Question about Samsung LN-S2652D 26 in. HDTV LCD Television
LCD TV randomly cycles through viewing modes
My new Samsung LNS2652 26" LCD TV randomly cycles through viewing modes. After roughly 20 minutes of viewing, the viewing mode switches to the next mode. For example, if I am watching in 4:3 mode, after some time (about 20mins) it will switch to 16:9. Or if I am in 16:9, it will switch to Zoom 1, or if I am in Zoom 2, it will go to 4:3. This happens regardless of where the input signal is coming from (ie- Component In from our DVD player or just the yellow Video Input) Can anyone shed some light on this? Thanks.
    Problem Solver:
  • 6 Answers
You could also check your controler..some controlers will do strange things as the battery is about to go out. a recently wet controller will also make circuits act up in the controler and hence..cause things to be changed on your tv. try this..turn your tv on.. hide your controller under a pillow in a very far away area from the tv..see if things change..if not. do what the man snakehead says...tech time. .
Posted on Apr 30, 2007
    Genius:
  • 1,074 Answers
Yea have a tech check your tv the microchip is faulty causing it not to be stable this chip is on a module.good luck
Posted on Apr 28, 2007
DO YOU HAVE a manual for a woods e227659 TM-068-2 timer?
Woods TM-068-2
Indoor 7-Day Astronomic Timer
125V ac / 60Hz 15A / 1875W general purpose
8A / 1000W tungsten 500VA electronic ballast
15A / 1875W resistive 120V ac / 60Hz / 8,3A ballast
FEATURES:
• Up to 7 different programmable ON/OFF cycles, cycles repeat weekly.
• Programming fl8xibilify: u8hts fun on/off automatically at sunset/sunrise,
or at any programmed times you choose.
• ln Sunrise/Sunset programming mode, timer will automatically adjust the
programmed ON/OFF cycles to match current sunrise/sunset times.
• Timer automatically adjusts to daylight savings time
WARNING: TIMER IS INTENDED FOR INDOOR USE ONLY!
BEFORE YOU BEGIN PROGRAMMING THE TIMER:
This timer has in internal battery backup to save all programming.
  1. Plug the timer into wall outlet for 30 minutes to charge internal battery.
  2. After 30 minutes, unplug timer and press the RESET button with the tip of a toothpick or similar object to clear the memory.
TO SET THE CLOCK:
  1. Press SET. PRESS +/AUTO or -/RDM to set the current year.
  2. Press SET. PRESS +/AUTO or -/RDM to set the current month from 01 to 12.
  3. Press SET. PRESS +/AUTO or -/RDM to set the current date.
  4. Press SET. Daylight savings mode (DST) will appear on the bottom of the display. PRESS +/AUTO or -/RDM to set mode to either DST AUTO or DST OFF.
  5. Press SET. PRESS +/AUTO or -/RDM to set the current hour. To change between AM and PM, press +/AUTO or -/RDM 12 timers.
  6. Press SET. PRESS +/AUTO or -/RDM to set the current minute from 00 to 59.
  7. Press SET. PRESS +/AUTO or -/RDM to set the Astronomic function to your zone - North (nor), Central (cen), or South (sou).
  8. Press SET to view the sunrise time. To adjust sunrise time press +/AUTO or -/RDM. To go back to the default sunrise timer press ON/OFF.
  9. Press SET to view the sunset time. To adjust the sunset time press +/AUTO or -/RDM. To go back to the default sunrise timer press ON/OFF.
  10. Press and hold SET for 5 seconds to exit clock setting mode.
Note: The timer allows a maximum of 7 programmable ON/OFF cycles.
To program the first ON/OFF cycle: Press SET repeatedly to scroll through setting the clock mode.
  1. Press SET to display ON 1 setting.
  2. Press +/AUTO or -/RDM to select day or group of days you want for cycle 1. Scroll to select either every day, any individual day, weekdays only, or weekends only.
  3. Press SET. Set ON hour by pressing +/AUTO or -/RDM to scroll through and choose hour AM or PM, or Sunrise/Sunset icon for first ON setting. Note: To select Sunset or Sunrise for the ON time, you must scroll through all the AM and PM hours first. If you select Sunrise/Sunset as the programmed ON time, press SET to continue programming OFF setting.
  4. Press SET. Press +/AUTO or -/RDM to set ON minute from 00 to 59.
  5. Press SET to display OFF 1 setting.
Repeat steps 2-4 to program desired OFF time.
To program additional ON/OFF cycles: Repeat steps to create additional ON/OFF cycles (ON 2-OFF 2, ON 3-OFF 3, etc.) up to a maximum of 7 different ON/OFF cycles.
Press and hold SET for 5 seconds to exit programming mode. Note: During programming, if no button is pushed for 30 seconds, the timer will automatically return to standby mode. Press ON/OFF to cancel any setting.
Sun tracking technology: Timer adjusts automatically to changing sunrise and sunset times in sunrise/sunset mode is chosen for any programmed ON or OFF time. For example, if you program a cycle to turn ON at sunset and OFF at 10:00 pm, the timer will automatically adjust ON (sunset) time as sunset time changes throughout the year (and will always turn off at 10:00 pm as programmed).
