Question about JVC GR-D250 Mini DV Digital Camcorder
MESSAGE ON SCREEN
Mini dv model no GR-D31EKon the screen all i get is the message
condensation operation paused
how do get rid of this i have pressed every button but its still there
  • dannyboys43 Dec 30, 2008
    the repair shop want £200 to fix this problem a new cam is only £100 if the hair dryer doe's not work then the cam will become a doorstop
    many thanks for the help what a gr8 site
  • worpydooley Feb 07, 2009
  • 4,234 Answers
Since water inside of these is a bad thing, these units contai a "dew sensor" that will prevent the loading of the tape if a "wet" condition exists. This can happen if the camera is cold and the room you are in is warm. The humidity on the air will condense onto the camera internals and cause this to occur. Try ejecting hte tape, leaving the compartment open and point a hair dryer at it. Keep the hair dryer a bit away from the unit, you don't want to heat it up, just get some warm air inside to evaporate the "dew".
If that fails to resolve the problem, the sensor itself may be defective and need to be replaced.
Keep us posted.
Dan
Posted on Dec 23, 2008
When I switch on the unit it says "Condensation, operation paused"
I just left the unit switched on and after about 1 hour the message cleared, then I was able to use the unit.
Jan 11, 2010 | JVC GR-D60 Mini DV Digital Camcorder
Lcd screen reads
Either the dew sensor is defective or there is some condensation inside the unit. Try opening up the unit and pointing a hair dryer at it from about 12" away (enough to blow warm air inside the unit, not hot air). Let that run for about 10-15 minutes and try the unit again. If it continues to fail, than the dew sensor needs to be replaced. This repair shoold be done by a repair shop as cameras are not the easiest to work on.
Dan
Nov 13, 2009 | JVC GR-D350 Mini DV Digital Camcorder
Getting a message on my camcorder lcd. "condensation operation paused"
According to my Canon manuel, it occurs when condensation forms water droplets inside the camera.It also says that the camcorder will auto matically shut off. Time will vary depending on location and weather condition. General rule is 2 hours.
Oct 05, 2009 | JVC Cybercam GR-D70 Mini DV Digital...
Help
yes had this on a few JVC it may be that the moisture has corrosded the dew sensor and will need service. When you store it use those crystals that come in packing of some items They are excellent for preventing this in Video cameras
Please rate our help to keep the service online
Aug 17, 2009 | JVC GR-D290 Mini DV Digital Camcorder
Following message is displayed on screen Please wait condensation operation paused
Hi FixYa !
My problem seemed to be like so many others, i.e. dirty or defective sensor.
One solution, was to turn the camera on, with the charger connected, and leave it on.
After app. one hour, the fault disappeared, and the camera was functional again, but the next day, I had to repeat the operation again!
Is there any where "cleaning the sensor" is descriebed?
Regards pb58
Polle
Jun 23, 2009 | JVC Cybercam GR-D30 Mini DV Digital...
Condensation, operation paused, JVC Video Camera model GR-D70AS
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
Apr 27, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
Gr-dx97 - condensation, operation paused message on screen
Dec 31, 2007 | JVC GR-DX97 Mini DV Digital Camcorder
Help me please....
try removing the battery and take a clean soft cloth and gently wipe surface.
Jun 21, 2007 | JVC Cybercam GR-D90 Mini DV Digital...
Condensation
This is a bad or dirty dew sensor, a common problem with this model. It's not a user correctable problem. Your local camcorder repair shop should take care of it ( under $100 ).
Jul 12, 2006 | JVC Cybercam GR-D30 Mini DV Digital...
Open Questions:
Audio drop out and/or static sound Thanks to anyone who has taken a look at my issue with audio cutting out. JVC has always been a brand I have confidence in, and I believe I picked this camera up when those recording to an internal hard drive were out of my range. Last summer, I received a fantastic deal on some JVC Evarios, so GR-D250 duo would be used only as back-up, BUT, I have a ton of old Mini DV tapes -- never recorded over anything. I would find the heads needing cleaning solution highly unlikely. The first 250 recorded the bulk of those 150 or Mini DV's and worked like a champ. Because of legal depositions for lawyers and like, who may not want for me to call time-out in a deposition to switch tapes and the fact that eventually my first was going to give out, having a back-up and eventually multiple seemed like the thing to do. Having a couple of friends film some sports events I could my mix radio play-by-play I could with dual camera angles was cool. This same-year model second buy had sat in storage; The original tape the who sold it to me with 10 minutes of footage came with it. I could tell the battery was so much stronger after a full charge than my old one, but this newer D250 has maybe had 1/10 the recording time as my original. Whether listening to the camera speakers, piping the sound from the rear A/V jack or importing via firewire, it's the same. The video may not be perfect and may "spark" or "flicker" in unison with the audio that drops out,but not always. At times, the video seems just fine but the audio drop-out is akin to a loop and I could probably time it, which was what I termed as cyclical. Could one of my friends have dropped it or tipped over a tripod and not told me? Sure, but I would think they would have told me. One night, follow some high school hoops I was importing, excited at the prospects of some two camera angles mixing. Thought I may have had a bad tape, but ruled that out right away through trying multiple tapes in bother cameras. Apologies for my loquacious follow-up; I suppose if worse comes to worse, I could check eBay for a secondhand model. I've "misplaced" my original, but it will turn up; it's simply a matter of desiring to import all that footage, since 2008, with superior editing software and skill than what I possessed when doing so initially. Thanks so much!
Apr 13, 2014 | JVC GR-D250 Mini DV Digital Camcorder
See all JVC GR-D250 Mini DV Digital Camcorder Questions
JVC GR-D250 Mini DV Digital Camcorder Logo
94 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
