Question about NetGear WGT624 Wireless Router
Connecting both ethernet and wireless
I have set up a NetGear WGT624 wireless with no problem, however when I try to wire in my desk top via ethernet cable I am unable to connect. Can you use the router for wired and wireless simultaneously
    Problem Solver:
  • 6 Answers
Yes, you should be able to do that. Check to see if your Network Card is set for DHCP and not a static IP. Click on Network Connection in the control panel and then right click and go to properties on your Local Area Connection. Then click on TCP/IP and then Properties.
Make sure both are set to obtain an IP address and DNS automatically. Also try all Lan Ports and a different network cable just in case.
Posted on Jan 03, 2009
Dont know how to install a password so other wireless computers cant log on I have a netgear WGT624
Hi dude check this would be useful
http://kbserver.netgear.com/pdf/wgt624v3_ref_manual_25Apr05.pdf
Things You'll Need:
  • Ethernet cable
  • Cable or DSL modem
  • WGT624 Installation CD
  1. 1 Plug the Netgear WGT624's AC adapter into a wall outlet. Plug an Ethernet cable into the yellow Ethernet port on the back of the Netgear router. Attach the other end of the cable to the Ethernet port on the back of your modem.
  2. 2 Insert the installation CD that was included with the Netgear WGT624 into your computer's disc drive. Click the language option you want to use and then click "Setup."
  3. 3 Follow the setup wizard's onscreen instructions and then click "Finish." The wizard will automatically detect your Internet settings. Open a web browser and navigate to "http://192.168.1.1."
  4. 4 Type "admin" in the Netgear's "User Name" text box and then enter "Password" in the text box labeled "Password." Click "OK."
  5. 5 Click "Yes" and wait for the latest firmware upgrade to install. Double-click the upgrade file and follow the onscreen instructions to install the upgrade.
  6. 6 Click the "Wireless Settings" link if you want to password protect your wireless network. Click the "WEP" radio button and then type in the password you want to use for your network in the "Passphrase" text box.
  7. 7 Click "Apply" and then close the web browser.
Sep 27, 2010 | NetGear WGT624 Wireless Router
Netgear wgt624 does not recognize my ethernet wired connection to the internet. It tell me the cable connection is missing. What goes?
1. check your cable. It should be a "straight through cable".
2. Unplug the router for 1 minute and then power it again.
3. Call your ISP to check the status of the connection (verify).
4. check the manufacturer for firmware updates for your model router.
May 19, 2010 | NetGear WGT624 Wireless Router
So I have a little problem. I'm trying to find out how to connect 2 wireless routers together from across the house. The internet side is connected to a Linksys wireless router (WRT54G). This is located in...
you need a wireless ethernet bridge(like wet54g/wet610n) which will grab signals wirelessly from u're primary router wrt54g,& then a ethernet cable from wireless bridge will be connected to one of the lan port of u'rs netgear router(otherwise u will not be able to do file & printer sharing between 2 routers)Remember,the ip address of all 3 devices shold be of same class.
Jan 02, 2010 | NetGear WGT624 Wireless Router
Netgear WGT624 router won't connect to the internet
I am in the UK and have found through experience the Netgear's seem to work perfect on a BT line (equivalent of AT & T)
but not on the cable.
I would suggest purchasing a Linksys by Cisco WRT54GL Wireless-G Broadband Router as these seem to install in minutes,
saves me hours of wasted time when setting up wireless networks.
Jan 18, 2009 | NetGear WGT624 Wireless Router
No connection when installing WGT624 Netgear router
Plug an ethernet cable into the wan port of the router from your virgin modem... then plug ethernet cable from computer into a port on the router....that should solve your problem.
Jan 09, 2009 | NetGear WGT624 Wireless Router
Setting Up the Netgear WGT624 as a bridge
Just disable the DHCP function of the Netgear router. Connect them from LAN port of 2wire to LAN port of Netgear.
Nov 25, 2008 | NetGear WGT624 Wireless Router
Netgear 624
to set upa network
http://lifehacker.com/software/wifi/geek-to-live-set-up-a-home-wireless-network-162754.php
there is no "earthnet" connection. it is an ethernet connection. it looks like a phone cable but has larger ends than a phone connector. the router is connected to the computer via an ethernet cable if it needs to be hardwired to a ethernet port or internal ethernet card. a wireless connection only needs to be an add-on internal card w/antenna or a usb connector hub (it looks like a usb flash memory stick)
here is how it's done. netgear has the same type setup.
Oct 13, 2008 | NetGear WGT624 Wireless Router
Netgear 108 Mbps Router WGT624 v3
As you say that, you are able to go online with the modem, connect your modem- router and laptop witha cable and check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be checked..open your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
Nov 27, 2007 | NetGear WGT624 Wireless Router
NetGear WGT624 Wireless Router Logo
55 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
