Question about HP Compaq Evo Notebook N600c
View fies in my hardisk when windows does not load
I have a "Non- system disk or disk error" due to which I'm forced to format my harddisk before reinstalling windows using the restore CD.
But i want to check to see if it has an files which need.
Any suggestions on how can do this without windows and starting from the 'C:\>". I tried using 'dir' command which did not show folders inside my 'c:'.
I have accesss to a bootable CD drive attached to this laptop.
  • Brian Ebeling May 11, 2010
    when did this start to happen, the error i mean? does this happen when you try to boot or does it go into your o.s. and it comes up? what o.s. are you using?
  • 74 Answers
Well it sounds like you are booting with the cd however it's your harddrive that's having a issue.
Go into the bios and check to see if your computer see's a hard drive.
If you can't do that put the laptop against your ear and listen to see if you hear the harddrive spin up.
Either way you do not have access to c:\
The harddrive either died or someone might have dropped it or jarred it and somehow it came unplugged depending on the laptop or notebook you have.
Posted on Dec 24, 2008
Hello Sir, Vinoth here from chennai. I am using hp compaq nx 6115 for about 3 yr. now i am facing a regular problem in Hardisk. It is not detecting. So i bought a new Wester Digital hard disk 80GB, 6 month...
Check that your cmos mother board battery has not gone flat it should have 3 volts or more when tested .(it is a small coin sized battery on the motherboard not the actual laptop power battery) .this battery keeps the cmos time and settings if it goes flat then settings like time and enable disable and other functions can be affected
I hope this Helps
Andrew. A
Apr 01, 2011 | HP Compaq nx6115 Laptops
When i am connectind my portable hard drive with my laptop is showing only taksbar not showing in laptop harddisk pls send messeage
Try connecting it to another computer and if it also slows down, something is probably wrong with your external hard drive and you should get a new one.
Mar 01, 2011 | Maxell 665203 USB 2.0 Hard Drive
I keep getting the following error even after formatting the machine(windows xp sp3) "Non system disk or disk error, replace and strike any key when ready" ..if i insert an Operating System disk,...
Hello.
I suspect that your hard drive is faulty. If you formatted your drive, due to getting errors, this could be your problem in the first place.
I´d suggest running the hardware diagnostics (usually F2 or F12 upon boot) to see if that info is confirmed).
Hope this helps.
Jan 06, 2011 | HP Compaq nx7010 Notebook
Did not see second sata harddisk
To know if your Hardisk is detected follow this steps:
In Windows XP
1. Open Control Panel
2. Go to Administrative Tools
3. Open Computer Management
4. Double Click Storage
5. Open Disk Management
All the list of Hardisk is here, your hardisk is not formatted that's why, so you have to proceed to format just right click that unformatted hardisk and choose format, specify the label for your hardisk or simply leave it blank.
Jan 11, 2010 | HP dc7600 Small Form Factor P4 640...
Compaq deskpro 2000 error code 1780 disk 0 failure,how do I fix it?
first open cpu cover and reconnect both connection to hardisk. Like sata or ide and power cable.
Then check in bios .
When you power up the computer pressF2 or "del" or F5 to enter in bios setup then load optimal defaults.check your harddisk is proeprly detected in bios.
also if youi have sata harddisk then enable sata option in advanced .
then save settings and exit.
Thanks for using fixya.
Please rate solution if it helps.
Jul 23, 2009 | Computers & Internet
When formating progress error code "windows no disk" but the hardisk is still in good condition,
hi! system disk error,no disk on windows,check hard disk from your set up if your hard disk was configured by your computer, restart your compurter press F2 or delete depend how you start your cmos and bios set up,you can see this on left down corner of your windows when starting your computer,if it was there, this might have loosen connection of your hardisk i.d.e cable switch off your computer,disconnect your i.d.e cable just to refresh connection or replace if you have a new one,connect again make it sure it was properly connected,resstart your computer check if your windows will appear.if not reinstalling your windows might solve your problem you mention that your hardisk was good. ....regards
Mar 25, 2009 | Acer Aspire RC900 (91.PJB6P.UE7) PC...
MOBILE HARDISK IS 40 GB.HARDDISK PROBLEM IS DATA CAN NOT COPY FROM MOBILE HARDDISK OR PASTE IN MOBILE HARDDISK. HARDDISK SERIEL NO:-Q2KXOPE. HARDISK MANUFACTURING DATE:- OCT-06.
Maybe your hard disk is locked. Or kindly look at the properties of the Hard Disk see if the Read Only option is unchecked.
thanks
Mar 22, 2009 | Computers & Internet
My computer freez and go blank after formatting the computer
Greetings,
There is no problem with your computer as a whole it is your hardisk that has a problem, It cannot continue installing the system files because an error occur in your hardisk. Format your hardisk with other computer.
If you have an extra hardisk much better.
Thanks
Nov 12, 2008 | IBM NetVista PC Desktop
"Non-system disk or disk error replace and strike any key when ready".
If this error occurs you open the cabinet disconnected the harddisk data cable for few seconds and reconnected the harddisk data cable and bot it will work.
Apr 10, 2008 | Compaq Evo N610C Notebook
Seagate harddrive diskread error
go to bios and see there whether it is showing showing your hard disk or not if it is showing then re-install your XP again format your hard disk with the slow formating option,while re-installing it.
Nov 23, 2007 | Asrock GE PRO-M2 Motherboard
HP Compaq Evo Notebook N600c Logo
95 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
