I need a little more specifics to help. What exactly happened when it shuts down. Does it restart? you need to check for ignition fire when it shuts off. If no fire check ecu module. If fire and no fuel, pump or pressure regulator is faulty
As when front elevated, possible small leak on fuel pipe, check connections, air getting in fuel runs back to tank, so when starting, has to pull fuel back up before starting
Holden Rodeo 1989 2.6mpi , start and only runs for 2 or so seconds themselves stalls, after putting on a fuel peesure gauge, fuel looked okay and slowly dropping, found the ECM relay was intermittently switching on and off, gave it a tap and the engine kept on running, relay not repairable, replace with new part. Located in the fuse and relay box on the right hand side of engine bay next to battery. Hope this helps.
You could have a number of problems. First do a complete tune up, proper timing, new plugs etc.
Turn the key and do not give it gas. If it starts slowly give it gas and let me know what it does. I suspect it will cut out. In that case, you might have bad injectors. Let me know if I can be of further help
