Question about Sony LBT-LX90AV CD Shelf System
MY SONY LBT-LX90AV CASSETT PLAYS DISCORD AND BELT FALLS OFF
ANY TIME I PRESS FOR PLAY THE BELT FALLS WHICH I PUT IT BACK THEN PLAYS FOR FEW MINUTES THE FALLS OFF AGAIN
  • 24 Answers
Hi. Make sure the flywheel turns freely and that the capstan pin and pressure roller are clean. If this is OK then it is more than likely that the belt is stretched, dried out or generally worn. These parts only have a certain usable life and are quite cheap to replace.
Posted on Dec 23, 2008
I have a sony lbt d550 cassette player that needs new belts. I need a picture of how to install the belts or how they are configured.
Below is a link for the service manual! The cassette dismantle is on page 9. from what I see there is a plate that covers access to the belts, that is if Your lucky! the plate is shown in the first picture on page 9, sorry I have worked on other brands, and some of them You have to do a lot of dismantling to even get to belts! Hope this helps You! Regards!
Sony HCD A295 HCD D550 LBT A295 LBT D550 Service Manual
Jul 14, 2017 | Sony Audio Players & Recorders
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
SONY LBT-XB88AVcd player will not play cds
Take it to a certified Sony Service Centre and have a technician look at it. The disc loading mechanism is a complicated piece of engineering that needs dismantling by someone who knows what they're doing. From experience, it will probably need a new laser assembly, but if you're lucky it could be just a worn belt on the loading assembly. Whatever, don't be tempted to have a go yourself - or trust a 'back street' repair shop - I've seen too many that end up being scrapped because of it!
Apr 17, 2014 | Sony Audio Players & Recorders
My sony walkman WM EX-190 is playing at low speed than normal. I changed the belt. bot still it is not playing at normal speed.
its maybe a failed speed ajustment or its slipped there is normally a tine whole on the back under the belt clip, press play and insert a small screw driver and turn u should find it speed up or slows down, if not its failed, but please be careful they are delicate anyhow
Jul 31, 2013 | Sony Audio Players & Recorders
Sony Handycam CCD-TRV21 won't play tapes.
no that u must remove ur camera and try to clean all strip that connect with board and mechanisum and all connectors legs solder then it will work .any doubt call u.a.e no 00971503853766
Jul 04, 2009 | Sony Handycam CCD-TRV21 Camcorder
Cassette stuck in Sony TC-K611S deck
Rotate loading gear with your finger until mechanism released and set on stop position. press eject button and take out tape.
Jul 01, 2009 | Audio Players & Recorders
Broken drive belt on cassette player lbt g2000 how
just go to a good electronics store i bought a pack of ten assorted belts today for $7.97 at **** Smith Electronics
May 16, 2009 | Sony Audio Players & Recorders
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
Sony WE605S won't play in back direction any more
if the square belt kinda serpentines in and around a couple pulleys (or did originally) then it did not get put back on correctly. try to think of another way it could be threaded through the pulleys.
Jan 24, 2009 | Sony DECK, MECH WITH AUTO REVERSE Single...
Sony LBT-LX90AV CD Shelf System Logo
148 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
