Question about Kitchen Ranges
The flame on my gas stovetop won't get larger
I have a gas stovetop. One of the burners on it cannot give me a large flame. It turns on fine, the flame is even, but when I turn the knob on the oven (to increase the flame), nothing happens - it stays as small as ever. Any idea why this would be, and how to fix it?
Thank you
  • shlo77 Dec 23, 2008
    Thanks very much.
    We just began renting this apt. Everything around this place is dirty, broken, and clogged. So it's probably a clogged orifice. We have never seen a good flame come out of it since we moved in.
    How do I unclog it?
    Thank you again
    Great advice. Very, very helpful. Thank you very much.
  • 3 Answers
If this was not always the case then the orifice is partially plugged & needs cleaning.
If this was always the case then someone may have squashed the gas line when changing the orifice (perhaps to or from propane?). In this case you will need to change this part of the piping.
Posted on Dec 23, 2008
  • phantss Dec 23, 2008
    Since you have never seen a good flame then it could still be a squashed gas line. Remove the top cover of the stove top so that you can see all the gas lines to check. You will need to do this anyway. If pipe leading to that orifice is bent or squashed you will notice by comparing to others connecting to other burners. Orifice threads out. You should have TWO wrenches otherwise you may end up with problem above. Not sure how to clean a plugged orifice but soaking in soapy water might work depending on what is down there. Could assist with straightened paper clip or whatever fits but won't break off inside. Pressured air might help.
Oven ignitor intermittent spark, oven wont light, emits gas.
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Mar 13, 2015 | Ovens
What can I do to fix my Wirlpool Gas Oven? Mo. # WFG361LVB
i would check my oven gas safety valve first
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
May 16, 2014 | Whirlpool Ovens
NATURAL GAS OVEN WONT COOK PROPERLY
ELECTRIC OVENS:
Apr 06, 2014 | Frigidaire Ovens
Frigidare gas oven wont ignite
ELECTRIC OVENS:
Feb 07, 2014 | Frigidaire Ovens
My hotpoint gas stovetop is leaking aldehydes, per gas company. They said to replace gas burners. will this fix the problem?
I don't know your make and model number so can't tell you if it will or won't. BUT I would think the problem would be the gas valve and not the burners.
What led to the gas company being called? Gas odor? Give us some background to work with, so that we can give you better advice.
Jul 27, 2011 | Hotpoint Kitchen Ranges
One of the 4 burners has a LARGE, YELLOW flame (right rear burner). It just started today. Other 3 have a BLUE flame. Using Propane Gas Is this a fuel/air mixture problem, and if so, how do I fix...
The yellow flame suggest incomplete combustion is taking place and on a flueless appliance Otis very dangerous, check for dirt/greese that has accumulated aroroud the gas jets ( this will dercrease air available at the primary airport) if this is clean then your gas jet may be worn and become larger allowing more gas than air as they mix, in this case you will have to replace the gas injectors
Jul 12, 2011 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Our Uniflame Grill has a round outer burner and a round inner burner. The outer burner has a large orange/yellow fllame. The inner burner has a small blue flame. Is it normal for the inner burner to...
Bob, your wife is partially correct. However, both burners should have blue flames with orange tips. Cleaning the burners and the their venturi valves, should solve the problem. When I say cleaning them, I mean removing and cleaning them.
Hope this helped you and Happy Grilling!!
Jun 27, 2011 | Uniflame FG2204C Grill
Middle burner of 3 is just a large flame.
Either the burner or the line to burner could be sooted or dirty
Apr 19, 2010 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Jenn-Air Gas stovetop
try to clean the burner and then try it.
Sep 21, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Gas Burners Not Lit Completely
sounds like there isnt the right amount of gas coming out of the orifice. orifice could be partially plugged
Oct 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
149 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
