This is a sign that you have a power wire that is shorted to ground. First check the power wire leading to your fan to see if there is a possible short to ground. Sometimes if the wires are not secure, they can rub up against the spinning fan or melt against the exhaust, and then possibly short against the motor or frame. If the wires appear to be o.k., then check the fan motor to see if it is bad. Try spinning the fan blade manually and if it makes noise or won't spin, replace the motor. Once you isolate the short and repair it, you should be able to install a new fuse with no problem.
SOURCE: radiator fans fuses keep blowing-chevy impala
p0108 map curcuit high input, p0128 coolant temperature below thermstat regulating tempurature, p0341 is camshaft position sensor A-bank 1 ckt range/performance, p0401 is exhaust gas recirculation, insufficiant flow detected, p0420 is catalyst system efficiency below threshold, p1480 is manufacturer control auxilary emission controls, p1481 is same as p1480.
