Question about SanDisk Sansa e260 MP3 Player
Major damage on my sansa e260
Hey y'all i realy need help.. my sansa is completely out cold... i was told to upgrade it, i did it but afta that my sansa won't go on any more.. evn when i plug it in the computer it does not show but it starts charging.. the weel is blue and the screen is black...PLsssss i realy need help
  • Abdoulaye Balde
    Abdoulaye Balde Apr 11, 2007
    i tried that but it still doesn't show on my computer..
    the first time i tried it worked but when i removed the usb cable the screen just went black.. and now when i put it on only the weel becomes blue... and it stil doesnt show on my computer even in recovery mode
No it did not work
Posted on Jun 18, 2008
2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downl... 7. execute the application while in boot mode
Posted on Apr 11, 2007
SOURCE:
My computer is not recognising my sansa 4.0.gb
You should make recovery mode on your player then make firmware upgrade.
The recovery mode:
1. On your Sansa player, press and hold the Power/Menu button for 15 seconds to turn the device completely off.
2. Slide the Hold switch so the orange portion shows.
3. On your PC, double-click My Computer
4. On your Sansa player, press and hold the REC button while connecting it to the PC.
5. Release the REC button when a 16MB-FORMAT drive partition appears under My Computer.
If this work, this link helps you to upgrade:
http://kb.sandisk.com/app/answers/detail/a_id/306
I hope I could help.
Feb 11, 2011 | SanDisk Sansa e260 MP3 Player
Hi! My Sansa e260 won't turn on. It charges
try upgrading the firmware...if that doesnt help u'll need to replace the battery here's how to update firmware- http://kb.sandisk.com/app/answers/detail/a_id/306
Aug 14, 2009 | SanDisk Sansa e260 MP3 Player
Where can i get sansa e260 mp3 player driver?
You need to make sure you are connected to a 2.0USB port if your computer is not IDing it try a friends computer or a labtop...Download the sansa update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe).
to a flash drive so you can download it to the friends com or lab...Make sure it's in msc USBmode in settings...Then try with your computer;......
Jun 07, 2009 | SanDisk Sansa e260 MP3 Player
I think that my sansa e260 have a virus, which could be the solution?
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....IF that doesn't work try to recover...download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Star the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
May 02, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 problem
Either your earbuds are damaged or the headphone jack was damaged when you were working out or storing your player.
Your best bet is the warranty, or if you're skilled enough, a good set of miniature screwdrivers and a soldering iron. Also be sure to have some kind of dry cleaning solvent or some isopropyl alcohol and somekind of applicator to clean with.
Open up your player( 4 screws on your backp[late, and 4 more at the corners once you're inside). Once you have everything unscrewed, gently, pry apart the inner workings from the front plate, and then the rear cover.
Now you should be able to look at the headphone jack and notice two solder points attaching it to the ckt card at either side. inspect either point for corrosion or damage and repair as necessary. While you're at it, go ahead clean out anything else that needs cleaning and before you put everything else back together.
Remember when cleaning to be patient and smooth, as any kind of rushing may damage the inner workings of your player.
Jul 29, 2008 | SanDisk Sansa e260 MP3 Player
How to restet my sansa e260
Menu - Settings --> Reset All
This option will reset all the Sansa e200 player’s settings back to
factory defaults.
Jun 11, 2008 | SanDisk Sansa e250 MP3 Player
E260 Vista SP1 Drivers
You should be able to access it as a flash drive straightaway; yes, the Sansa.com site has drivers on it.... But keep searching the web on
  1. Vista SP1 Sansa Drive Mount
...and try changing the Sansa between USB modes.
May 31, 2008 | SanDisk Sansa e260 MP3 Player
My mp3 a sansa e260 player may have been corrupted and am told by the peaple a real help that i may need to format my device inasmuch as we have tried absolutely everything on their end.
To reformat:
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
May 28, 2008 | SanDisk Audio Players & Recorders
PC cannot detect Sansa e260
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Apr 20, 2008 | SanDisk Sansa e260 MP3 Player
White screen every time
have you tried to call sansa yet? its a pain and you have to go through a couple of people before getting someone who knows what they are doing, but a phone call or looking on their website might help?
good luck
Mar 13, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
51 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
