Question about Nintendo DS Lite Console
Nintendo DS Lite power adaptor disconnection problem
Power adaptor for Nintendo DS Lite is stuck in the Lite console. Do you know how to get it out? Brute force doesn't work and the console is brand new, this was the first charge!
  • mathew_sling Dec 23, 2008
    Thanks for the suggestion but I can't budge it, feels like it will snap off.
    Yep "Nintendo" is facing up. I can't believe this has happened straight out of the box! Is this a common problem for others? Thanks for suggestions so far. Will be going back to Nintendo asap.
  • 24 Answers
There is a small latch on the connector that may be stuck. Try this. Turn the DS Lite upside down with the charger plug facing away from you. Press down the on the plug gently with your right thumb and with your left hand pull the connect away from the socket. FYI this should be a simple fit! Make sure the connector was not jammed in upside down to start with. It has a clear six sided shape to it!
Posted on Dec 23, 2008
  • Andrew Jury
    Andrew Jury Dec 23, 2008
    On the charger the name 'Nintendo' should be facing top! You'd have to be pretty special to get the connector in upside down! If it were me I'd sacrife the charger and cut awat carefully at the connector until its component parts are exposed and could be pulled away individualy. However, there is a good chance the console's socket is now damaged. Off to Nintendo service I am afraid...
Does a nintendo ds lite need the battery in to power up on just the adaptor?
The adaptor is only to recharge the battery. If you only use the adaptor without battery, I'm sure nothing will happen. You need the battery in or you can't play. But you can play with both the battery and adaptor in at the same time. It makes your battery recharge + you can play meantime.
May 20, 2010 | Video Game Consoles & Games
My nintendo ds is charging when I plug the AC adaptor but when is turn it on.. it doesn't start at all.. could someone tell me what's the problem in my DS
give nintendo a call or go to your retailer where you bought it if you bought the warranty youll get a FREE new one hope it helped vote thumbs up for more answers
Aug 09, 2009 | Nintendo DS Lite Console
Nintendo ds lite console
Not that common a problem. Have one on my desk at the moment with the same problem. It seems that the game bent two of the contacts in the card reader (ds lite game section -slot 1). I opened the slot and straightened the two pins and this solved the problem.
Be careful if you are doing this as it is quiet tricky with a good few small parts.
Mar 31, 2009 | Nintendo DS Lite Console
Power Button Sticking on Nintendo DS Lite
when you slide the power switch try sliding your finger off
Mar 14, 2009 | Nintendo DS Lite Console
Nintendo DS Lite Purchased in the USA
Remove battery clean contacts on battery and game using pencil eraser. Then try charging. Or replace the battery
Dec 26, 2008 | Nintendo DS Lite Console
Power cable stuck
just gently woble the cable from side to side as you pull it out... thats all the advice i can give towards this problem... sorry
Dec 25, 2008 | Nintendo DS Lite Console
Nintendo DS Will Not Charge
Try if the battery is charged right, when batter is fully charged disconnect from AC adapter. Hold the power button for 5 seconds. If it does not work that means that you need a replacement battery for the Nintendo DS. When you receive the replacement batter, follow the steps again.
Sep 11, 2008 | Nintendo DS Lite Console
Nintendo no power
I had bridged the F1 and F2 fuses and then replaced the top screen and seemed to fix everything
if you need more info or are looking for someone to repair I also do console repairs and have fix quite a few nintendo ds lite systems.
let me know and ill help you out.
either info or a fix
Aug 24, 2008 | Nintendo DS Lite Console
Vmx
looks like you need to replace the AC adaptor , test the AC adaptor with a multimeter to check Voltage , if there is Voltage reading?? then you need to replace the battery. hope this helps & please rate, AJ
Jul 02, 2008 | Nintendo DS Lite Console
Ds Lite not power up L2 Inductor is not good not work.
For the L2 L4 inductor specification, I check the following website, on there have original L2,l4 inductor power and specification
http://www.logictoyz.com/nintendo-ds/nintendo-ds-lite-spare-parts/ds-lite-l2-inductor-power-replacement-.html
By the way,L2,L4 is not fuse,
It is Inductor power
May 30, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
56 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
