Question about GE JEM25 Microwave Oven
Microwave Oven Problem
Sporadically our built in microwave oven "turns on" when the door is opened. In other words, upon opening the door, the light turns on, the fan starts, the turntable rotates and for all I know radiation is streaming into the oven and out the open door. After shutting and re-shutting the door a number of times, the situation returns to normal with the fan/turntable etc. not activating until the user presses "start" which is as it should be. What's going on here, and is it possible the oven is actively heating if the door is open? Seems like a major safety problem so appreciate qualified input.
  • Anonymous Apr 25, 2008
    I have the same problem with a model JE1540WV. Can the door switch be installed by a competent repairman?
  • GE Master
  • 9,128 Answers
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. It's probably not actually heating with the door open, but better safe than sorry! If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Posted on Apr 10, 2007
How do I turn on the microwave and set the clock
well setting the clock comes first if my memory is right
Jan 14, 2016 | Microwave Ovens
Advent rv microwave shows no power
Advent camper microwave shows no power but when you open the door the light comes on and turn table turns but on power on the screen shows nothing
May 19, 2014 | Advent MW912BK Black Built-in Microwave...
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
My new panasonic microwave model NN ST 340w has the internal light on when I heat up food. However when I open the door to put food in or take it out, the internal light does not turn on. What can I do?...
Your oven light is busted or damaged. You can buy the replace at the any electronic shop. Just open the top cover then you will see the light you will going to replace
Aug 15, 2011 | Panasonic NN-H664 Microwave Oven
The turntable runs when the door is shut and the oven is not turned on. When the door is open the turntalbe stops and the light comes on. the heating part of the oven is fine.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 09, 2010 | Goldstar MV-1501 Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Nothing is hot - everything is on
Check the door safefy interlock switches before you plunk your $ down.
If you open your oven to check the contents without turning the oven off first ... the tiny switches arc and start to burn ... once they cannot make contact ... the oven doesn't know if the door is open or closed so it will not turn on the heat.
It is worth checking ...
Jun 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
NEFF 7871 electrical problems
neff built in microwave cannot open the door
Mar 02, 2008 | Neff H7871 Convection/Microwave Oven
GE JEM25 Microwave Oven Logo
316 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
