Manual tray feed problem on Xante Platemaker 3 laser printer
HiHave a problem with feeding plates from the manual feed tray on my Xante Platemaker 3.Where can I get a picture of the pickup mechanism, and spares if I need them : rubber tracks, clutch, interrupt sensor? Should be able to do it myself if I can get the bits.
  • Anonymous Jan 04, 2009
    Well, my printer not recognize the plate in the bypass tray, ever tell me "Feed the 'X' size" and I can't print nothing :(
  • maskidder Mar 06, 2009
    Our Platemaker 3's manual tray gave up the ghost years ago. We bypassed the problem by printing plates from the cassette. I use Quark, so in the Quark print menu, I select "tabloid" paper size, then shift the image to the right 1" to compensate for it thinking the paper size is smaller than the plates.
    We just leave the hickey-do that goes up against the paper set in the tabloid spot and the plates sort of lay up over that.
You may have to change your settings in the program you're printing from to say "tabloid" instead of the plate size. You basically set everything to make the printer think it's printing 11x17 paper instead of a plate. The only thing I leave the same as a plate is the setting in Quark that says, "Media Type". I leave it on Polyester Plate.
Posted on Aug 18, 2010
Xante 3G - indicates 'print' then constant 'front paper jam' (any size)
That is cause the paper feeder is not working properly. It could cause the roller that feed the paper wear out or a bad tray release selenoid
Jun 12, 2014 | Xante Accel-a-Writer 3N Laser Printer
Front paper jam xante 3g
Dear you printer paper pickup sensor stuck,please removed all papers in tray and manual feed after that restart the printer,also clear the paper path,hope you understand.
thanks
Feb 19, 2014 | Xante Accel-a-Writer Laser Printer
Xante platemaker II paper jam error
Sometimes the sensor which detects paper jams gets knocked out of position during moves. NEVER move a printer while it is on. Don't even slide it around on your desk a little bit. If this is the case, your printer needs a replacement sensor which likely requires a professional to install. It would probably be cheaper to buy a new one anyways.
You can try the following to correct the issue:
1.Get a can of compressed air. As per the directions on the can, dust anything you can get at within the printer without moving or touching the internal mechanisms. It is possible that dust or smoke has gotten onto the sensor and is causing false paper jams.
2.open the rear access panel of the machine. You will see black rollers. With a slightly damp cloth (no paper towels) gently wipe at the rollers. Dirty rollers will not grab the paper properly and this may be confusing the mechanism.
If you need any technical help on printer then you can reach at here
Jan 21, 2013 | Office Equipment & Supplies
Myriad 2 polyester plates constant toning problems, tried different fountain solutions added varnish to the inks need your expert advise
Darrellf674
Did yor even find a resolution to this problem? I am having a similar issue. I have ink transferring from the non image area of the plate to the blanket. I can't see the toning on the plate but I sure do see the ink on the blanket.
May 05, 2011 | Xante PLATEMAKER 4 Laser Printer
Were is manual feed tray on ilumina
the manual feed tray is the Multi purpose Tray,. its the fold down input tray on the top RHS of the machine
Oct 26, 2010 | Xante Ilumina Digital Color Press Printer
It won't print - says manual feed - load paper tray. Its a brand new printer (Brother HL-4040CDN) and the paper tray is full
The printer has an "alternate" feed, i.e., for envelopes and/or for special paper.
Open the door to access that "manual" tray, take some paper from the "normal" tray, and insert the paper into the "manual" tray.
Or, on the printer's controls, set the "standard" feed, rather than the "manual" feed, and press PRINT.
Nov 11, 2009 | Brother HL 1440 Laser Printer
Printer prints from manual feed but not from tray.
you need ot open up the papper tray and more the laser down then it should work
please rate my helf i need you to i am a exert
Apr 20, 2009 | Brother HL-2040 Laser Printer
Brother MFC-8440 shows "manual feed" and will not feed from tray
go to your cpu in the printer set up and tell the printer what you want it to do
Dec 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
Accel-a-writer 3g feed problem
The printer probably was known to be defective when offered on eBay.
Dec 15, 2017 | Xante Accel-a-Writer Laser Printer
534 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
