Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WMA42 I was using the machine, there was a bang and the electrics tripped. Now no lights or anything. Could it be the brushes in the motor?
  • Hotpoint Master
  • 3,463 Answers
Hi there .
Yes ,it more than likely is the brushes in the motor, or a faulty heater element.
Access is by removing the lower rear panel, there you will see the motor and element.
You can test the heater in situ with a meter, but you will have to remove the motor to check the carbons.
With it tripping your electrics, there is a distinct possibility that it will have blown the board in the top of the washer.. To check this,
Remove the dispenser and undo the screws, remove the 2 top screws located behind 2 plastic covers at the front of the top, and remove top cover.
With the selector dial in the off position, slide the console panel to the right and ease forward.
There you will see the board. Spring the plastic retaining lugs back that hold the board in place ,and ease the board out..You will then be able to see if it has blown, look at the right side.
If it has blown , then you will have replace it, as they cannot be repaired.
Hope this helps you solve your problem.
Plz rate my solution.
Thanks.
Posted on Dec 23, 2008
Fabric softner not draining away on my hotpoint aquarius
take out your soap draw and in side there on the top you will see all black gunk that need cleaning i use a toilet brush with hot water ok
Oct 19, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
My washing machine it tripping the mains board out, changes plugs and sockets and its still doing it - any ideas? perhaps the bushes?
sounds like water is getting into the electrics....or your trip circuit has became week...try switching the trip switch from another circuit.
Jul 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Wer is the brushes in a hotpoint aquarius extra as it wont go in2 a spin
YOU WILL NEED TO REMOVE THE MOTOR FIRST TO SEE IF THE BRUSHES CAN BE REPLACED AS SOME OF THE MOTORS FITTED WERE SEALED UNITS. 15 MINUTES TO REMOVE THE MOTOR. BRUSHES ONLY ABOUT £25
Jun 22, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
Dec 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washes but does not spin
I AM NOT A MECHANIC, BUT IT SOUNDS LIKE YOUR MOTOR COUPLING NEEDS TO BE REPLACED.
May 13, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wma42. drum not turning, brushes changed last november, have tryed a new motor twice still not turning... suspect pcb. what do you think.
Pcb is a distinct possibility but would check loom from board to motor as i have found many broken wires on wma series.
Hope this helps & thankyou for using Fixya.
Feb 20, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WM51 Washing Machine keeps tripping the electric
I had this problem; it was the motor arthing out on the body. It took a repair man half an hour to sort and it cost me £35. Hope this helps. Domo.
Jan 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WMA42. I was using the machine when there was a bang and the electrics tripped. I reset the fuse box, checked the plug fuse and the socket but still nothing. No lights so presumably no...
It more than likely is the motor that has shorted. Remove lower rear panel, remove belt. Undo 2 screws that hold motor in place, remove motor plug, lever motor back to remove same,
Remove carbons and check for wear, also look at armature and see if there is any sign of shorting, clean armature with emery paper, fit new carbons, refit motor and belt, test.
If it still does not work, then in all probability it will have blown the main control board.which would require replacing.
Dec 23, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
