Question about Whirlpool Duet GHW9150P Front Load Washer
I need to reset duet washing machine to open the door
I unpluged and nothing works to open the pump just runs...
I have a Whilrpool Duet washing machine, model: GHW9100LQ1
Type 199-AWM075/BL It works perfectly all the cycles, but every time it must start a new wash load, I have to unplug and plug it again to start a new cycle and works perfectly. There is no flashing numbers o letters. I changed the CNTRL-ELEC part, code 8182221 and that part was not the problem. The machine still does the same. Please, could you be so kind and tell me what part is cousing the problem- reseting every time I do a new load by plugging and unpluggind- Looking forward to your kind reply. Thank you!
Posted on Dec 24, 2008
  • elhatillo Dec 24, 2008
    President:
  • Whirlpool Master
  • 2,651 Answers
????? your pump just runs??? is it pumping water???if you rermove the lower aceess panel(3 screws across the bottom) youll gain acess tot eh pump clean out, perhaps its clogged , not pumping any water out
Posted on Dec 23, 2008
I have an arrow code f 26 on my duet washer
Drain pump triac failure This error code is displayed when the main electronic controller fails to detect the triac that controls the outlet drain pump during the wash cycle.
  • Check pressure switch contacts and connectors
  • Failure of the pressure switch or level sensor can also give rise to this fault code
  • Run test program
  • If failure persists after test and verification of pressure switch, replace main controller
Dec 27, 2013 | Whirlpool duet Washing Machines
Duet front load washer door locked & will not cont wash cycle
you can use a wet dry shop vac and attach it to the end of the drain hose and remove all the water in the unit this should unlock your door then you can check the drain pump for anything that may be restricting or blocking the drain pump
Jun 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool duet washing machine. We had a
Unplug the machine.
Remove the lower front panel.
Reach your arm up inside on the door latch side. Feel for a pull ring and pull it to release the door.
Feb 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The control lock light is on. The machine will not work. I tried unplugging it for 1/2 hour hoping it would reset. Whirlpool Duet Washing machine
The door will have to pried open and door switch will have to be tested or replaced. You can use a multi-meter or ohmmeter.
Worst possible cause is faulty eprom or control board but usually is faulty switch or door sensor.
Jun 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet ht, motor running but nothing happening, says 48 mins to go, cancel does not work. Have unplugged but will not reset. Left over night unplugged, stiil not reset. Cannot open door to even get...
Our Duet washer (5 years old) would not pump the water out, and would not spin. It displayed no error codes. Tried reset, would cancel but still not work. I started disassembly (found the Whirlpool maintenance/ repair manual on line to refer to); everything seemed to check OK. Cleaned filter, fortunately the washer sits on a pedestal drawer as the washer had at least 3 gallons of water in it I had to drain into a bucket. As I went through the diagnostic test sequence found in the repair manual it was apparent that although the pump had power and made noise, no water pumped out. I removed the pump assembly and found the remains of a small plastic baggy fouling the pump impeller. It was left in a clothes pocket and run through the washer. No idea why the filter basket didn't stop it. Pulled baggy out with needle-nosed pliers and presented it to my wife (her baggy). Reassembled and all works great. No cost, actually made 1 cent on the penny found in the filter basket. You need a Torx screwdriver to access most of the panels. Reason for not spinning was the massive weight of wet towels and water sitting in basket.
May 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Canceled the clean washer cycle, got "INT", won't work now
Unplug machine, wait 2 minutes and re-plug. This should reset computer and unlock door.
Mar 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HOW TO FIX A F01 ERROR ON MY DUET HLT WIRLPOOL WASHER
hi my name is joyce
Did you try to unplug the unit for 60 secounds and replug it back up?
do this and see if this works. then reset the machine's cycle, you are in the middle of cycle I usually push pause cancel and wait till the door beeps and then I can open it. but if this does not open the machine do the unplug and reset method. if this does not work please let me know.
thanks,
joyce
Feb 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet sport washer door will not open
without complete f code hard to pin cause but suspect pump not pumping out remove bottom cover reach up to lock area pull small tab down to unlock door remove as much water as possible remove pump clean out by turning counterclockwise clean pump and connecting hoses reassemble and ck
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Paused. now stuck. cannot open, turn off, etc.
Unpluggin the machine is pretty much the only way to reset it.Leave it unplugged for a couple hours if that doesnt work its most like a control board issue
Mar 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
485 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
