Question about HP Scanjet 5590 Flatbed Scanner
Problem with scanning of document
During scanning when i click on preview icon then this will show the messsage as following
scanning could not be completed coz of lamp < to solve this problem disconnect the power cable. then i remove power cable for 60 sec. but the scanjet showing problem again and again. send me answer as soon as possible. is it problem of hardware of scanjet or software?
    Genius:
  • 2,785 Answers
Just try once by reloading the drivers and try with another usb port and cable, if the problem is not solved then your scanner needs servicing
Posted on Dec 23, 2008
Hp 6210 officejet all in one ... want to test scanner only. Took 16 hour tech assist to download (software was not provided by work associate). Ink cartridges do need to be replaced. Want to test the...
yes, you can test the scanner without inks.
use the hp solution center c01810967.gif installed on the computer Double-click the HP Solution Center icon (c01810967.gif ) on your desktop
  • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
  • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
    For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    • Scan to: Select your scan destination from the drop-down list.
    • File Type: Select the file type from the drop-down list.
    • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
    • Show preview...: Select this check box if you want to see a preview before the actual scan.
      Click Scan
Jun 05, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How can i fax and scan on canon mx310
for scan, in windows go to accessories
click on scanner and camera wizard
select your pixma mx310
click on next
click on preview for preview you document or photo click next
click next
now it show your scan document
enjoy
M. Zahid click next
click finish
May 14, 2011 | Canon PIXMA MX310 All-In-One Printer
Which software to scan ?
Down load the software for your windows 32 or 64 bit here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=1138373&
You need the full package to use the scanner.
To scan a picture or document, follow these steps: Step one: Load the item to scan You can scan from the scanner glass or from the ADF (Automatic Document Feeder) tray, if your product has one.
  1. Make sure that the product is connected to the computer.
  2. Turn the product on.
  3. Load the picture or document:
    • Scanner glass : Place the item with the print side down on the scanner glass, and then position it according to the engraved guides around the glass (usually on the right-front corner or the left-front corner). Close the scanner lid.
    • ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item. CAUTION: Do not load photos in the ADF. Use the scanner glass instead to prevent damage to photos.
Step two: Scan the item
  1. Open HP Solution Center with one of the following methods:
    • Click Start , click All Programs , click the HP folder, and then click HP Solution Center
    • Double-click the HP Solution Center icon (c01810967.gif ) on your desktop.
  2. If you have more than one HP device installed, click the tab or icon for the product that you are using to scan.
  3. Use one of the following methods to start the scan:
    A screen displays to prompt for scan settings. If a settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    3. Start the scan again.
  4. Read through the various options for the scan settings. Make selections for at least the following items:
    c01940398.gifImportant : HP Solution Center software versions vary, depending on the age of your product, and whether you installed updated software after the initial setup. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  5. Click Scan . The preview screen might display, if you selected an option to show a preview. Use the options on the preview screen to make any desired adjustments before you complete the scan.
After the scan completes, it goes to the destination that you specified in the settings. hpweb_1-2_plus.gifhpweb_1-2_minus.gif Using the scan button on your printer HP recommends that you first get comfortable with using the "Scan Picture" and "Scan Document" on-screen "buttons" in HP Solution Center as explained in the previous steps. By doing this, you determine the scan settings that you use most often, and then you can more easily set up the scan button on your printer. c01940398.gifImportant: Before you use the scan button on your printer, use HP Solution Center to create the settings for that button . For example, you need to decide whether you want a settings prompt screen and a scan preview for each scan. Also, you must create the list of "shortcuts" that you want to display on the front panel of the printer. To get started, click Settings , click Scan Settings , click Button Settings , and then click the tab for Front Panel Scan Buttons . Read through the options, and then create the settings that you want.
Mar 03, 2011 | HP Officejet 4355 All-In-One InkJet...
L want to scan a document with hp office jet 4355 how do l get scaning option from my computor
1.Turn on your computer and wait for it to boot up, then turn on your printer.
2.Locate the " HP Image Director " icon on your computer and double click it.
