Question about Olympus FE-340 Digital Camera
My olympus FE-340 does not start in shooting mode
It only shows shooting mode when i press the shutter
    President:
  • 919 Answers
That is how the camera is supposed to function. When the shutter button is depressed it automatically assumes you want the camera to be in shooting mode to take images.
Posted on Dec 29, 2008
Camera picture distorted Olympus fe -340 8.0 5xzoom
Could it be you changed something in the settings?
Can you see the scene in a normal way before shooting? then it look to me the sensor an the camera have to be good.
It is to much to tell you how, because you have to look that up in the manual, but, please try to set the camera in auto mode, because is you did set to in the scene mode, and than chose blurry background, or shooting through glass that could cause the distortion.
I put the link for the manual down here, in case you can't find yours.
Start at page 6 to see how to shoot in automatic.
Be aware if you shoot ready shot (anti shake) on a tripodthe pictures will be blurred to.
http://www.olympusamerica.com/files/oima_cckb/FE-320_X-835_C-540_FE-340_X-855_C-560_Instruction_Manual_EN.pdf
Dec 12, 2014 | Olympus FE Cameras
Why does the screen stay black when camera is turned on?
Did you try to press the display button several times? Most of the time you can cycle through different views on the display, with different information during record mode. One is display off.
Jun 18, 2014 | Olympus FE-340 Digital Camera
My olympus camera fe-340 showing black screen when i snap a picture its also showing black all my picture before we erase need help
If your menus work and you have no picture in recording mode, either movie or single, then your possible problem is that the CCD sensor has a problem.
See if it is still coverd by the manufacture, if not sell it for parts on Ebay or some such website.
Oct 31, 2011 | Olympus FE-340 Digital Camera
When shoot, in display ' locked "
remove the memory card & check that. Make sure the memory card should be in unlocked mode. Then try & let me know.
Feb 13, 2011 | Olympus FE-340 Digital Camera
Problem for Olympus FE-4000 Digital Camer: My camera lens was not moving in, what shall i do.
http://www.olympusamerica.com/cpg_section/cpg_archived_product_details.asp?fl=&id=1354
The above is for the fe-340.
http://www.olympusamerica.com/cpg_section/product.asp?product=1466
The above is for the fe-4000.
I don't know which one you have.
How do I change the shooting functions back to default settings?
You can reset the current settings to the camera's default settings by using the RESET function. RESET is available from the camera menu when the shooting mode is set to iAUTO, P, SCN (Scene), Digital Image Stabilization or Movie. Simply press the [MENU] button, press the Left Arrow to select the reset icon (a green arrow bent backward on itself), and then press the [OK] button.
The following table shows the functions that can be reset as well as their default values.
FUNCTION DEFAULT Flash AUTO Exposure Compensation 0.0 Macro OFF Self-timer OFF Image Size (Still images) / Compression 12 M / Normal Image Size (Movies) / Frame Rate QVGA / 15 fps SCN Portrait WB (White Balance) AUTO ISO AUTO _soundrec.bmp (Still picture REC) OFF _soundrec.bmp (Movie REC) ON AF Mode SPOT
but_up.gif What type of memory cards does this model support?
Olympus recommends Olympus-branded xD-Picture Card media for use with this model. In addition, certain microSD and microSDHC cards may be used when inserted into the MASD-1 memory card adapter bundled with this camera.
For detailed information about the proper use of the MASD-1, please review the MASD-1 FAQ. For information on caveats and restrictions to the use of microSD and microSD media with this camera, please review this file.
Aug 03, 2010 | Olympus FE-340 Digital Camera
Does the FE-340 camera have a time delay feature so that we can take our own picture?
Please look for clock sign on buttons to turn on-off timer function.
Press clock symbol button to turn on timer function, press shutter button to start timer (10 seconds delay) to take picture.
Mar 14, 2010 | Olympus FE-340 Digital Camera
Blurry images on camera
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Also try to reset the camera back to factory settings as there may be a setting that is causing this issue to occur. To reset the camera - go to Menu - left arrow to reset - highlight Yes and press ok. This will reset the camera back to factory default settings. See if the blurriness still occurs. If it is still blurry you may want to send to Olympus for evaluation and repair service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Apr 22, 2009 | Olympus FE-340 Digital Camera
Wide angle mode switch stuck??
repair... olympus will charge about $60
Oct 02, 2008 | Olympus FE-100 Digital Camera
How do you set up sequential shooting on an Olympus E500
Single-frame shooting o Shoots 1 frame at a time when the shutter button is
pressed. (normal shooting mode)
Sequential shooting j Shoots 4 frames or more at 2.5 frames/sec. (in SHQ,
HQ or SQ) for as long as the shutter button pressed.
Focus and exposure are locked at the first frame.
1 Press the </Y/j (Remote control/
Self-timer/Drive) button.
2 Use the control dial to set.
o Single-frame shooting
j Sequential shooting
3 Press the shutter button all the way to
take the picture.
Press the shutter button fully and keep it
pressed. The camera will take pictures in
sequence until you release the button.
Notes
Sequential shooting is not possible when [NOISE REDUCTION] (g P. 95) is set
to [ON].
During sequential shooting, if the battery check blinks due to low battery, the
camera stops shooting and starts saving the pictures you have taken on the card.
The camera may not save all of the pictures depending on how much battery power
remains.
The above comes from page 62 of your user manual.
Aug 23, 2008 | Olympus Cameras
Olympus FE-340 Digital Camera Logo
113 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
