Question about Ovens
Nardi FE46 electric oven short
I have a Nardi FE46, have used it for 5 years. I turned the dial on heat, it shorts the circuit breaker. What is wrong?
Where do I get a replacement light bulb for this unit and usually how much?
Thanks.
  • 700 Answers
It appears that there's a short in the oven. When you turn it on is when the short happens and in order to properly determine what is wrong then you are probably have to call a service tech./
Posted on Dec 23, 2008
My Creda Reflection double oven keeps tripping the oven fuse when I turn it on? It doesn't trip straight away, it works for a minute or so and then trips the fuse. Any ideas?
call an electrician to check the circuit insulation for shorts
could be vermin cooked across electrical terminals , failing insulation, grease /fat across terminals
dead shorts trip the breaker immediately, ground leakage problems take a little longer
May 07, 2017 | Creda Ovens
Why oven not heating
Bad element, bad switch or other electrical problem. You could double check switch by turning on broiler element to see if that
gets hot. If so then either oven thermostat, or element. Did the circuit breaker pop off and then you reset? So there is a short somewhere, especially if it happens again. The above test with broiler element could verify power to oven. If it pops the
circuit breaker again. You need a service technician. Usually the oven requires a dedicated wire to the oven. Don't use the oven again until the problem is resolved. There's a slim possibility
that the circuit breaker needs to be replaced. How long did you use the oven? If a long time circuit breaker is more likely because
when they begin to fail they get too hot and therefore pop. You will need an electrician to change the circuit breaker if that is the problem.
Feb 13, 2015 | GE JKP90 Electric Double Oven
Broil trips circuit breaker every time
I would start by replacing the breaker. They do become weak over time.
Dec 05, 2012 | GE JRP28 Electric Double Oven
We have a whirlpool double oven, model RBD245PDB12. Oven cooks well but, will not stay off, buzzes long and short intermittently throughout day and night flashing F2 code or E6.
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
: I offer free advice bcuz God is so good!
Feb 13, 2012 | Whirlpool Ovens
Went to switch oven on fan works when you turn the temp knob it trips the trip switch every time help
HI, Sounds like your from the UK
If you are referring to a trip switch as being equivalent to an American circuit breaker. (Electrical safety device designed to shut down power to an electrical appliance). Then we are on the same page.
Do the following diagnostic procedure:
1 SHUT DOWN THE POWER SUPPLY TO THE OVEN. I.E. THE TRIP SWITCH/CIRCUIT BREAKER.
2 Open the oven door and look very carefully with a flashlight at the heating element. Look at the the entire element. If it blew (similar to when a light bulb blows) you will
find white powder around the hole in it or it will be completely broken, or have bubbles in it. Some indication like that. If so it has failed and must be replaced. It is probably tripping the switch because it is shorting out somewhere. There is also the possibility that the internal wiring connectors to where the element is mounted into the oven walls is broken off and short circuiting against the oven chassis (walls). That being the case, it may be just a wiring repair in which you install new appropriate electrical contacts and re-connect the element.
Hope this helps,
Happy New Year,
Mark
Dec 31, 2010 | AEG B3101-4 Electric Single Oven
What does F- mean on my jenn air expressions electric wall oven? If it means what I think, then this is the 4th failure in 10 years. This just can't be right!
Common fault codes:
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
May 22, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Kenmore oven 790.95322303 went pop. After reset breaker outside gave me an F1 error code Can I fix it myself or do have to buy a new piece of **** oven that will last a whole 5 years?
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 06, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a Fagor oven 2H1261 model electric short circuit
try checking oven switch could be shorting or usless
Sep 29, 2017 | Ovens
Bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Dec 25, 2007 | Dacor ECS230 Epicure Electric Double Oven
Whirlpool Double Oven GBD307
there are three possible issues, one is a faulty ground. the computer uses ground to determine zero in binary logic. It could also be a stuck key on the input board, or the main control board. Check your owners manual, some units come with an exceptional warranty on the electronics. This is a big one and it may be worth your time to call a tech in to check it out. electronics are expensive and you can not send them back if you diagnosis is wrong.
Sep 24, 2007 | Whirlpool RBS245PDS Electric Single Oven
Ovens Logo
662 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
