Question about Toshiba Satellite A105 Notebook
How to get audio by connecting pc to tv using hdmi
I have a acer 6920 laptop .i use hdmi to hook up laptop with my TV to watch blueray movies from my laptop on to tv screen but when i play online movies on internet on to a tv its not gonna work through same connectivity. pls help
    Scholar:
  • 141 Answers
In your internet option and the menu advanced, you've got a sub-menu "multimedia" ,disable the box with "play sounds in webpage"
tell me if it's works.
cheers
Posted on Jan 05, 2009
Acer support
Use the VGA and set the TV to VGA as well.
Oct 15, 2012 | Acer Aspire One D255E13438 Netbook
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
Connecting an Acer 6920G to a LCD TV
Unfortunately, DVI doesn't support audio. Your headphone output may work if you have a PC audio input on the TV. However, you might need to change the audio output on the Acer 6290G. It is probably defaulting to using the HDMI audio output.
Go to the Control Panel (click on Start). Select the Hardware and Sounds section. In Sounds, look for Manage Audio Devices. Change the Default Audio Device to a different Audio device (look for Output in the description). Note: you may need to turn off the computer and TV and turn them both on for the headphone jack cable to be identified.
If this doesn't work, check the manual for the TV. It might only have the PC audio connection available for a VGA port. Please add a comment with the TV model, if you need assistance with this step. Make sure that you aren't connecting the headphone out of the 6920G to a headphone out on the TV.
I hope this helps.
Sep 07, 2017 | Acer Aspire 6920-6422 Notebook
I have the aspire 6920 i bought a cord to connect laptop to the tv either with a SD video cable or RCA but either one i try i still get the message, that there is no other display device.. any suggestions?
Where does the error show up? on your TV or laptop? I hooked up my laptop with a DVI connection to the TV. I had to use the TV remote and select the right input from the laptop.
Apr 13, 2009 | Acer Aspire 6920 Notebook PC
No signal input when connecting PC to LG TV via HDMI
Do you also have a computer monitor attached to the computer when attempting to use the HDMI?
Mar 29, 2009 | Acer Aspire m5640 PC Desktop
Connect my 6920 to tv or through foxtel
Hi the 6920 may have a HDMI out(mine does) if not Maplin are selling a PC to TV box, it converts VGA to AV signal (£30) hope this helps
Feb 21, 2009 | Acer Aspire 6920 Notebook PC
Cant play blu-rays on lcd hdtv connected with hdmi
The software playing the bluray disc (PowerDVD) will only play it on the primary display. You will have to set your tv to be your primary display in order to watch the movie.
This only happens with bluray and HD-DVD discs.
Dec 06, 2008 | Sony VAIO Notebook
Acer 6920 hdmi sound output
An HDMI cable carries audio and video. Connect the HDMI cable to the cable box and to the tv. Make sure you then select the HDMI input on your TV. Also, make sure the internal audio is turned on in the Samsung TV settings. If all is setup correctly and you still have no audio try using a different HDMI cable.
Nov 29, 2008 | Computers & Internet
Acer 6920. no hdmi output. error code 0122
The Acer 6920 cannot show a movie on both screens at the same time. You must choose one or the other (the TV or the Laptop screen) NOT both.
Aug 22, 2008 | Computers & Internet
Toshiba Satellite A105 Notebook Logo
659 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