( This icon was placed there when your printer was installed on your computer )
3. A screen will appear showing the scanning options available on your printer.
4. Place your document or picture on the printer's glass top.
5. From the HP Director screen, click on the appropriate button to start the scanning operation.
The scanner will perform two passes, the first; is to preview your document or picture and to
make changes, if necessary, the second; is the final acceptance of the document or picture
and save it on your computer.
All scanned pictures can be viewed in the HP Photo Gallery and the My Pictures folder
Documents can be viewed in the My Documents folder.
I hope your scanning goes well.
Feb 07, 2011 | Office Equipment & Supplies
How do I scan a picture and email it?
Hi
You can start a scan from your computer or from your HP OfficeJet.
to scan an original from your Windows computer
1 Load your original either on the glass or in the automatic document feeder
(ADF).
2 Press Start Scan.
A scan of the original appears in the HP Preview window.
3 In the HP Preview, you can edit the scanned image. When you have
finished, click Accept.
For more information about making changes to an image during the
preview, see adjust an image during the preview in scan pictures and
documents in the HP Photo & Imaging Help for more information.
The HP OfficeJet does a final scan of the original and sends the image to
the HP Photo & Imaging Gallery.
If i helped you pls vote me
Sep 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
How to scan using hp j4580. Booklet only tells how to fax!!!!
    • Click the Windows icon c01319360.gif , click All Programs , click the HP folder, and then click HP Solution Center.
    • Double-click the HP Solution Center icon on your desktop.
Jul 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do you scan a picture?
simply installoffice 2003 and there will be microsoft office tools select microsoft office document scanning select scan new document.....first of all u have to install printer drivers my dear friend
Mar 11, 2010 | HP PSC 1210 All-In-One InkJet Printer
I did not receive a manual when I purchased my HP Officejet J4580 All-in-oe printer. I'm trying to scan a document that I need to send as an e-mail attachment. Is there a simple way to scan my document?...
Download Manual from here:-
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=3645100&lc=en&cc=us&dlc=en&lang=en&cc=us
1) Load the item to scan
2) Scan the item
    A screen displays to prompt for scan settings.If a settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
For more details visit this link:-http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01585107&cc=us&lc=en&dlc=en&product=3645100
Have a nice day...do not forget to rate the solution.
Feb 17, 2010 | HP OfficeJet J4580 All-In-One Laser...
I have an HP Officejet 6500. I want to scan a document to a PDF, then upload it to a website. How do I do it? I scanned the document, but now I can't find the PDF.
(1.) Start / All Programs / HP / HP Viewer / Scan Document (icon is in left margin)
(2.) A small screen appears entitled "Select Source", and provides the "HP Officejet 6200 Series TWAIN" option. Highlight this then click "select".
(3.) I accept the default provided on the next screen (i.e., radio buttons for "Document" & "Scan for editable text"; "Scan to:" (drop box) "HP Document Viewer; check "Show Preview" box; then click "Scan".
(4.) After a brief pause, my printer scans, then the HP Document Viewer screen on the PC provides a small image of the scanned document and allows me to click the "accept" icon.
(5.) After "accepting" the scan into the HP Document Viewer, it takes a minute for it to appear in the "viewer". Notice that the "View Thumbnails" tab is highlighted at the top of this screen. Click the check-box next to the scanned item then click the "View Page" tab just to the right of the "View Thumbnails" tab.
(6.) The new screen should show a larger version of your scanned document. Now notice the "Save As" icon in the upper left corner. Click that, then "yes" to warning default screen, then select a file name and location to save it into.
(7.) Before clicking save, click the drop box next to the "Save as type:" and select one of the pdf options. Mine offers: "PDF 1-bit", PDF 8-bit Grayscale", and "PDF 24-bit Color" options. Choose one of them then click "save".
(8.) You should then be able to find the scanned pdf file in the directory you selected to save it under.
Note that you may need all of the HP printer utilities and tool software installed for this to work. If you don't, you may need to uninstall/reinstall the printer software.
Nov 06, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Scanner
There is glass platen and on its sides you can see the markings to place various paper sizes. Just follow them as per your paper size.
Oct 05, 2007 | Epson Perfection 1240U Flatbed Scanner
HP Scanjet 5590 Flatbed Scanner Logo
297 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
