Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool Ultimate Care II - NO WATER COMING IN
FAUCET OPEN, INLET SCREENS OK but still no water coming in on one hose. The other hose is still working.
  • 179 Answers
Take the hoses off the back of the machine. make sure that water is coming through. if water is coming through the hoses and the screens are clean then you need to replace your inlet valve
Posted on Dec 24, 2008
Water will not come out when starting
check water inlet value. also check that the hose is not blocked at the value where they screw on. there are screens that get blocked clean with old tooth brush
Apr 07, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
On rinse cycle...cannot control water temperature...set it for warm but still feels cold to touch. wash cycle is ok. model is whirlpool gold ultimate care II..top loader.
Is the hot water turned on. Remove hose from washer and check screen in water inlet. If it is clear you may need a new water inlet valve.
Apr 01, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Cold water tricles in . no normal flow does the washer valve need to be replaced
There are debri screens in many styles of washer fill hoses that can block up. And the end that connects to the back of your machine also has a reachable screen filter up inside the water valve inlet that can also block up.
Disconnect the water fill hose at the machine and check screens ... clean or replace if needed.
The screen are usually attached to the hose washer and will pop out manually with a small screwdriver or knife. Then turn the water valve on with the free end of the hose aimed into your washer tub to make sure you have free water flow from the faucet to the water valve. If all screens are clean and clear but still no water pressure going into the washer after reconnecting your hoses then you can suspect the water valve inlet assembly.
Dec 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirpool Ultimate Care II washer - drips
Your water inlet valve is leaking through. Turn off the water. Remove the hoses from the washer. Clean the sediment screens in the water valve and replace the hose.
If that does not solve the leak through problem,the water inlet valve will have to be replaced.
Use the attached video to show how to access the inside of the washer in the event the water valve needs replacing.
http://appliancejunk.com/forums/index.php?topic=5191.0
Nov 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water goes in very slow. Cleaned the intake filter where the hoses connect.IS the valve worn out to where it does not open all the way?
Check if the volume of water supplied to the washer from the water line through the hoses attached to it is good. If yes, the screen inside the water-inlet valve if it is clean. If clean, the water inlet valve is defective and you need to replace it. The water inlet valve is located inside the washer on the upper back portion. It is where the water supply hoses are attached to.
Oct 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The cold water trickles in to fill the tub
sounds like you have checked the water coming out of the cold water so the fill valve requires replacement
Aug 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
No cold water
HI, the main reason for no cold water will eb a faulty inlet water vale assembly but, it is best to rule out any minor issue that m,ay cause this as well. check the following devices and hoses for faults. replace the water valve assembly if the the below inspection points check out ok.
Check points-
1. check the cold water wall faucet. make sure the faucet screen is clear of debris and, the faucet is all the way open.
2. Check the water inlet hose for obstructions and kinks. if the hose is knotted or kinked, straighten if possible or, replace.
3. Check the Selector switch(Water temperature switch on control panel)- This is an uncommon problem area but, its worth testing.
Jul 14, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
73 people viewed this question
Dan Webster
Dan Webster
Sal De
