HARD DRIVE PROBLEM.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:''Table Normal''; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:''''; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:''Times New Roman''; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hello everyone,
My problem is this:
Yesterday while I was working on my pc, the computer jammedand i restarted, only to restart with It didn’t load windows but, showed ablank screen with the message
PXE-E61 - Media Test Failure, check cable
PXE-MOF: Exiting Intel Boot Agent.
Naturally I panicked. I restarted but still the same. Pleasenote that I have two hard drives (SATA): One (200 GB Seagate) with the OS (WINXP) and the other for myfiles (500GB Seagate). I did some research on the Internet and assumed thateither the HD are faulty or fried or that this might be a boot problem in thebios (boot sequence). So I checked the bios and would not recognize the harddrives (The order was floppy, DVD, Harddrive, then Network). I played aroundwith the sequence but still nothing. Ithen thought that it might be a cable problem. I switched the SATA cables, Ieven replaced them with new ones. I then proceeded with the power cables.Nothing. I then attempted to check the Hard drives by themselves. I left the OSHDrive and it booted all ok. I then placed the second hardrive and would notrecognize it. I assumed that there might be a problem with the secondHarddrive. I attempted to placed them both again, but again it would notrecognize either. I them checked the second Harddrive on another computer, andagain it would not recognize it, but it would recognize the OS Harddrive of theother computer.
Is there a possibility that the OS of my 1st Harddrivefaulty and it may be causing a problem? If so then why doesn’t the secondhardrive get recognized on the other computer? So I connected my second Hardrive with a Sata USB connection. I heard itspinning! but would recognize the USBbut said UNKNOWN Device. I tried to use HDD Regenerator but would not find thesecond Harddrive.
I thought of using the freezing trick, but I am too afraidto do so, scared of what happens after.
My Work of THREE long years is on that drive and I am verydisappointed and confused.
Any suggestions please?
    Master:
  • 413 Answers
If the first drive will get recognized on another computer but not yours it would lead me to believe that the controller on your motherboard went out. But the part about the non os drive not getting recognized at all leads me to believe that drve went out. First i would definately take the drive somewhere to have the info transferred or if you can hear it spin up you might get lucky and it will work after you get your os to boot. it wouldn't hurt to have it backed up though. Before you do anything too drastic try to get your hands on another drive and see if you can get your PC to recognize any drives, if not then you will need a new motherboard.
Posted on Dec 23, 2008
Hi everyone, I was installing windows xp sp3 on my compaq desktop computer through my hard drive because my computer doesn't recognise cd roms, So I can't install through cd drives. It installed to...
Hi
Have you tried to go into your cmos settings and enable the settings to detect your cd rom
You should be able to use a external cd rom connected through your USB port to load and re-install windows and your drivers if you have the motherboard cd.
The problem is your limited in your options to work from the hard drive but a disk also gives you the option to repair the filing system and replace missing files.
The problem with installing windows on one pc and it not working on another pc is the motherboards are not compatible, and the configuration has to be similar or the same so the hard drive can boot up and communicate between the hardware and software.
Your options are use a CD rom, change your MB or google your problem and hope someone else was able to resolve this issue.
Cheers
Nov 26, 2012 | Computers & Internet
My laptop turns off when charged
Computer restart due to overheating:
Computer restarts due to over-heating when the processor fan goes faulty.Computer restart due to faulty RAM:
Computer restarts abruptly if RAM goes faulty, or if you install some in-compatible RAM or more than one RAM modules of different frequency or type.
Computer restart due to faulty Hard-disk:Faulty hard disk is one of the most common reasons for abrupt computer restart. Run a hard disk scan to fix this issue. If there are bad-sectors on your hard-disk, its the time to get it replaced. Computer restart due to overheating up of hard-disk:
Apr 05, 2012 | Computers & Internet
I plug the hard drive in and the computer doesn't recognize it
Install it another computer which is running well.If your Hdd run well in that computer ,change the USB cable .If the HDD can not run in another pc you think, you have lost data.Because that Hdd cant run any more.
If the problem is same.
follow the step
R_click on my computer>Properties>Hardware>Device manager>uninstall all the usb ,one after one .
After UN install all the usb, restart your PC .
If the problem , is same as before ,
Insert your OS in the cd tray > press Win key + R>type sfc /scannow (please take a space between sfc and front slash)>hit enter .Again you will restart the PC.
If the problem is same please change the Hard disk.
Hope it will help you
Jan 06, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Simpletech Signature 500gb "is not accessible"
Right click on MY COMPUTER and select MANAGE.
Go to DEVICE MANAGER and expand the DISK DRIVES category on the right side window.
You should see the Simpletech drive listed under there. Delete the Simpletech drive and click on OK. Restart the computer.
Windows should re-detect the simpletech and re-install the built in drivers automatically.
Jun 17, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Emachine t3604, computer shut down. then restarted showing hard disc error and it never started again. the only thing that shows when booting is the e symbol with f2 or f10 options for Bios. then it goes...
I'm sorry to say this but your hard drive may be faulty and need a replacement. Your files might still be retrievable but you will need to take it to a repair center to get it retrieved or plug it as an external hard drive and try to retrieve data yourself. But nevertheless, it seems like your hard drive gave in and will need to be replaced with a new one..
Thanks,
Lolita
Mar 05, 2009 | eMachines T3604 PC Desktop
Hello the hard drive of our laptop needs a full reformat so i can reinstall xp but how do i format it without a working opperating system? thank you
 You can do a full reformat right from the windows xp install disk.  Put the xp disk in the cdrom drive and restart the computer.  Upon restarting a message will come up ( Hit any key to boot from CD )  Hit any key,  the files will load then you will be able to format the hard drive and also load windows XP.
    If for some reason your system doesnt boot from the cd, you might have to go into the Bios and change the boot order from the hard drive or the floppy to the cd so the computer will boot from the CD first. Hope this helps...                                                           Joe > Data Miner <
Oct 31, 2008 | Computers & Internet
When I restart my laptop, all i get is a black screen with my cursor...
Are you able to start the computer in safe mode?
Try starting the computer into safe mode by following the instructions found here.
If the computer loads in safe mode, then you can try disabling some startup programs by reading the instructions found here and restarting your computer. If this fails to fix it, you'll probably need to reinstall windows.
Steven
Sep 17, 2008 | Sony VAIO VGN-N130G/W Notebook
Hard Drive
its nothing some unwanted member or unknown member used that combuter.and delete some files ithing no broblem.1st restart and shutown.
used tuneup software clear registry.
Jun 07, 2008 | Computers & Internet
Notebook won't start
press the key F1 or F2 or F10 or DELETE when you try to restart your computer before 5 seconds that will open the BIOS page so go to boot order and change it instead of start with cd flopy hard drive put the hard drive first save it and restart the computer it have to work good un less there is a problem with your hard drive or windows software if that is the case restart the computer and press F8 before 5 seconds and you'll see black page with the next options last know good config and save mode click on last an then restart the computer if does not work try save mode of you can acces tue hard drive that means bad windows software if not bad hard drive
Jan 02, 2008 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
