Question about GE Adora DSS25KSTSS Stainless Steel Side by Side Refrigerator
Icemaker dispenses but clogs and makes clunking noise.
Our icemaker dispenses both crushed and cube but after a few seconds begins to clog. When it does it sounds like the worm is still turning, trying to advance the ice and there is a loud clunking sound. After we unclog the chute, it works fine for the next 3-4 times then repeats. We have the temp set at 4 on both sides.
    New Friend:
With mine, the ice crushing bearing blade rounded out on the auger shaft. That leaves too much slack in the blade system allowing an ice jam. This also puts stress on other parts breaking them this is a sorry design by GE coupled with plastic parts equals failure.
Posted on May 29, 2015
    Problem Solver:
  • 7 Answers
Try using cube ice only for a few days
Posted on Sep 02, 2012
SOURCE:
peyton32034
  • 410 Answers
SOURCE: icemaker makes ice; door dispenser cranks, but no ice dispensed
sounds like either the dispenser motor is bad or the dispenser yoke is stripped. remove the bucket from the freezer. you will see a u shaped yoke in the rear of the disp area. this should be fairly hard to turn by hand if it turns easily then the motor gears are bad if the yoke slips on the motor shaft then you have a stripped yoke. hope that helps. peyton...
Posted on Jan 22, 2009
SOURCE: Ice dispenser not working - GE side by side refrigerator
Check auger motor if getting power then probably motor gone , if
not may be switch. good luck
Posted on Nov 09, 2007
  • 65 Answers
SOURCE: Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Posted on Jan 27, 2009
peyton32034
  • 410 Answers
SOURCE: water dispenser does not work
most likely the water line for the dispenser has frozen in one of 2 places. the first place to check and the easiest is the water tank behind the crisper drawers in the fresh food compartment. what i would do is use a hair dryer to warm the tanke and see if it will start working again. the next place that is common for it to freeze is in the freezer door. the only way to fix this is to leave the door open for a while to allow it to thaw out.
If I'm not mistaken I think there is a recall for some of the  GE sxs refrig that addresses the water line freezing in the door. you may want to all GE and heck on that. good luck peyton
woodchuck789
  • 4070 Answers
SOURCE: Our GE Monogram Icemaker will only dispense crushed ice
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components
Posted on Aug 29, 2009
Whirlpool model # ed5vhexvq1 side by side ...ice maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
LG ice maker will not dispense cubes without crushing them
Check the evaporator system, that release the cubes, when that does not work the cubes stay stuck inside.
Oct 31, 2008 | Refrigerators
Icemaker not getting water
look inside the ice maker and see if the shut off leaver is stuck.
maybe a chunk of ice stuck in it. thanks for rating ;-)
Aug 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Icemaker is on cube but is still crushing ice it seems like it is stuck on crush,the light is on cube.
Nov 13, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Aug 29, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Water dispenser doesn't work
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 12, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Can not get cubes from the front, just crushed ice and water?
Hi
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 23, 2009 | GE Hotpoint 25.0 Cu. Ft. Side-By-Side...
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
May 15, 2008 | Amana Refrigerators
Whirlpool icemaker not giving cubes, only crushed ice
If less than a year old should still be under warranty
Sep 05, 2007 | Whirlpool ED2FHEXN Side by Side...
GE Adora DSS25KSTSS Stainless Steel Side by Side Refrigerator Logo
799 people viewed this question
Top Refrigerators Experts
Brad Goodale
Matt Sicignano
Level 1 Expert
JP Meneide
JP Meneide
