Question about ASUS P5LD2-VM Motherboard
First time connecting SATA hard drive to this motherboard - do I need special drivers?
I am replacing my old 40GB drive with a Maxtor 160GB SATA hard drive and need to know if I will need a special driver to have the motherboard recognize the new Maxtor? I am using Windows XP Professional and according to the Maxtor manual, I will need a SATA driver from ASUS to be installed during the Windows installation. The Maxtor manual says to boot from the Windows install CD and then when prompted by Windows installer to install a third party SCSI or RAID driver, to press the F6 key and then the S key to specify additional devices. At this point I am to insert the SATA driver floppy and follow the on screen prompts. Sounds good but when I go onto the Asus website - I find no SATA drivers for this motherboard! What would you suggest I do?
Make a driver floppy disk with the asus cd
Posted on Oct 01, 2007
    President:
  • 2,961 Answers
Go to the bottom of this link and the ata/raid drivers are what you need http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Apr 10, 2007
  • andrew pester
    andrew pester Apr 10, 2007
    Update, sorry, that link doesn't work you have to put in your board model and drivers it is the bottom one
    Problem Solver:
  • 10 Answers
You shouldn't need any drivers- as long as the drive shows up in BIOS and looks correct- windows will load the drivers you need to make it work. Then when it's running - load the chipset.inf driver and the LAN driver from the motherboard CD. This will get you on the internet so you can go to the ASUS site and download all the new drivers (Including the newest chipset and LAN drivers)
Posted on Nov 01, 2007
Can I put in my PC Compaq Presario SR 1610NX a Hard drive Maxtor 40GB, 3.5 ? Thanks
Desktop Specs Link Motherboard Specs Link
A. From the first link above, you already have a 80GB 7200rpm hard drive and a combo drive with no further details. you can only use two additional devices one 3.5 inch external and 5.25 inch external bays.
B. Assuming that two devices are already IDE devices, that will leave you two additional IDE and two SATA device.
1. Turn off your computer before plugging any additional device and proceed with cautuion.
2. Add the additional 40GB Maxtor IDE hard drive, you will have to mount the drive into the casing and put some screw to lock or use tool lesslock if its present. (Check the jumper if its a master or slave) if you have configured the 40GB drive as master and you're going to add additional IDE drive you have to put the jumper in slave header.
3. Now put the IDE cable to the hard drive and to the IDE2 of the mother board mount firmly. (you cannot mount the IDE cable if it is in the wrong position)
4. Next the four pin power from the power supply to the hard drive. (you cannot mount the power cable if it is in the wrong position)
5. Power On your computer and press Delete or F2 to access bios, proceed to the option boot priority select your Combo drive as first boot, next your 80GB Hard driver, press F10 save.
6. Power On your computer and check your 40GB hard drive through device manager.
7. Time to add your new hard drive through disk management, so you will be able to see your new drive from your computer. I forgot how WIN XP recognize new hard drives especially the fresh one.
Hopefully this information helps.
Feel free to ask, so I can clarify things.
Thank you for using FixYa.
Sep 05, 2011 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
I wish to upgrade my Maxtor 32049H2 HDD (20gb) to a Maxtor DiamondMax 10 6B300S0 (300gb) HDD, The KM400-M2-3.0 Motherbourd specs indicate that the HDD is compatable other than the cabling to the Newer...
The new HDD uses a SATA data interface as well as a SATA power interface. You will need a SATA cable as well as a power supply that supports the SATA power connectors. Since this is an older machine you will probably need to buy a SATA cable and a Molex to SATA power connector. This should cover any cabling issues that you are having.
May 05, 2011 | EliteGroup KM400-M2 Motherboard
Acer vt7500 with a s88m motherboard and xp pro The hard drive(40gb) is failing and I would like to know what I could replace it with (ie. largest size) and install xp. I do not need to save the old...
Your 40GB drive is an IDE ("Integrated Drive Electronics") drive.
The largest IDE drive ever manufactured is 500GB.
However, some motherboards do not support drives larger than 320GB.
Some disk-drives (Seagate/Maxtor) come with a CD-ROM of "tools" that enable you to copy "everything" from your "old" drive to your "new" drive.
Oct 26, 2010 | Computers & Internet
SATA Hard Drive Type The Dell Optiplex GX280 Takes?
It makes no difference providing the computer motherboards support SATA interface.
SATA 1 and 2 drivers are in the BIOS. If all the computers have SATA 1 you can upgrade the BIOS to latest version via Dell's support website.
Regards.
Jul 08, 2010 | Dell OptiPlex GX280 PC Desktop
Install driver of maxtor 160gb onetouch 4 mini
Hmmm What software do you need?
You should not need software to run the HDD. Just plug it in.
You can get the One Touch software from Seagate (who no own Maxtor) See
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot4-downloads&vgnextoid=0ed72c9e46914110VgnVCM100000f5ee0a0aRCRD
HTH
Dec 08, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Installing an ide in a vista sata
Some of the laptop/s and desktop/s with IDE hard drive is not being supported by the Windows Vista. No matter you did already updated the BIOS still it will not fix the issue. If I we're you, have another SATA drive not and IDE one.Thank you.
Oct 05, 2009 | Computers & Internet
Longer Boot time after upgrading the Hard drive
first let's determine if the upgrade cause the boot speed.
Disconnect your NEW HDD and/or memory, one by one and see if you get back your fast boot. Then try with your NEW components only !
If you find it works better with new components only, then first connect your OLD HDD only and try.
If you connect both HDDs on one cable, check Jumper settings for both HDDs (Master/Slave).
Also HDD capacity and type is automatically detected by the BIOS and there is no need to put/change those settings manually.
I believe you new RAM is DDR type, too!
As written in the manual for the board, your motherboard has two pairs of memory slots, and you can use one or two modules of DDR memory, OR one or two modules of SDRAM memory, but you can NOT put BOTH DDR and SDRAM memory modules.
regards.
Apr 22, 2009 | Computers & Internet
Msi pm8m-v series micro-atx mainboard is not detecting 160gb seagate sata harddrive
Had u properly connected the driver to motherboard..?
U can change the sata cable. Check the power connection also.
Jan 19, 2008 | MSI PM8M-V Motherboard
ASUS P5LD2-VM Motherboard Logo
8,501 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
