Question about Toshiba Satellite A65-S126 Notebook
Video output is upside down on Monitor.
My Video output is upside down on my Monitor after booting my computer. The login screen is even upside down. I tried another monitor, but the same result. My OS is Win XP. CPU is Dell Optiplex GX260. ThX
  • koofah Dec 24, 2008
    Ziraffa,
    Your Solution was extra extra helpful. Thanks .Happy Holidays
  • 827 Answers
Hi Koofah,
To fix the issue press Ctrl-Alt-Up. To permanently fix the problem go to:
Start >> Control Panel >> Display >> Settings >> Advanced
Where it is after that it dependent upon your video card.
Fixya!
Season's Greetings!
Chris (ziraffa)
Posted on Dec 23, 2008
  • chris grams
    chris grams Dec 24, 2008
    You're very welcome:)
    Have a good one!
    Chris (ziraffa)
Lacie electron blue desktop rolls over top of monitor
I agree--you need to first try another monitor. Sounds like a monitor problem to me.
Jun 28, 2012 | Computers & Internet
Why does my monitor have a white screen
First, it could be out of adjustment--turn the brightness and contrast controls up and down to see if it makes a difference.
You could have a bad video card in the computer. Do you have another monitor to try to see if the actual video output is good? This is the easiest way of troubleshooting.
When you start the computer, can you see any white printing on the screen indicating it is booting? Does the problem start once Windows starts? If so, try starting in safe mode. If you can do this, then I'd suspect video driver problems.
Dec 27, 2011 | BenQ FP791 17" LCD Monitor
No video appearing on screen of IBM intel celeron model r51e monitor
Attach an external CRT (or LCD) monitor to the VGA-output port,
and reboot the laptop. Does anything show-up on the external screen?
You might have to press "FN + something" to toggle the computer:
* video-output only to internal screen
* video-output only to external screen
* video-output to both screens
to get video-output to the external screen.
Or, take the laptop into a darkened room.
Now, do you see anything at all, even faintly,
i.e., your normal "desktop-icons" and "wallpaper" ?
If so, then the "video-inverter" part of your LCD screen has failed.
It's about a $20 part, but you should add $60, for one hour of labour
by a qualified technician, to disassemble your computer, replace the bad part, reassemble and test.
Jan 07, 2010 | IBM Computers & Internet
Upside down screen on monitor
hi,
turn your monitor upside down on your desk and look near the clock at the bottom in the system tray. you may have a shortcut there to that video setting, hover above the icons next to your clock, hopefully one of them is your video settings and study in there to change the setting back to the way it was. if not then right click the destop, go to properties, then go to settings in your display properties, then click advanced, and right in there should be a setting to flip the screen 180 degrees back to the way it was..
jm
Dec 15, 2009 | ViewSonic VX2235WM Monitor
My monitor on my computer is shoing upside down
press Ctrl-Alt-Up - right side up 0n y0ur keyb0ard.
(If that doesn’t work, try Ctrl-Shift-R)
Jan 15, 2009 | Computers & Internet
I have a BENQ JoyBook Lite U101. For serveral days I had my monitor output connected to a HP L1706 monitor. Yesterday I tried to connect my video output in our boardroom - however the output from the...
It sounds like the video card could not handle the monitor in the board room - As it is unless you have a graphics based laptop you rarely get a high quality video card built into your laptop.
Causes aside boot your computer in safe mode - This is done by tapping F8 several times during startup
A menu should pop up - select boot in safe mode
A long list of text will pass in front of the monitor - Do not fret this is just Windows telling you what it is loading.
Once at your desktop you should be able to see everything clearly
Right click on your desktop
Goto Properties
Settings
Drag the Screen Resolution down to something more appropriate e.g. 1024 x 768
Jan 07, 2009 | BenQ Joybook 5000 Notebook
Hyundai flat screen monitor upside down display help?
There are 4 screws on the back that connect the monitor to the stand. Remove them and turn the monitor right side up and replace the screws tightly. OR you can change your layout in your video card settings.
Nov 20, 2008 | Hyundai L91A 19" LCD Monitor
Computer
When your computer first boots is everything up the right way?
If so, errrr you may have to turn your monitor upside down to do this with any ease, but have a look in your video cards control panel. It may have been set to rotate the display by a hotkey accidently.
Just set it to be 0 degrees and apply.
Hope that helps =)
Apr 03, 2008 | Samsung SyncMaster 910T 19" LCD Monitor
Monitor goes standby after boot
Look the problem it may not your monitor it's your windows XP. Let me guess you have a VGA/Svideo card. From prior experience I can tell you that dual output Nvidia cards will default to Svideo first, and then "adjust" your windows settings to do so every time even if a VGA monitor is re-connected (HIGHLY ANNOYING). So if the last thing you see before nothing is the Windows XP boot screen, here's how to fix it. Boot to safe mode uninstall your video driver, reboot then reinstall. You can substitute a system restore for uninstalling your drivers if you can remember when the monitor was last working. This really really pissed me off when it happened to me.
Jul 09, 2007 | HP mx705 17" CRT Monitor
Toshiba Satellite A65-S126 Notebook Logo
240 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
