Question about Canon imageRUNNER 8500 Copier
IR5000 bloque my copier canon IR5000 shows error code E000061-0001. plaese help me what to do clear the error code. i've tried the ussual clearing error but it doesnt work. please help :(
  • 168 Answers
This is a code for detection of no or faulty charge to the drum open front door remove toner hopper take out primary charge unit see if any wires are broke on grid , then see if the wires underneath the grid are still there... if all seems ok gently clean the grid with cloth and windex then clean wires underneath dont break grid wires . put it back in let me know
Posted on Dec 23, 2008
How to clear e000067 for canon irc2880i copier
What is the meanin of error e000067 for canon irc2880i - Fixya
www.fixya.com/.../t26059344-meanin_error_e000067_canon_irc2880i
Jun 6, 2010 - Question about Canon Printers & Copiers .... How to clear e000067 for canon irc2880i copier ... How to clear error 000062 canon ir 2880i.
How to clear error 000062 canon ir 2880i - Fixya
www.fixya.com/support/t26059317-clear_error_000062_canon_ir_2880i
Jan 11, 2010 - Question about Canon Printers & Copiers. Open Question .... How to clear e000067 for canon irc2880i copier. Jan 18, 2016 ' Canon Printers & ...
Error code E000067 on canon iR3170Ci copier? - How To ...
www.howtomendit.com > Office Appliances, Photocopiers
Free repair help - error code e000067 canon ir3170ci copier. ... could anyone tell me what the error code E000067 represents and how can I clear this code.
Canon ImageRunner Error Code Reset - Question Defense
Jan 18, 2016 | Canon Office Equipment & Supplies
Canon iR6800C printer error code E000002-0001 pls fix this error code on photo coppier machin
Hi. You have to clear that error from service mode
Try to clear that error from service mode
press additional function
2 and 8 together
select copier
select function
select clear
select ERR
select ok. Unplug of the machine for 5 second and then turn it back on
try to make some copies, if problem persists fixing heater is damaged and need to be replaced
Mar 28, 2015 | Canon Office Equipment & Supplies
How to fix error e000001-0000 for canon ir6000
You can try to reset error code in service mode, but if the error persist after clear, you need to rectify the problem and replace fault component which is fairly fixing easy to do.
The problem can be in thermistor, sub thermistor or dc controller pcb, or ... call service!
To reset error code:
while ready to copy/showing the error code:
1) Press the user mode key ( * ) on the control panel.
2) Press the 2 and 8 keys at the same time.
3) Press the user mode key ( * ).
Choose: COPIER>FUNCTION>CLEAR>ERR
Turn off and back on the copier.
Jul 30, 2014 | Canon Imagepass L1 Print Controller For...
Ir5000 error code 000005-000 how do i clear it
Whenever you have replaced the fixing web, be sure to set '0' to
the following in service mode:
COPIER>COUNTER>MISC>FIX-WEB
COPIER>COUNTER>DRBL-1>FIX-WEB.
do not clear the limit,
Jan 16, 2014 | Canon imageRUNNER 5000 Copier
Error code e000001 0000
e000001 0000 is E001 error this is a fuser type fault.
First, the error needs to be cleared. Turning off/on won't do that.
You could go into service mode and clear the error (*28* > copier> function > clear > err > ok. Then turn the copier off, then on again and watch it heat up. I always monitor the temperature to make sure it's in the acceptable range (190 C or around that range).
If it happens often you need to change the thermistors . If it still happens, check the connectors in back of the fuser. They may need to be shimmed.
And you can get the service manual for ir5000 it will be help you a lot and save u $ you can get it from the below link:
http://goo.gl/k11ZyW
good luck
Aug 05, 2013 | Canon imageRUNNER 5000 Copier
What does error code E000001-0000 on a Canon IR5000 copier mean
The error code is much more likely to be E001, this is a fuser type fault. You should be able reset it in service mode. (copier, Funtion, Clear, error, turn m/c off then back on)
As the issue is a fuser temperature related. First, the error needs to be cleared. Turning off/on won't do that.
If it happens often I'd have the thermistors changed. If it still happens, check the connectors in back of the fuser. They may need to be shimmed.
Sep 01, 2010 | Office Equipment & Supplies
How to solove thiis problam ir 3300 E000602-0003
Just entered in service mode by press add. functon button then 2&8 together and add. functon button, in service mode entered in Copier then function then clear and touch ok tab in touch screen. restart ur machine error code should be cleared.
or run harddisk scanning mode by holding 1 & 9 buttons then switch ON machine. it will take one & half hour.
if still there is a problem then you need to change your machines HDD.
Jul 13, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Look up error code E00061001 for Canon 5020i
Title : E-061 Error Code Problem :
E-061 code is occurring for the IR5000/6000
Solution :
Check, re-seat or replace the Primary Corona Assembly
Apr 25, 2008 | Canon imageRUNNER 5020i Copier
Canon imageRUNNER 8500 Copier Logo
460 people viewed this question
old marine
old marine
