you can down load the drive from internet and install to check whether the driver is installed or not right click my computer click properties then hardware then device manager if any sign in th drive means that driver is not installed properly you will have reinstall the correct driver as per the OS version
Since you have formatted C drive, all your previous drivers must be erased and you need to get a fresh install again. All drivers are installed in C drive, so you must install your sound drivers again. It will surely solve your problem.
GOOD LUCK
It looks like the error in ur registry because of invalid registry errors so make ur registry error fix by using reginout and then install ur recommended driver as u want to install sound driver by writing ur brand name with model name
Usually if you have installed an new hard drive, you need to install also your laptop driver. After you've successfully installed the driver you need to restart the unit to take effect.
if you installed a new hard drive.. did you also installed windows on that new hd? if you did.. you may need to also install the sound card drivers.
the sound from your speakers depend on the sound card on your computer, and the sound card works only if you install the drivers that are specific for that sound card/computer. if you need help finding the drivers post back you computer specs (model, brand etc) and operating system and we'll help you find the drivers that may need to be reinstalled.
If so and even if so, you need to have an audio cable installed connecting the DVD drive to the Sound Card in order to get sound when playing a MUSIC CD or DVD player from that drive. So double check that inside of the PC.
Next, go into the Audio Settings in the Control Panel and make sure sound is not muted.
it it is p4 board then u need to format and reinstal ur os. immediately after insalling os intall sound drivers dont install anything else. after ur sound drives are installed then install other softwares...
same problem
I formatted my hard drive and reinstall windows xp but no sound comes from speakers I tried to install audio drivers from the motherboard CD "foxconn" but PCI driver can not be installed what should i do?
