Question about Hotpoint Aquarius WMA56 Front Load Washer
Dirt and grime always building up around door seal
This is a very common problem with a lot of users, it is mainly down to the way you are using your washer.
The most important factor is that you are probably doing a lot of low temp washes,eg:40oC.
This does not let the wash powders and detergents to work properly at these low temps, so consequently you get a build of slime and grease and bacteria which is actively growing.
At least once a month depending on how often you wash, do a 90oC hot wash with powder in, but no clothes in.
This is called a maintenance wash, and most manufactures are recommending this now in the user instructions.
The other thing to do now before it gets any worse, is thoroughly clean the door seal and glass with a scouring pad or steel wool pan scrubber you will not hurt the door seal by doing this, and remove as much of the grease etc that you can, pull back the door seal and get inside where you normally can't see.
You will find that the seal will be stained, but as long as you get off the worst, it should be o/k.
Hope this helps solve your prob.
Plz rate my solution.
Thanks, and a merry xmas.
Posted on Dec 23, 2008
Apr 27, 2014 | Tecumseh Garden
on Apr 04, 2011 | Dishwashers
May 17, 2012 | Samsung Refrigerators
Aug 27, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Aug 22, 2011 | Jenn-Air Refrigerators
Oct 27, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Nov 16, 2009 | 2003 Volkswagen Passat
Oct 02, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Oct 01, 2009 | GE GTS22WCP Top Freezer Refrigerator
Feb 19, 2009 | Hotpoint WMA40 Front Load Washer
310 people viewed this question
build up slimy dirt round rubber seal on WMF720 Aquarius
build up of slimy dirt round rubber seal
