Question about Toshiba 43A10 43" Rear Projection Television
GREEN LINE ON PROJECTION TV
SIR I HAVE A PROJECTION TV 43 INC ,THERE IS A DISTERD ON IT AND MY SON CLEAN ITS SCREAN WITH DIRTY WET DESTER , NOW THERE IS A GREAN LINE ON IT . KINDALY TELL MY HOW TO CLEAN IT. THANK YOU WITH REGARDS NADEEM TARIQ
  • 927 Answers
I hope you have repaired this concern by now, but if you have not there are cleaners one can buy at local electronic retail/part stores made for cleaning your bs screens, or your can use a mild soap such as dawn with a damp, soft cloth. Make sure you wipe up&down, not side to side. i hpoe this was helpful.
Posted on Apr 02, 2008
Fix screen got wet
These screens do not like water or chemical cleaners. I would try rubbing a soft damp cloth on a small section then dry it quickly gently with a soft dry cloth. If you see an improvement, clean the rest of the screen that way slowly a section at a time. Thats how I cleaned my Samsung Projection TV screen, I spent 30 min or so doing it but it was not very dirty.
Good Luck :)
Nov 08, 2013 | Mitsubishi Televison & Video
Yes my Sony KP43T75GRAY 43 in. Rear Projection TV worked beautiful before I placed it in storage for about 7 months. Now it has a slight green haze on everything. What should I do? I was told to remove the...
The DLP tv alway have problems with it convergence board problems.Tries flash focus button or manual + - convergence R,G,B colors lines alignments up.Still have the same problems,the convergence board is dead or have problems,convergence board must be fix to solved the green haze problems.
Jan 17, 2011 | Sony KP43T75GRAY 43" Rear Projection...
Line pink and green
this would definitely won't be the lamp, the issue is either with you video board or the dmd board, go to the menu and if that line still shows up on the menu, the issue will be with your dmd board, on the contrary the issue would be with your digital video board
Jul 21, 2009 | Samsung HCN436W 43" Rear Projection...
Picture has shadows with different colors (red, yellow, green)
Sounds like the convergence needs adjustment. You can do this through the menu-follow the on screen instructions. The idea is to line up the red, green, & blue.
Jun 24, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Toshiba Rear Projection TV
In the videomenu theres an option called convergence. you can shift blue and red color arround the green on, hopefully solving you're problem.
Good Luck
Jul 20, 2008 | Toshiba 43A10 43" Rear Projection...
My phillips model 60pp920217f has a horrible picture...no green to the color
The green CRT coolant has congealed thats whats giving you the green halos. Change the coolant in the green and blue and your set will be fine. red is never affected so the red coolant should be fine.
May 07, 2008 | Philips 43PP9202 43" Rear Projection...
Line in pic
Good Day, varndog;
Line on left side of pix,? It sounds like you have a high voltage leak. Check all high voltage cables and make sure that they seated firmly, all of those big red cables.
Good Day and Luck, big IRISH.
Apr 24, 2008 | Hitachi 43FWX20B 43" Rear Projection...
Converging green?
jaymz, you can`t move the green, the green tube is always mounted in the middle and is not adjustable from the convergence menu. red & blue should be converged one at a time on top of the green, once you have accomplished this the crosshatch grid will be white and that means your done :)
Nov 30, 2007 | Philips 43PP9202 43" Rear Projection...
Toshiba 43A10 43" Rear Projection Television Logo
261 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
