Question about M-Audio Audiophile USB Audio and MIDI Interface (Macintosh and and Windows) External Sound System
Recognizes the midi interface but not the keyboard
Hi
I'm using a macbook pro with osx 10.5.5 and I tried to connect my korg sp-250 with a m-audio uno midi interface. I installed the driver and the computer recognizes the interface, but no signal gets to the computer. For ex: I open Sibelius (a music program) and the program recognizes the interface but doesn't receive any signal whe I play on the keyboard.
Thanks for any ideas.
Sir,
I am using lenovo system IBM & this system format, but sound card not match this system.  You are requested to please solve the problem.
Posted on Dec 24, 2008
I am trying to connect my Korg M1 via my presonus interface into my Studio One program. HOw do I get connected after MIDI cables are hooked up?
Hope i did not miss understood...
If MIDI is hooked up there are only the audio signals left to connect...
Try to connect the audio outputs from the M1 to the DI´s of the interface via instrument line cables and routing them to/in your software...then set up midi channels for one instrument track that triggers the M1 and activate an audio track to record/monitor your incoming M1 audio signal
Mar 15, 2018 | Korg Music
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
How to connect psr-3000 to computer
You can connect it with USB connection to your computer. It should be plug and play, but some drivers might be required.
You can connect it also via MIDI interface: - you will need sound-card with MIDI input connector, or you can use special MIDI device like M-Audio UNO.
Mar 07, 2011 | Yamaha Full-Size Keyboard
I have an Alesis io2 audio-interface and a macbook pro. I'm using garageband software. I plug the interface into the macbook before I load garageband. (So standard protocol.) My problem is that when I...
sorry about your problem, i have the same issue. i think i solved i'm by using my midisport 2x2. Alesis fucked up on the midi with this unit. use an other midi sort, and that may fix the problem.
Jan 06, 2011 | Apple MacBook Pro MB991LL/A 13.3-Inch...
MBox 1 Compatibility with new Macbook Pro Unibody and OSX 10.5.6?
unfortunately any pro tools application below version 7.4.2 is not compatible with leopard and I don't think you can use mbox 1 with the universal mac I may be wrong but I wanna say I tried a while back and even garageband wouldn't find it anymore but you can check for sure by going to the applications folder then open the utilities folder in there is an application called "Audio Midi Setup" and you can select the mbox in there if you see it but if not there is no patch or driver that I know of to get it working unless you upgrade pro tools which if you do upgrade I suggest getting mbox 2 and getting LE with it
Mar 12, 2009 | Digidesign Mbox External Sound System
Mbox 1 Compatibility with new Macbook Pro Unibody and OSX 10.5.6?
it could be this mbox thing isnt compatible with intel chiped macs. did you check their website for minimum requirement and compatibility? any of your friends have the same laptop of yours and theirs is working?
did you google "macbook pro not working mbox 1" for forums that relate to you
Mar 12, 2009 | Apple MacBook Pro Notebook
I want to connect my YAMAHA DTXPRESS IV SPECIAL to my PC
Any pro-audio interface with a midi input would do the trick. There are numerous products out there that offer this. You can get a simple usb midi interface, and connect the Yamaha up with a midi cable running from the midi out of the drum module to the nidi in of the interface.
one of the simpler ones:...
http://www.amazon.com/M-Audio-Midisport-Uno-MIDI-Interface/dp/B00007JRBM
Jan 24, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Oxygen 8 Recognized but not working in OSX
i read somewhere, and it worked for me, at least in logic, that when i plugged it into a usb powered hub, it showed up in the audio/midi setup as a keystation and logic accepted its input..... when i had it plugged into the cpu direct (w/o hub) it was useless.... hope this helps....
Dec 18, 2008 | M-Audio OXYGEN 8 USB Controller
I have an io26 firewire audio interface linked to my macbook. When i record in cubase le4n i'm only getting sound out of the left headphone and its seriously quiet. I have set the audio/midi settings to...
your audio are not in interface with your macbook it means to say, the common wire are not in the same connection. that why you only hear sound on your left headphone. in short your firewire audio is not compatible with your macbook. but you can rewire it with same audio plug. or replace the audio plug with the compatible one. when you do this, make sure that the common wire of your firewire audio and your macbook are in the same connection.
Nov 07, 2008 | Computers & Internet
Open Questions:
M-Audio Audiophile USB Audio and MIDI Interface (Macintosh and and Windows) External Sound System Logo
296 people viewed this question
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
