Question about Toshiba Satellite M45-S265 Notebook
How do download ConfigFree Launcher
How do i download the ConfigFree Launcher
i need instructions for this
  • Anonymous Jan 21, 2009
    ya me to my cusin has it and i want it
Launcher is missing
Launcher is Missing is it a luncher app you downloaded from the playstore or is it the default launcher of your phone because if its just an app that you downloaded from the playstore its missing because a factory reset will erase all your data and apps
If its the dufault launcher is your phone rooted?
Did you perhaps uninstall the default launcher using a root tool like link to SD?
If you have uninstalled your default launcher then you would have to flash a stock rom from your phone's manufacturer or download a custom rom from the internet
Sep 03, 2015 | Nextbook Premium 8 Se Android
Please help me get rid of touchwiz
Pretty straight forward, you will just need to replace the touhwiz launcher, first download and install a different launcher, I use Apex Prime and it works perfectly but you could also use Google launcher or any other you want.
Setup is pretty basic just open the app and it should prompt you to set the launcher as your default launcher from there you can go to the launcher settings and change pretty much anything you want. I suggest setting animation and scroll speed to faster than default as it makes the phone feel more responsive. Good luck.
Aug 05, 2015 | Cell Phones
How do I remove google chrome app launcher?
its a glitch in Google Chromes latest update. just uninstall Chrome remove all its registry keys and left over folders. restart your computer.
then use Internet Explorer only then go to https://chrome.google.com click the download and follow the instructions. The app launcher will not install onto your desktop, but will open to the app launcher page when you open Chrome.
that too can be removed also bu going into settings "Open a specific page or set of pages. Set Pages" click on set pages and add new page to about:blank or to whatever page you want Chrome to open to. then click save. and that is it no more app page.
once i did this Chrome opens a lot faster.
Jul 07, 2014 | Google Chrome extensions Computers &...
Camera launcher.exe does not work anymore
you probably need to uninstall
and re-install the canon program
and ,if you want to fix launcher.exe,There are 3 step to repair launcher.exe stopped working error
If you got launcher.exe stopped working error then there is a 94% chance that your computer has registry problems. To repair launcher.exe stopped working error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair launcher.exe stopped working error.
Nov 20, 2011 | Canon Digital Rebel XT / EOS 350D Body...
How do I fix my virginmobile lg optimusv, it reads The application launcher (process com, android. launcher) has stopped unexpectedly. Please try again.
Hello there,
It looks like your launcher is giving you some trouble. You can download another launcher application (that looks better too) that might fix the problem. Try this great free launcher! https://market.android.com/details?id=org.adw.launcher
I hope this helps. Thumbs up always welcome :)
May 03, 2011 | LG Computers & Internet
I want to set a theme for my lg optimus and I dont know how to can you please help me
The easiest way to change the theme or look of the LG Optimus (or any Android phone for that matter) is to download a new launcher. The Launcher is like the desktop for Android, where you can place widgets and app icons. There are different Launcher's available to download from the Android Market, and some of them can be themed and dramatically change the look of your phone. There are multiple good ones that can be themed. Just go to the Android Market, search for ADW, OpenHome, GO Launcher EX, just to name a few that can be themed.
Once you install the new Launcher, when you hit "home" it will bring up options to choose which Launcher you want to use. Don't select "use as default" until you're sure you want to settle with one of them. (*if you do select use as default, and then want to change again, see the note at the end of this)
If you go back to the Android market, and search for ADW themes, OpenHome themes, etc., you should see quite a long list of various themes for each launcher. Install one you want to try, then hit home. You'll need to apply the theme in the Launcher's settings, which is normally accessed by (from the home screen) hitting the menu button, and then "preferences" or "adw settings" (if you're using ADW). From there, depending on the Launcher you're using, find the section that has to do with "Themes" or "UI". From there, you should be able to select and apply the theme you just downloaded and installed. It can't hurt to download a few if you want to test a few.
Changing Launchers is a great way to change the look and feel of you're phone, as a lot of them run much smoother than the Launcher that comes default on the phone.
*If you set a Launcher as default, but want to change it... the easiest option is to download "Home Switcher for Froyo" from the Android Market, and use that to change between Launchers. The longer was is to go into Settings -> Applications -> Manage Applications, find the Launcher you're using, click on it, and select "clear defaults". Then when you hit the "home" button, it should bring up your options again.
Mar 05, 2011 | LG Cell Phones
How to install themes to samsung galaxy 551 phone
you can download
1.GO launcher
2.ADW launcher
3.Launcher Pro
4.Regina 3D launcher
5.Panda Launcher
6.Honeycomb Launcher
7.Home Launcher
from Market and install it
and within any launcher you will get many theme
and also you can customise them
Try it
Feb 19, 2011 | Computers & Internet
Microsoft Works Task Launcher Operators Manual. I need to import templates from my hard drive into the Task Launcher.
Go to start
Programs
Select Microsoft Works Task Launcher
Click on calendar
If you already have a calendar it will automatically open for your, if not you will need to enter the info at the prompts. Just right click on new appointment and enter the info here.
To import directly from your hard drive, you will need to download an additional program and can do so here. There are a few to choose from, all having trial versions to see which one best fits your needs. http://www.brothersoft.com/downloads/microsoft-works-task-launcher.html Try this out and let me know if you need further assistance. Hope this was helpful! Lori
Oct 24, 2010 | Computers & Internet
Game needs update, but the launcher doesn't work...?
download the patch straight off the ea website or of filefront.com
Jun 29, 2010 | Acclaim The Sims 3 World Adventures for...
Bluetooth
if the bluetooth is not available in the configfree menu check to see if you have the driver installed for it , you can download the driver from Toshiba's website.
Bluetooth is an option on most of Toshiba laptops, check if your laptop has the module installed, and if you need to press a button or a function key combination to activate bluetooth.
Sep 02, 2008 | Computers & Internet
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
897 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
