Message OE Stop in washingprogram, message OE, does not pump water out.
    President:
  • 373 Answers
OE : Drain Hose is Kinked or clogged or The Drain Filter is clogged - Clean and straighten the drain hose / clean the drain filter.
also do check for the pump blockage.
for more info on this check the following link
http://pastoralfarms.us/2008/04/21/lg-fl-washer-2277-oe-error/
Posted on Dec 23, 2008
LG washer WM2501HWA quit mid cycle and had an OE error message. The drain filter was checked and was clear. I drained out all the water through the drain hose. For a time, the drum would not spin. When...
i believe if the water outlet is still good,,,,,u will have to loose out the pump from its cup , mayce something hooked its propeller inside the i cup or replace the water pump
Jan 25, 2015 | LG Washing Machines
What do we do after replacing the pump on an LG frontload washing machin, yet still get error message OE?
Assuming you cleaned the pump strainer?
Likely the drain hose leading from the pump to the drain, the section
inside the cabinet that "u-turns" back down is plugged up with
junk.. I had to remove the hose from the machine and force water
thru it at a outside faucet to clear what looked like a turd from the
inside of the drain hose..My shop vac could not dislodge it..
Aug 16, 2014 | LG Washing Machines
What do we when we replaced the pump on a frontload washer, LG, but still get an error message OE?
The DE Code indicates a Drain Error. This means that the washer thinks the water has not drained out of the tub within 10 minutes, which is an eternity for the washer. Since you have indicated that there is no obstruction in the hoses, and filter, and you have replaced the pump, then the only other parts that could be at fault would be the water level sensor, or the main circuit board. Replace in that order.
What is an "OE" error message on an LG Tromm clothes washer?
OE means Water may not drain properly
This causes:
Your pump is clogged.
Your pump is not connected.
Make sure your pump is repaired, and try again.
Jul 28, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a problem with my LG Tromm front load washer. It will wash seemingly normally up to the point it gets to the spin cycle. Then a motor comes on and the machine does not spin or drain. The display...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Sep 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washer won't drain! The OE message was on, I
have you cleaned out the water pump and hose ? check drain hose for blockage, check pump wiring to make sure it has a good connection.120 volts to pump. pump or board bad.
Feb 01, 2010 | LG WM-2277HW Front Load Washer
Oe message...filter is clean. water won't drain out. tub is ful
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Dec 21, 2009 | LG WM-2277HW Front Load Washer
Machine won't spin and rinse and stops with an "OE" message.
it could be as simple as a wire has come off the pump during transport or the pump was about to die.
check if wires have come off pump and if ok then with a little water in the machine see if you can blow some air back down the drain hose to see if there is a blockage in the hose or the pump if there is you will have to remove the hoses from the pump and clear the obstructions
Jun 11, 2009 | LG WM2688HWM TROMM SteamWasher
Error Message/OE
sounds like too much water is coming into machine.check water valve,and water sensor.it is bringing in too much water or not enough.
Mar 06, 2009 | LG WM1814CW Front Load Washer
Washing Machines Logo
990 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
