Question about AEG Dishwashers
Outlet pump running continuously and not responding 665 favorate
The boolet says that it is the pipe is leaking can not see a leak the solonoid switch has kiked in how do i replace it
I tried to move the machine arround, lean it forward back ward or side to side it stops working and starts again, it feels like a water levels sensor or some thing
Posted on Dec 27, 2008
Adjusting the pressure control
you may find the check valve on the pump may be leaking or there is a leak in the line. This all depends on what kind of system you have. Best test is to isolate outlet somewhere close to pump & see if pump stops. ( this is of course if you have a pressure switch control ), if so you may find your check valve on pump is leaking or you may fine there is a small leak in the line some where.
Nov 08, 2013 | Grundfos Plumbing
Whilst wash on, water leaks from the underneath of washing machine. but cant see where it is coming from
if the water is leaking during the fill cycle when the detergent is being added from the drawer
ensure the draw is clear, if too much deturget rests has blocked the vent then water maybe running out on the inside.
if the problem is happening during the wash cycle this indicates a leak on your drum, ensure your door seal is intact and not leaking.
if the problem is during pumping, ensure that the pump is not causing a problem
maybe open the bottom vent and ensure the cover is seated properly and pump is clear.
also check the outlet pipe is not blocked or leaking and water is running back on the outside of the outlet pipe and under the machine
I hope this was useful.
May 23, 2011 | AEG Washing Machines
We installed a Grundfos MQ3-45B series pump in our house a year ago. It's been great except for a few occasions when it's been turning on frequently when no taps are on. First time it was a leak in the...
These pumps are activated by a flow valve on the incoming pipe. You should fine a small device, with a cable leading from it, attached to the incoming pipe on the pump. This device is a switch that is activated by the movement of a magnet that is held inside the pipe - the magnet is in a captive housing inside the pipe and is moved by the flow of water through the pipe. When a flow is detacted the magnet moves slightly within its housing and that activates the switch that is strapped onto the outside of the pipe.
So, either you are experiencing a flow that is unexpected or unknown (leaking outlet somewhere) or the intenal component of the flow switch is faulty, The latter can happen if some foreign material has got into your system and is causing the magnet not to fully return to the 'off' position.
You can disconnect the pump and remove the flow switch component to inspect and clean it. That process should be fairly intuitive.
If I can be of any further help please respond with a comment.
Feb 10, 2011 | Plumbing
Hi I had a leak in my water line to the ice maker. I replaced the line, now it will not make ice. Water is not going into it.
The fact that it was running fine before you replaced the pipe indicates the problem is with either the connections on either side or possibly the pipe is kinked or the wires from the solonoid pipe have been accidently moved. Firstly Dissconnect each end and see if pipe is clear and round on both sides. if good, blow into one end and see if blowing is possible. Then replace one side of pipe onto solonid side. With the opposite end open activate the valve. Water should come out in about 3 seconds. no water = vave not activating.If you are not farmiliar with mains power i suggest you dont test solonoid by yourself. Get help. Put a lead onto the solonoid and plug into mains. Switch on briefly and see if sol. activates with water exiting on the open side. If so switch off and reconnect pipe onto connecter that old one came off from.Once connected, have someone check inside at the icemaker while you put power on to the valve again.If water comes out, switch off- pull plug out then reinsert solonoid wires back onto the sol. Must work. Very seldom will the valve be a problem. Another thing you could do is to activate the test button function.
Aug 19, 2010 | Refrigerators
The drain pump runs continuously when the Dishlex Global 300 dishwasher is turned on. When pushed, the buttons on the control panel would not change any of the cycles.
This could be that the anti flood device "polystireen float and micro switch at the base has detected water at the bottom due to a leak (pipe or pipe clamp). This device puts the washer in pump out mode and will not continue. Firstly you need to determine what causes the water leak and rectify it before it will continue.
Mar 20, 2010 | Dishwashers
AEG Favorite Compact 525 Dishwasher. The pump runs continuously even when the on/off button is pressed. any ideas
This is caused by the Anti-Flood device at the base of the machiene being activated. This device detects water leaks and is a polystireene float / micro switch that puts the machiene in pump out mode only. You need to determine where the leak comes from (pipe or perforated hose pin hole or pipe clamp etc.) If you tilt the washer and some water comes out from the bottom it is a clear indication that there is a small leak.
Mar 10, 2009 | AEG 24 in. Favorit 40850 Free-standing...
Ikea whirlpool dwf415 will not take in water and green light flashes on and off...help
MINE DID THE SAME IT WAS DUE TO A SPLIT PIPE ON THE OUTLET OF THE PUMP. THIS CAUSED A SMALL PUDDLE UNDER THE MACHINE THAT TRIPPED THE BUILT IN ANTI FLOOD SWITCH SO CUTTING OF THE POWER TO THE WATER SOLENOID. TO FIND THE LEAK BRIDGE THE ANTI FLOOD SWITCH AND RUN THE MACHINE WHILE LOOKING AT ALL THE PIPE WORK UNDERNEATH. IF IT IS THE HOSE ON THE PUMP OUTLET IT IS BONDED TO THE PUMP BUT YOU CAN CUT IT OF AND REPLACE WITH A HOSE AND HOSE CLIPS. DONT FORGET TO RE-CONNECT THE FLOOD SWITH. HOPE THIS HELPS
Aug 09, 2008 | Whirlpool Dishwashers
BOSCH DISHWASHER SGS 6312GB/13 , FD 7810
You have a leak underneath and it is switching the anti flood switch on. Tip the dish washer back at a 45 deg angle, you will probably get water teak out the back, stand it back upright and try it. although it will probably work you will need to look underneath and find where the leak is coming from, my guess is its the wash pump and will cost around 100 pound for an engineer to repair.
Dec 02, 2007 | Dishwashers
Dishwashers Logo
159 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
