Dell Dimension E520 PC Desktop Logo
Posted on Dec 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cd drive i try 2 burn a cd but it want catch the cd in tha drive.
Anonymous
Level 3:
Guru:
  • Master 558 Answers
  • Posted on Dec 23, 2008
Anonymous
Master
Level 3:
Guru:
Answers
558
Questions
16
Helped
218337
Points
1386
You mean to say the CD/DVD rom is not working?
Make me clear if the CD is not burning or it is not opening at all.
Check out and try with a new CD. Dont vote till you get satisfied with the reply.
Whenever I try to burn a cd in my DVD ram a message shows up saying it is not accessible, Incorrect function.? What do I do? ive tried to disable and enable the drive then reboot the sys., still the same...
try running the fix-tool provided by Microsoft on this web page
http://support.microsoft.com/gp/cd_dvd_drive_problems
If that fails then my suspicion is that either
1) the drive has failed
or more likely
2) because you don't have any DVD burning software, windows can't understand the blank DVD-RW disk. Thas basic packet-burning software installed with XP CANNOT write to DVD disks.
However there is a bit more to it than that - the Microsoft CD burning software (which is a cut down Roxio product) cannot co-exist with any other packet burning software (e.g. DLA, In-CD or simuilar) so if one of those is installed you have to DISABLE the MS CD burning capability on the drive settings tab. Even worse, Internet Explorer 8 is not compatible with DLA - which is included in quite a few CD/DVD suites including many of the later Roxio versions
My advice would be
1) un-install any CD or DVD burning software on the machine
2) disable the MS CD burning
3) run that Microsoft patch
4) Install some DVD burning software but DON'T install the packet writing software part of it
Note that after installing that patch you may also have to reinstall any DVD playing software
2answers
Disc stuck in dvd drive. tries to spin. won't eject. (emachines desktop with xp home
There is a small pin hole below the tray. Straighten a paper clip and gently push it in this hole. The tray will unlock and pop out slightly, then pull the tray out and remove the DVD disc.
I am unable to format CDs - the system just
Take a can of air and blow some into the drive. This will make sure that no dust or dirt is interfering on the laser.
If after you do this the drive is still acting up, then that means the drive is bad and would need to be replaced.
Won't read mp3 and wma cds
The discs were not "finalized" or "closed" - place the cd's back on your computer cd-rom drive and search the help file of your CD burning software and search for "closing disc" or "finalizing disc." Some programs will allow you to close or finalize after you have already burned them, but others (Sony SoundForge is one exmaple) will not allow it - you may have to re-burn the discs and select the option that says "close disc after finishing" (this option is usually left unchecked by default, because closing or finalizing a disc prevents you from adding any new information to the disc).
-Tha Mp3 Doctor
I tried 2 burn a cd and the drive want catch the cd
If you are using XP then try installing the free version of Deepburner from
http://www.deepburner.com
and then try to burn a CD with Deepburner.
I had a similar problem and (mysteriously) the problem disappeared after installing Deepburner. After that I could use any burner program that I wanted.
CD Burning gets stuck
Try this: : Decreasing the burn speed If the drive is not recognizing the disc at all, skip to Step 4. Decrease the CD writer's burn speed by half to increase the likelihood of a successful burn. Decreasing the burn speed is a quick, easy way of increasing successful disc burning sessions, at the expense of taking more time to create a disc. The following steps are for Windows XP only. For Windows 98 and Me, decrease the write speed from within the software that you are using to write discs (RecordNow, Easy CD Creator)
  1. Click Start , and then My Computer .
  2. Right-click the drive icon, and select Properties .
  3. Select the Recording tab and reduce the Current Write Speed by half (for example, from 16x to 8x).
  4. Click OK and close the My Computer window. Try burning a CD. If the drive fails to create the CD, go to the next step.
Step 4: Setting up disc recording in Windows XP If the computer does not have Windows XP, skip to Step 6. If you are using Windows XP, use the following steps to ensure that native burning is enabled:
  1. Place a blank disc into the drive. NOTE: If the error <drive letter> is not accessible. Incorrect function. " opens, close it and continue using these steps to correct this problem.
  2. Click Start , and then My Computer .
  3. Right-click the writable drive icon, and select Properties .
  4. If a Recording tab is shown, select the Recording tab, select Enable CD recording on this drive , and then click OK . Try burning a disc again. Continue to the next Step if you are unable to burn a disc. If a recording tab is not shown, continue using these steps. Figure 2: Enable CD recording on this drive c00368150.gif
  5. Look for a Recording tab: If the Recording tab is not shown, Windows XP has not detected the drive as a recordable device. Use the following sub steps to enable the Recording tab:
    1. Click Start , Run , and type regedit in the Open field.
    2. Backup the registry: Select My Computer from the list, click File , Export , type a name that you will remember, and click Save .
    3. Click OK , and browse to the following registry key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\Drives
    4. Click the Volume key that matches the CD/DVD drive that is capable of writing discs. If only one drive is installed, one volume key is listed. If you have more than one drive, examine the data values (by double-clicking them in the right pane) to find the correct drive.
    5. With the volume key selected in the left pane, double-click the Drive Type value in the right-pane. Figure 3: Drive Type registry value (CDRW) c01367502.jpg
    6. Type the number 1 in the Value Data field if the drive is capable of recording to CDRW discs (including CD-R discs). Type a 2 if the drive cannot write to CDRW discs but can burn CD-R discs. NOTE: A value of 3 indicates that the drive is only capable of reading discs. Changing this value to a 1 or 2 enables Windows to view the drive as a recordable drive.
    7. Click OK , and close Registry Editor.
Burning to a CD
As long as the Mp3 file has burn rights, then you can do it. Windows XP and up, on many PC's, has native CD burning software. If your computer does not, then you can get Roxio or Nero's CD burning software online (not free) - it will contain detailed instructions. Microsoft's website has detailed instructions for burning files to CD. If the burning fails, it is because the songs you are trying to burn do not have "burn rights".
-Tha Mp3 Doctor
Cd burner quit working properly
Just a thought! Check your hard drive is not out of space as it may be having buffering problems..
1helpful
2answers
Toshiba DVD-ROM SD 6012
Im sorry to tell you this my friend.. it seems I catch you a bad time but I suggest that you need to replace it with a new drive since CD/DVD writers has its life span limit.. Be careful in doing burn CD's especially if its in long hours since it tend to damage the lens of your drive because of too much heat that was prolonged in a long run.. If your'e using it as DVD ROM at the same time, I suggest that you must have another drive to minimize damage to your drives..
Philips dvd burn not burning?
1. see to it that you have set your burning software to write to the disk.
2. try to use it on a cd, if it finishes the job, something is wron with your dvd drive.
3. make sure that the drive you have is really a dvddrive and not a cd drive.
4. upgrade youe burning software.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
