Question about Blaupunkt Nassau CR127 Cassette Player
Dead radio Hi, i have a blaupunkt nassau cr127 it was installed already when i bought the car, 1984 mercedes benz 300td when i bought the car, it worked fine. I notice the screen on the face dimming in a out when I play the cd changer in the trunk. I just had the cd repaired, and it works fine. to make it simple, i just installed a 400 amp amplifier, with 12" speakers, when i ran the hot wire to the battery from the ampl. the radio when out. so i pull it out and pull out the fuse in the radio, and it was not blown, so i put it back in, and the clock can on, and the radio was playing, but as soon as i touch the hot wire again to make the ampl work, the radio did not come on again. and now its out. i put a test light on the fuse part of the radio, and i know power is getting to the radio. please help soloman abercrombie24notary@yahoo.com thank you
5 Suggested Answers
  • 3 Answers
SOURCE: BLAUPUNKT CDC-A071 problems
if the radio is working ok its getting the rite current its more likley the unit is faulty
Posted on Aug 21, 2007
MJS_1
  • 150 Answers
SOURCE: Blaupunkt flattening battery
I would be concerned about the amount of current required to kill a car battery in a week:
Let's assume that 1 week = 24 * 7 = 168 Hrs
A typical, healthy car battery will deliver anywhere between,
45 to 70 Ampere-hours at small currents, depending on the
size of the car (check your car owners manual)
Assuming a weak battery has a 40 Ampere-hour reserve, it would require an average current of 250 milliamperes to drain
in a week, or about 3 watts of power.
While this does not seem like a lot, it certainly indicates
something is wrong, because the clock and station memory
in a radio should take a lot less than that.
The first step is to make sure that the radio is actually at fault,
not damaged wiring or another one of the dozens of electronic
systems in a modern automobile.
Don't trust your mechanic on this, I have never met a gear-head
that was any good in electronics, but they do come up with
some fairly captivating fish-stories when they do not
understand something. :)
1) The first step is to disconnect the radio and isolate the
problem.
2) Remove the radio and hook it up to a 12V DC supply,
or battery through a digital milliamp-meter. Check the
current with the radio shut off.
3) Anything over about 10 mA or so is BAD.
4) If the radio draws any significant current with the switch
shut off, look for a bad switch or a leaky capacitor on the
B+ wire (before the switch, so it should not be hard to find)
Another possibility is the clock/keep alive controller chip,
but this is less likely. The most likely culprit is probably
an old leaky capacitor (electrolytic or solid tantalum),
since these do tend to fail with age, vibration and extreme
temperatures in a car environment.
5) If the radio is at fault, you will need some knowledge and
electronic instruments to find the problem yourself.
A quick way to check an electrolytic or tantalum capacitor
is with an ohm-meter. Connect ohm-meter to the capacitor,
and watch the reading race to infinity as the capacitor charges
up. Then reverse the leads and watch it again. Once charged,
the capacitor should have infinite impedance.
6) If the radio is not at fault, it could be dozens of other
problems, ranging from the body control computer,
immobilizer, remote starter, parking lights, door-locks,
alarm system, bad wiring ... you name it.
7) You should be able to isolate it by measuring the battery
current, while pulling fuses one at a time.
8) Another possible cause is the battery itself, or a bad
(shorted) diode in the alternator. The best way to check
the alternator is with an oscilloscope, while the car is
running.
A bad diode will show up as a missing peak in the otherwise
regular pulse train.
9) Finally, don't over look the relays in the power distribution box.
These can over heat and stick in the ON position with the
ignition turned off.
Good luck, Martin
Posted on Jun 13, 2008
SOURCE: BLAUPUNKT GMDAT CDP 3 (E) - CAR RADIO CD HOW TO EJECT CD?
Hi graz,
If your unit has a SRC button to the right of the CD clot, try holding this down for a few seconds - works on mine!
Posted on Feb 28, 2009
SOURCE: i bought a blaupunkt san remo car cd-reciever on
Me too From Ebay can anyone help get these please?
Posted on Jul 02, 2011
Hi. Could anyone help with unlock code for mercedes benz audio 10 cd radio, model MF2910. Serial AL2**********3. I bought it as a single unit at a yard sale.
How to unlock your car stereo, Mercedes Audio 10 stereo ...
? 2:09
https://www.youtube.com/watch?v=WKCrhOEI41Q
Feb 26, 2010 - Uploaded by Marvin Flop
How to unlock your car stereo, Mercedes Audio 10 stereo ... I had already phoned my local Mercedes dealer for the radio codeof my ML270, .... Mercedes Benz Car Stereo Removal and Repair 1994-1999 - Duration: 4:00. by ...
MERCEDES RADIO UNLOCK CODE - ecoustics.com
www.ecoustics.com > ... > Car Security Systems Forum
Mar 10, 2011 - Please assist me with the radio code for the Audio 30 radio of the E240Mercedes benz. My vin number is WBD2100622B495524. Your help ... Need Unlock code for Mercedes Benz C200
May 9, 2015
Help unlock code Becker BE 3309
Dec 29, 2013
Jan 27, 2012
Mercedes radio code
Aug 15, 2010
More results from www.ecoustics.com
Dec 15, 2015 | Cars & Trucks
How to install aftermarket radio
installing radios into electronic controlled cars can be a real nightmare as the wrong wires used creates many CPU problems . Best have it installed by professional radio fitters at the shop where you bought the wireless and save your self a headache.
Apr 26, 2014 | 1992 Mercedes-Benz Mercedes Benz 300 Class
Blaupunkt radio
Probably take it to the dealership
Feb 08, 2014 | Mercedes-Benz Cars & Trucks
How do you manually raise a broken 1987 mercedes 300td rear window with a dead motor?....the switch works fine.
Get a new motor and replace. Without external means to hold window up it will not stay up with motor off.
Sep 19, 2010 | 1987 Mercedes-Benz 300-Class
1980 mercedes benz 300td wont shut off when the key is taken out of the ignition?
T D Turbo Diesel probably getting to much fuel have to adjust fuel regulator
Apr 04, 2010 | Mercedes-Benz 300-Class Cars & Trucks
1984 Mercedes-Benz 300 SD My brother was messing around with our 1984 Mercedes-Benz 300 SD and seemed to blow something. Windows, wipers, sunroof, etc.. all not working any more. We replaced the fuses...
If you are certain that the fuse is okay, next replace the Multi-Purpose Relay/Combination Relay. This relay controls all three of those devices and is most likely your culprit. I would try the junkyard first and grab two just to be on the safeside. You'll find it under the fuse box cover on the driver's side engine bay.
Dec 08, 2009 | 1984 Mercedes-Benz Mercedes Benz 300 Class
1979 Mercedes Benz 300D- Turn signals, windows, radio...quit
Barrel fuses used to be made of aluminum and corrode on the copper contacts. Pull fuses and replace. 10-15 dollars now will help get rid of electrical gremlins.
Jul 28, 2009 | 1984 Mercedes-Benz Mercedes Benz 300 Class
Mercedes 1995 C180 radio needs code
as i know of code normally be posted somewhere on top or behind stereo when you pull the whole stereo out,
Jun 18, 2009 | 1997 Mercedes-Benz C-Class
Feb 20, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt Nassau CR127 Cassette Player Logo
53 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
