now you will find iris 2 blades there are different you need to remember wich is wich.Now carefully remove both blades (they might stick to each other because of grease) and place them into isoprophyl alcohol after that put them on to napkin fold napkin so blades are inside and dry them you also need to clean iris unit where blades are going from grease and also clean zoom motor and focus motor shafts to remove grease. Now put everything back together and i hope you can do that. Good luck.
Aug 17, 2008 | Sanyo VPC-HD1 HDV Digital Camcorder
Digital ELPH, Canon powershot
Hi
You could be missing a part or two, including the tiny little springs that hold the 'butterfly covers' in place.
If you google: darntoothysam and search your model number you will find the repair parts you need to fix your lens covers.
Good luck from Darntoothysam com
Thomas
May 27, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Quantary Tech-10 75-300mm use with Canon Rebel XTi
Hi all
On most lenses the way to test if your old lens works on a cannon digital to set the camera to AV then set the iris to the small setting ie F16/F22 then use the stopdown button.
Things that might happen
1 The lens will close down OK
2 The error 99 will show,will need are rechip if avaliable
3 Nothing happens, will need a rechip
Q.Why will it work inside but not outside.
A. Inside the camera needs light so the iris is full open, outside the lens needs to close down and if not compatible it is unable to close down. will need a rechip
Mar 12, 2008 | Quantaray Tech-10 70-300mm f/4.0-5.6 for...
Sony Handycam DCR-PC101E Mini DV Digital Camcorder Logo
56 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
