Question about Microsoft Windows Server Standard 2003 for PC
I add the user, and set the password, then I get this error message: "Windows cannot set the passsword for (Username) because: the password does not meet the password policy requirements. (More)...
  • 827 Answers
The password does not meet password policy requirements because it is not complex enough.
You have to turn off password complexity so that the Control Panel is able to work if people add users with insufficiently complex passwords. To do this access "administrative tools" - "Local (Domain) Security Policy", then in this area, access "Account policies" - "Password Policy" and disable the password complexity check.
Or use a complex enough password?
Good Luck
Chris (ziraffa)
Posted on Dec 23, 2008
  • chris grams
    chris grams Dec 23, 2008
    It's probably best advice, though, not to modify your policy settings too much.. Try using a mixture of alphabetic, numeric and special characters. That'll keep the password within the domain policy's defined parameters, and you'll be able to get on with what you are doing! :)
    Chris (ziraffa)
  • 43 Answers
U must enter ur password in Alphabetic(A-Z), Numeric(0-9) & Special characters(. , @ _ -)
kkkkkkkkkkkkk
try this now.............
plz rate me tooo.......
2 Suggested Answers
ziraffa
  • 827 Answers
SOURCE: I add the user, and
Hi sathiamat428,
Good Luck
Chris (ziraffa)
Can't get logged in on windows 8
Follow the steps:
Requirements:
1 ) Windows Vista or 7 DVD
1. Insert the Windows Vista DVD into the DVD drive and then restart the computer.
2. Change Boot Options 1st Priority to Optical Drive.
3. When system booting up, if the message "Press any key to boot from cd" appears, immediately press Enter.
4. On Language Settings, Time and Currency and Keyboard Layout screen, just choose the correct settings then click Next.
5. On Install Now screen, click Repair. Note: Click No just in case you get the message: Windows found problems with your computer's startup options.
6. On the System Recovery Options screen, under Operating System, click Windows Vista then click Next. Then select Command Prompt.
7. At the command prompt windows, type the following command then press Enter after typing each command:
c:
cd windows\system32
echo ~takeown /f %1 /r /d y > TakeControlOf.cmd
echo ~icacls %1 /grant administrators:F /t
ren Magnify.exe Magnify.old
ren cmd.exe Magnify.exe
8. Restart the computer.
9. On the Welcome Screen, click the Ease button.
10. Check Make items on the screen larger then click OK.
11. At the prompt, type the command then press Enter.
net user Administrator /active:yes
exit
12. Restart the computer.
13.
At the welcome screen, logon using the local administrator account.
14. Access Control Panel then click User Accounts. Select the username of the account you can't login to then remove the password.
15. Log off on the current local administrator account your are logon to.
16. Check if you can logon to your user account now.
17. Open c:\windows\system32.
18. Right click on Magnify.exe, select Properties -> Security -> Advanced -> Owner -> Edit -> Administrators then click OK.
19. Select Edit -> Administrators -> Full Control then click Apply then OK.
20. Rename Magnify.old to Magnify.exe
21. Open command prompt then type the command then press Enter.
net user Administrator /active: no
To create a new user :
Net user username/add
Windows XP/2003, Vista and Windows 7.
To add a new user account to the local computer from command line:
net user username password /ADD
Example: To add a new user account with the loginid John and with password fadf24as
net user John fadf24as /ADD
To add a new user account to the domain:
>net user username password /ADD /DOMAIN
Note that we do not need to specify the domain name here.
Example:
net user John fadf24as /ADD /DOMAIN
Rename a user account from windows command line
We can use below wmic command to rename a user account from command line.
wmic useraccount where "name='username' " rename new_username
Ex: To rename the user account techblogger as win7techblogger
wmic useraccount where "name='techblogger' " rename win7techblogger
Net use command does not have any switches to rename a user account.
Few more Advanced uses of net user command.
To specify user full name while creating the user account
net user username userpasswd /ADD /FULLNAME:"User_Fullname"
To specify that the user is allowed to change the password
net user username userpasswd /ADD /PASSWORDCHG:Yes
To restrict user not to change the password:
net user username userpasswd /ADD /PASSWORDCHG:NO
To specify when the account expires we can use /EXPIRES switch.
To specify if the user must have a password set we can use /PASSWORDREQ switch.
How to create a new administrator account from command line?
An administrator account can't be created directly from command line. We first need to create a user account and then add the user to the administrators group.
Errors:
If you don't have privileges to add new user account to the system, you would get an error like below.C:\>net user John /add
System error 5 has occurred.
Access is denied.
C: \>
if cant able underatand send me your mail id..
Nov 10, 2013 | Computers & Internet
Tip
Creating users easily and quickly in windows xp
Creating users in windows xp:
Go to start, then run, type "cmd".
Here, you can type the following command to create a user,
net user "username" /add "password"
net user "username" /del "password"
example:
net user goodmorning /add *****
And also you can manage your user accounts in the user management option:
Right click the my computer icon in desktop, click "manage".
