Question about Toshiba Satellite A135-S2276 Notebook
Getting off suddenly.
While working with sattellite a 135, it's getting off suddenly. And now the laptop was broken. I don't know what's the matter of this laptop.
  • Freddy Gonzalez
    Freddy Gonzalez May 11, 2010
    Hi, debits to be able to indicate ourselves since is that it leaves and since it is that this I broken, according to what you describe it seemed that it is restarted only or power off, if it is last this your equipment can need preventive maintenance, it is possible that the thermal modulates this one very covered and the equipment does not remove the temperature of the CPU and for this reason the same power off automatically
  • Dan rogers
    Dan rogers May 11, 2010
    getting off what? And how is it broken? We need more info
I TOO FACE THE PROBLEM IN WL LAN THROUGH ROUTER NOT WITH CABLE! THERE MUST BE SEVERAL STUPID SAFETY MEASURES/FEATURES ARE BUILTIN- I SUSPECT U MAY FACE BIOS PROBLEM SOON- FREQUENTLY CLEAN DISC , DEFRAGMENT AND ABOVE ALL KEEP BACKUP DATA. VISTA HOME PREMIUM IS BETTER TO SOME EXTENT. Disconnect AC when not in use since SPIKES may trigger one of the safety measure and trouble U
VNRao
Posted on Jan 11, 2009
Have an industrial singer 31K20 and plate no is Y9279937 and i am trying to buy needles for it. THe broken needle is 19/120 but i dont know if they need to be 135/17 or 135/7 - or doesnt it matter
any sewing rade shop will have an assortment of needles
they will be able to advise you on the correct needle to use for different materials that can be sewn
there is a site on the net that explains the needle sizing and uses
go google and type in--- needles for industrial sewing machines ---
pick the information for singer or read what is pertinent to singer
Nov 06, 2016 | Singer Sewing Machines
Kawasaki 135 ls.no ligthing works and can't charge the battery.
Hi Rey, in order to check out any main system electrical circuit, you have to start with a fully charged battery 12.5 volts or better, and be able to pass a load test if necessary.
1. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
2. Check the voltage drop at the battery when you hit the starter button, anything below 9 volts you might have a faulty battery.
3. Check voltage at the battery with the bike running at 3,600 RPM should be 14.3 to 14.7 volts. If you are not getting these numbers, you might have a faulty voltage regulator.
4. Make sure voltage regulator is grounded and functioning properly, watch the video below on how to test a voltage regulator.
5. Unplug the connector to the alternator and hook your multimeter leads to the alternator (pin/socket selection does not matter) set the multimeter to AC volts, at an idle the meter should read 16 to 20 volts AC. at 2,000 RPM 32 to 40 AC volts, 3,000 RPM 48 to 60 AC volts. If you are not getting these numbers, you may have a faulty rotor, follow step 6
6. Set the multimeter to OHM'S, connect one lead to the alternator (any pin/socket) and the other to a ground, the meter should read infinity. Connect both leads to the alternator meter should read 0.1 to 0.2 OHM'S. If you are not getting these numbers, you have a bad stator.
7. Check all wiring in the charging circuit for worn or chaffed spots and all wiring connectors in the circuit for corroded, broken, or loose pins/sockets, which is the # 1 offender.
For more information about your issue please visit the websites below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/kawasaki+135
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 13, 2015 | kawasaki Motorcycles
An alarm sound just started going off. I don't know how to make it stop.
my toshiba laptop is working but dont coming display so please help me
Jan 22, 2013 | Toshiba Computers & Internet
Altec lansing ada885
All of your speakers get power from your sub. The volume control may have failed or the connection to the sub may be loose or broken. The power light indicates only that primary power is getting to the sub; the amplifier ICs may have failed. It will be necessary to open up the sub (if possible) to find out what failed.
Nov 12, 2012 | Altec Lansing Audio Players & Recorders
On my Toshiba sattellite ,neither shift key will work
1. Look at ur keyboard settings.
2. Use caps lock
3. Bash your keyboard with a sledge hammer and put on a big smile....like you accomplished something.
Apr 18, 2010 | Toshiba Satellite A135-S4527 Notebook
Originally when I pressed anything on the number pad every touch would type a 1 no matter what key I touched. The numlock light will not switch off. When I hit fn + num lock it shuts the computer down....
if you ahve any external usb keyboard just connect it to testing may be your laptop keys are stucked .try to clean the with dryer. just give hot air to keys with the help of dryer. but make sue it should not too close to keys.
Nov 20, 2009 | Toshiba Satellite A100-S8111TD Notebook
Sattellite 1415 s173 format problem
http://forums.laptopvideo2go.com/topic/7011-toshiba-notebook-dmi-updates-for-wrong-error-message/
Aug 02, 2009 | Computers & Internet
What button do i hit to reformatt hardrive on toshiba sattelite p
First do you have all the software CDs that came with your machine, if not you will have to obtain a copy of whatever Windows software you prefer, when you format you lose EVERYTHING, only the BIOS is left.
If thats all ok the go to the bottom of your screen and click on "RUN" a dialog box will appear in this dialog box type in "Format C:/ and follow directions and good luck, you are in for hours and hours of work getting your computer back where you like it again.
Feb 12, 2009 | Toshiba Satellite A135 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
