Question about Panasonic TH-42PX50U 42 in. Plasma HDTV
Can't set the sleep timer
What is the purpose of the 'sleep' button on the remote? It doesn't work, it doesn't set the sleep timer! When I select the 'timer' menu to set the sleep timer, I see 'sleep', 'timer 1', etc... but I can't scroll down to set the sleep timer!@!!
Why did you guys make it so hard to set the sleep timer! You need a simpler, easier solution!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I have the same problem. Does anyone have a fix?
Posted on Jul 29, 2009
I just bought Samsung UHD TV SERIES7 no where manual shows how to set sleep timer
The sleep timer is accessed through the Menu under System > Time. You may need to set the TV time first which is in the same sub-menu area. For the sleep timer using the smart control, press Menu/123. Use the pointer button to steer to Menu then press the Pointer. Repeat this to select System. Select Time. Then select Sleep Timer and choose your time (up to three hours) when you want the TV to turn off. From the regular remote, press Menu. Use the arrow keys and press OK to move through the above menu steps. You can also do this from the Menu button on the Control Stick (joystick type control) on the back of the TV (lower left-hand side).
See page 126 (page 132 of the PDF) of the e-manual for the JU7000 series TVs for additional information or the section on setting the TV time. The e-manual is available online or through the TV. To read this manual, press the e-manual button on the regular remote. If you have the smart control, press Menu/123. Then select the e-manual from the on-screen remote. Alternatively, press Menu and then select Support > e-manual. The quick guide does not have the information on setting the timer. See https://www.samsung.com/uk/support/model/UE40JU7000TXXU/ under the Download Manual section. You may need to expand the list.
I hope this helps.
Jun 15, 2018 | Samsung Televison & Video
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
Problems sony bravia tv
Go into the menu and turn off the timer. The timer can be set to turn off the tv after a predetermined time. Look for sleep timer. May be on remote control.
May 28, 2013 | Televison & Video
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
May 05, 2011 | Televison & Video
How do i set the timer? i use it for my alarm.
Which timer do you want to use? To use the On/Off Timer, press Menu and use the navigation arrows to select Time. Press Enter and navigate (up/down arrows) to select either On Time or Off Time. Press Enter and then use the up/dwon arrows to select Repeat. Select the frequency for the timer function (off, once, everyday etc.) with the left/right arrows. Use both the up/down and left/right arrows to set the time (hour or minute). Press Return to return to the previous menu and Menu to leave the OSD menus. For the On Time, you can also select the input source that will be shown when the TV comes on. (Select Input similarly to the above directions and set the desired channel if the source is TV.) The time must be for this to work (select Time and then Clock then Auto (gets the time from a digital channel) or Manual) and the TV must be in Standby mode for the On Timer to work. The TV will go into standby in two hours after coming on unless a button is pressed on the remote or the TV. The Off timer will override the TV On if they are set for the same time.
The Sleep timer is set in the same Time area or in the Q.menu (from the remote). Select Sleep time and then the length of time you want the tv to stay on before going to sleep. This is reset when the TV goes off.
The Shut-off time is set in the Time menu as well; select Auto Sleep. When this is on (on/off options), the TV will shut off after 10 minutes without a signal.
I hope this helps.
(you will have to reset the timer after a power failure)
Oct 06, 2010 | LG 32LG30 32 in. LCD HDTV
Sleep Timer on remote does not work
First try to access the sleep timer menu from the controls on the TV to verify the TV is working.
If that works then the remote has the problem.
Now try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If this does not work, then you may need a new remote unit.
Mar 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Olevia TV Remote doesnt work Sleep Timer
The TV is in 'showroom mode'. To fix: Click: Menu --> Picture --> Mode --> Power up then select: Home. Then click menu until you exit the settings. You will now be able to use the sleep timer.
Mar 10, 2009 | Bose Cinemate Digital Home Theater System...
Sleep timer
Pres Timer. Make sure the time is set. Then just set the off time. It's not really a sleep button, but it works.
Jan 27, 2008 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Timer on television
The user manual is available here:
Pioneer website - PDP5060HD
Setting of the sleep timer is on page 58, quote:
You can also use the menu to set the Sleep Timer.
1 Press HOME MENU.
2 Select “Sleep Timer”. ( / then ENTER)
3 Select the desired time. ( / then ENTER)
4 Press HOME MENU to exit the menu.
Nov 17, 2007 | Pioneer PDP-5060HD 50 in. Plasma...
Panasonic TH-42PX50U 42 in. Plasma HDTV Logo
1,357 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