Here you can find "Local users and groups". you can create, remove,manage the users, and groups here also.
on Jul 22, 2008 | Microsoft Windows Server Standard 2003 for...
Live Mail - xtra mail login
As evident from the message, you are getting the error 0x800CCC92 in Windows Live Mail because the password you had entered is not correct. Or, in other words, the password provided to the email client does not match the account username.
Thus, to solve the Windows Live Mail error 0x800CCC92, you have to double check both the password and the user ID (username) you had supplied when the email account was set up. Please understand that in order to access your email account successfully, the login information has to be correct.
Oct 16, 2013 | Microsoft Computers & Internet
Windows security center
If this is your router and you've forgotten the username or password we suggest that the router be reset and then setup with a new username and password.
Default username and password
Before doing a hard reset on the router you may want to try the default username and password. While this is not the same for all routers, this may allow you access to your router.
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com
Sometimes when attempting to visit a secure website on your Windows computer, you will receive a message about a security certificate error.
You will have the option of whether to continue to the site.
Secure websites, such as an online bank or retail store, use security certificates so your browser knows that any financial or personal information you enter on the website will go the correct place securely.
Every error message does not necessarily indicate a security problem on the website.
Check your computer's date and time.
If they are incorrect, you will receive security certificate errors.
Click on the time in your taskbar, and set the correct time in the pop-up window.
Refresh the website where you received the error message.
If you receive a security certificate error message again, the problem lies with the website's security certificate.
Click the icon that looks like a padlock next to your browser's address bar.
Read the information in the window.
This will detail who owns the website, the site's verification status and any known information about the website's trustworthiness.
Compare this to what you know about the site you were attempting to visit.
Click "View Certificates, then "Install Certificates."
Click "Yes" at the security warning to install the certificate for the website.
May 20, 2013 | Linksys WRT Computers & Internet
How do I remove log in username
for which operating system ????
Windows XP users
Change password
  1. Open Control Panel
  2. Double-click the Users Accounts icon
  3. Select the account you wish to change.
  4. Select the option "Change my name" to change your username or "Create a password" or "Change my password" to change your password.
Note: Windows XP Home users can only change the Administrator password through Safe Mode
Windows Vista and 7 users
Change password
  2. Click Add or remove user accounts.
  3. Click the account you wish to change.
  4. Click Change the password
Change username
  4. Click Change the account name
Windows 2000 users
Change password
Microsoft Windows 2000 users can change their username by pressing CTRL + ALT + DEL while in Windows to open the Windows Security window. From this window click the "Change Password" button
Enter your old password and the new password you wish to use.
Change username
In order to change the username of an account on Windows XP you will need to have an account with Administrator rights. If you're logged in as Administrator or have an account with Administrator rights, follow the below steps.
  2. Double-click the Users and Password icon
  3. Make sure "Users must enter a user and password to use this computer" is checked.
  4. Highlight the account you wish to change the username for and click the Properties button.
  5. Within the Properties you'll be able to change the User name.
hope this helps
Sep 25, 2011 | Computers & Internet
How do I change my password
Hi to reset your password, please follow these steps --
1.  Open the internet browser of your choice.
2.  Enter 192.168.0.1 into the address bar.
3.  In the username field select admin
4.  By default the passsword is blank.  If you changed it when you previously setup your router, enter the changed password.
5.  To change the password used to login to  your router, click on Tools in the menu bar at the top of the browser screen.
6.  Under the Admin Password section, you can change the username and the password to login as an administrator.  It is suggested that you change the username and password of your router.
7.  Under the User Password section, you can change the username and password to login as a user.  Logging in as a user allows you to see the settings, however, you are not able to change any of them.
If you would like additional information, please ask.  Also, if you would like information on setting up your wireless, please post that question.
Apr 03, 2011 | D-Link DIR-615 Wireless Router
Hello where can i know my user name for DSL-2640T ? I NEED IT !! PLEASE CAN U HELP ME
Hi
There is 2 Usernames when it comes to Routers.
1st is the USERNAME and Password you use to get into the Router configurations which is the following.
Username: admin
Password: admin
The above username and password is the Factory setting and only the password can be changed by an user. SO if it was not changed the password will still be admin or you can reset the modem to reset the password back to admin.
2nd is the Username and Passsword you get from your Internet Service Provider which usually is the email address and whatever password you gave them to set your internet up
Feb 04, 2011 | D-Link AirPlus DI-524 Wireless Router
I have a Linksys WRT160N Wireless router and I had set a username and password, since I had to reset it the username and password I set will not work. I also tried using the username and password as...
Try leaving the username blank and just typing admin in the password. If you remember your old username and password try those too, You may not have saved changes.
Jan 17, 2011 | Linksys WRT160N Wireless Router
Hi sathiamat428,
Good Luck
Chris (ziraffa)
Dec 23, 2008 | Microsoft Windows Server Standard 2003 for...
Oracle 10g Error
You're using the wrong password.
Sep 10, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Microsoft Windows Server Standard 2003 for PC Logo
107 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
