Back to:
Tags:
OKI MICROLINE 520 Matrix Printer
Oki 520 missing print
posted by xcite47 on Apr 10, 2007
Hi, the problem I have with my printer is that when it prints it never never prints the top line of dots, so when I print something off it never prints the top of the letters. ie.. if it was to print the letter T it would look or like an I.
I have replaced the print head and ribbon, any ideas what might be causing this.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 10, 2007
FixYa! (100)
dodgecharger
Rank:Wiz Wiz
Rating: 82%, 264 votes
You have replaced the item which is commonly the cause- the printhead. The other possible problems are: a connection break in the printhead ribbon cable, which makes electrical connection from the driver circuitry to the printhead. Look for a tiny crack, especially along the edge of this ribbon cable. Another possibility is an electronic component defect in the circuitry which fires the printhead, or maybe a loose solder connection in the same circuit.
Lastly, when you replaced the printhead, are you reasonably certain the replacement head didn't have a broken top pin or two?
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Oki 520 missing print:
I don't want to Accept this solution
Can you Help with these Printers problems?
I 'pressed and released the SEL button, then held the...
i have several docs which are 4-6 ply and the 420 prints...
We unplugged the printer and gave it a good blow out. We...
We have an OKI Microline Elite 520 matrix printer that is...
Last week the above printer "corrupted"...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
