Question about NEC 133MHz CPU&Chassis Power Board Assy (3RE0B13512240)
What is computer chip? - NEC 133MHz CPU&Chassis Power Board Assy (3RE0B13512240)
  • 599 Answers
Do you know what a chocolate chip is?...well its nothing like that...
..need more info..or ..try this... a circuit board..very tiny..that holds many many pathways routing electrical impulses to there proper destination
Posted on Dec 23, 2008
Are 2002 Aztec computers compatible
I am assuming you are discussing the 2002 Pontiac Aztec, the early crossover with the rather distinctive look. I would assume that since they were made by the same manufacturer and they used the same parts that their computers should be compatible. I can't say so for certain as you haven't provided much information, but, unless one of the Aztec owner swapped out the original computer and replaced it with an updated device, the computers should be compatible.
If you are thinking of trying to swap computer chips, I would advise you to wait and let a professional do it at an independent shop. The reason I suggest this is simple, unless you know how to access the computer chip correctly, you risk accidentally ruining it. If you handle the replacement chip incorrectly it is entirely possible that for a stray static charge to ruin the chip by blowing out a trace. Also, if you damaged the socket from which the original chip was removed then it is possible that you will not be able to reinsert the new device without bending any leads on the bottom. If the leads are damaged, then the new computer won't work.
Even if the new computer chip and the original chip were already installed in installable cases (the way most desktop computer chips are installed), it is possible that when you removed the computer, you might have damaged the receiving socket which means that when you go to insert the new computer carrier it won't work correctly because a few or many of the pins on the bottom of the board won't sit correctly.
Jan 03, 2015 | Computers & Internet
Does my 1994 J30 have a computer chip of any kind on it?
That depends on what you mean by "chip" as all computer contain chips to some degree. If you mean a chip in the key, then no, USA production Infiniti models did not have transponder chip keys.
Mar 04, 2014 | Infiniti J30 Cars & Trucks
I have a grand caravan i had a new starter put in as well as a new computer and it still wont start. have any answers?please help.we think it is the security but dont know how to fix
when you purchased the computer, did you remove the computer prom with the CHIP from your old computer ? cause when you bought the replacement computer it DOES NOT have a chip in it ! youmust put your old chip into the new computer or you have NOTHING but an EMPTY BOX ! do you understand ??? you must get back your chip thats still in your old computer ! the person who sold you the replacement comp., they aren't the brightest people in the world, you know what I mean. you thought you where getting the complete package, they assume you know what your doing, when in reality ??? GET YOUR CHIP BACK, THAT CHIP IS SPECIFCALLY FOR YOUR VAN, WITH OUT IT YOUR TRUCK WILL NEVER START AGAIN !!!!!!! I DON'T KNOW IF YOU COULD GET ANOTHER CHIP , THERE ARE AFTERMARKET CHIPS , $100 + . GOOD LUCK !
Mar 24, 2013 | Dodge Grand Caravan Cars & Trucks
I can't close tower cover
When your computer appears to slow down, one way to help increase its speed is by adding memory. You can easily purchase memory chips from various online sources or if you have a Dell Dimension and want to stick with Dell products, you can purchase additional memory chips from Dell itself. It is not difficult for a non computer person to add memory to a Dell Dimension, although sometimes, it is cheaper to purchase a new computer and then install additional memory.
Shut down your computer, turn the computer off and unplug it. Open your computer case. There will be two thumbscrews on the back of the Dell Dimension computer case that will release the cover. The side of the computer case will then slide backward and lift away from the rest of the box. Locate the slots for RAM. These are short off-white slots that are near the power supply on the motherboard. They will be slightly longer than the RAM you are about to add. There will be at least one RAM chip already in place in one of the slots. Place your new RAM chip into a blank slot gently. It does not matter which slot you use; any will work. When you press the RAM into place, be sure the notch on the chip lines up with the slot. There will be a guide on the slot to ensure that you do not insert the chip backwards. Press down on the RAM chip until it locks into place. There are two guides on the side of the slot that will snap into place on the sides of the chip to ensure the chip does not fall out. It will take a bit of pressure to make the chip snap into place, so press straight down into the motherboard to get the chip in place. Close the computer case, put the thumbscrews back where they belong and start up the computer. Your Dell Dimension will sense the new RAM, which will be available to the operating system when the computer starts up. Hope this helps.
Dec 30, 2012 | Dell Dimension 4600 PC Desktop
Compaq sr1303wm makes beeping
This is normally caused by a memory issue. Unplug the computer, pull out the memory chips. Now place one chip in one of the slots and turn the computer on. Even if the computer comes on, unplug it again and try the other chip in the same slot. Then repeat the process in the other slot. Hopefully one of the chips will cause the condition and not a memory slot. If it is a chip then just replace that memory chip. If it is a slot, you will have to either not use that slot or replace the motherboard.
Jun 28, 2012 | HP Compaq Presario SR1303wm PC Desktop
Power button does not work vostro 1700
LOL, sounds like a lemon. I would think either the memory, power cord or CMOS battery might be the cause. But since it boots each time after you go thru the process you described it has me baffled.
Maybe one of your memory chips is bad.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Mar 31, 2012 | Dell Vostro 1700 Notebook
If i change from a v6 to a v8 on my 93 mc do i have to swap out the computer?
No, they use the same computer. But the prom chips in the computer are different. It will run fine on the 4.3 chip but it will run better with the V8 chip. After you switch it, I would order a performance V8 chip for it.
Nov 11, 2010 | 1993 GMC Sierra
Where do i install the chip on 2002 monticarlo
the chip go's inside the ecu or the car's computer (most newer cars the computer is located passenger side in the engine compartment front disconect battery locate the access plate should be 1/2 x 2 see chip pull chip streight out DO NOT TOUCH PINS static will kill chip take new chip (note the way you pulled old chip out chip must be installed the same direction reinstall cover plate connect battery start car
Dec 06, 2009 | Chips Computers & Internet
Memory chip set.
If you have overheated the computer you may have already done your damage to the mainboard. It may be time to replace the main board if it has been overheated. The CPU could have been overheated and damaged.
Jan 15, 2009 | Toshiba Satellite P35-S609: Pentium 4-3.2...
You given me computer chip
A computer chip is a small electronic circuit, also known as an integrated circuit, which is one of the basic components of most kinds of electronic devices, especially computers. Computer chips are small and are made of semiconductors that is usually composed of silicon, on which several tiny components including transistors are embedded and used to transmit electronic data signals. They became popular in the latter half of the 20th century because of their small size, low cost, high performance and ease to produce.
Dec 23, 2008 | Dell A215 Computer Speakers
Computers & Internet Logo
163 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