IMPORTANT! REVIEW PROGRAMMED ON/OFF CYCLES: Press SET to advance through all programmed ON and OFF settings. Make sure there are no overlapping ON or OFF times. Stop at any programmed setting you want to change.
To operate timer: Press +/AUTO until AUTO appears in display. Timer must be in AUTO mode for programmed settings to operate. Plug appliance (such as lamp) into timer and plug timer into wall receptacle.
IMPORTANT: Appliance must be turned ON or be in the ON position before plugging it into timer.
SECURITY (RANDOM) MODE: To operate a plugged-in appliance (such as a lamp) in a random pattern while you are away, to simulate actual use: press -/RDM until RDM appears in display. In Random mode, plugged-in appliance will turn on and off at random, approx. +/- 30 minutes from the programmed settings.
To cancel Random mode, press ON/OFF until RND disappears from display. Timer will now function using your previously programmed settings.
DAYLIGHT SAVINGS (DST) MODE: If timer is in DST AUTO mode, clock time (and sunrise and sunset time) will automatically increase 1 hour on the second Sunday in March at 02:00 am and decrease 1 hour on the first Sunday in November at 02:00 am.
TO OVERRIDE THE TIMER: Press ON/OFF until desired mode is displayed:
ON: Programmed settings will be overridden; the plugged-in appliance will remain on
OFF: Programmed settings will be overridden; the plugged-in appliance will remain off
AUTO ON: Turns plugged-in appliance on immediately until the next programmed OFF time. Press ON/OFF until ON displays on the screen, then press +/AUTO and AUTO will display on the screen.
AUTO OFF: Turns plugged-in appliance off immediately until the next programmed ON time. Press ON/OFF until OFF displays on the screen, then press +/AUTO and AUTO will display on the screen.
RDM ON (Random ON): Turns plugged-in appliance on immediately until the next random off. Press ON/OFF until ON displays on the screen, then press -/RDM and RDM will display on the screen.
RDM OFF (Random OFF): Turns plugged-in appliance off immediately until the next random on time. On/Off times will vary +/- 30 minutes from the programmed settings. Press ON/OFF until OFF displays on the screen, then press -/RDM and RDM will display on the screen.
Consumer Support (800) 561-4321
www.colemancable.com
Dec 12, 2017 | Woods Hardware & Accessories
Lg w2234s-bn Monitor Cycling randomly through Light View Modes/Power Button turning It's self on and off.
On and off cycleing could be caused by a bad power supply or a low battery on your remote. Check them both out. Good luck.
Apr 28, 2012 | LG 22" FLATRON LCD Monitor
The tv viewing of TV shows and movies seem fake. The camera angles don't seem movie like but more like a video camera. What setting do I need on my 60" LCD sharp
Try cycling through all of the av modes by pressing the av mode button on your remote to see if you like movie or standard. You are most likely in av mode dynamic fixed at the moment.
Sep 20, 2011 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
MY 32" LCD PHILIPS KEEPS CLICKING AND SWITCHING ON AND OFF ON ITS OWN, ALSO THE REMOTE RANDOMLY STOPS WORKING
tomlyndlevjo, Possible failure of internal "switch-mode-power-supply" board in tv. Remote not bad or intermittant!!! SMPS board is detecting "fault condition" and goes into "shutdown mode" to try and "save itself" from catastrophic, nonrecoverable failure. e.g. sparks, smoke, fire!!! If warranty no longer valid option for you, then you or qualified electronics technician will need to investigate SMPS board to find cause as to why SMPS cycles in/out of "shutdown mode" 12fixlouie
Sep 13, 2010 | Philips 32PF7320A 32 in. LCD Television
New samsung 40 inch LCD. When in the wide mode
if you are watching cable or satelite, you need to change the screen format output from the source to make sure it matches with the TV
Jun 14, 2009 | Samsung LN40A550 LCD TV
Problems with the picture mode on my samsung 46''
Your TV is in DEMO-STORE MODE.
Go to menu, find Plug & Play option, start it, and when asked, select Home Mode, than Enter and than just Exit.
Enjoy Your TV!
Jan 09, 2009 | Samsung LN46A550 LCD TV
Samsung 20" sync master
I have the same problem and i think it's to do with the xbox because my wii works on the tv but my xbox doesn't, it says mode not supported. I heard that if you connect it to another tv then back to your old one,v it will work.
Aug 06, 2008 | Samsung LN-S2651D 26 in. LCD Television
My samsung lcd 40 inch tv resets itslef after about 20 minutes back to DYNAMIC mode after changing it to STANDARD or MOVIE mode...?
i had the same problem. i accessed the engineer menu. while the samsung is powered off, you press info, then menu, then mute and then power on. you will get a new menu and from there you pick the option block. here, you have an option for 'shop' mode. disable that. Voila. worked for me. should work for you unless a different problem.
Aug 04, 2008 | Televison & Video
Televison & Video Logo
123 people viewed this question
Jerry Greenberg
Jerry Greenberg
