Question about Panasonic PT-51HX42 51" Rear Projection Television
The red light on front is on but...
The red light on the front of the TV next to the power button is on but when I go to turn the TV on it will not turn on. What could be wrong?
  • jljp_sonlv Aug 25, 2008
    Other than calling a repair to my house or bringing my tv to a repair shop, what can I try doing to fix this problem: I push the power button to turn on the tv but the red light flashes and there is no sound and no picture.
Just happened to me yesterday. Do a cold reboot. Read carefully here: Unplug it from the wall and plug it back in. Voila!
Posted on Jun 02, 2008
  • 203 Answers
The unit sounds like it is in shutdown protect. This can be caused by many issues so it'd be best to take it to a service center for a look.
Posted on Jun 08, 2007
Replaced lamp on mitsubishi wd62527 worked for 10 minutes then shut down. Now red lamp light is on
If the red indicator light on the front of your HDTV is glowing a solid red, you should first unplug the AC cord from the wall power outlet and wait for 60 seconds before reapplying power to the HDTV.
After you turn the TV on, if it doesn't power up, try holding the power button down for at least 8 seconds. That's supposed to force a system reset. If your model has a system reset button, use that instead. Press the reset button for about 20 seconds...release it and press it again for 20 seconds, release it again and the led will blink just for a minute or two. You should now be able to turn the TV on.
If after several attempts, the HDTV has not fully powered on and the LED on the front of the HDTV is still glowing solid red, you may want to reseat the lamp.
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp.
Apr 05, 2015 | Mitsubishi Televison & Video
TV WILL NOT TURN ON AND RED STATIS LIGHT IS ON NO CODES ARE SHOWN. WHAT DO I DO?
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp. Keep in mind that some off-brand lamps may only last a few weeks, so replacing a relatively new off-brand lamp may unfortunately be necessary.
Apr 04, 2015 | Mitsubishi Televison & Video
My coby lcd tv won't work for my ps3 what wires would I need to make it work
You will need an HDMI cable. Please follow the below instructions.
Instructions
  1. Before you begin installation:
    • Turn OFF the PS3TM system using the [MAIN POWER] switch (in the back)
    • Unplug the AC power cord from the electrical outlet
    • Turn OFF and unplug the TV
  2. Connect one end of the HDMI cable into the [HDMI OUT] port on the back of the PS3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor. ps3_8_hdmiconnecttv.gif
  3. Plug in the AC power cord by connecting one end of the AC power cord into the [AC IN] port on the back of the PS3 system and the other end into an electrical outlet. ps3_11_connectacpower.gif
  4. Press the [MAIN POWER] switch on the rear of the system. A red light should appear on the front of the system indicating power is available.
  5. Turn on the PS3 by pressing the touch-sensitive [On/Off button] on the system front. The red light will turn green, indicating the PS3 is now turned on.
    Note: The blue light will also appear on the front of the system if you have a disc inserted.
  6. Plug in the TV and turn the power on. The PS3 should detect the HDMI display device automatically. When prompted, "Do you want to output video and audio using HDMI?", select YES and press the icn_btnx_color.gifbutton. (You may need to press the PS button on the center of the SIXAXISTM controller to enable the controller first).
  7. The next screen will ask, "Do you want to automatically switch to the optimal setting?" Select YES and press the icn_btnx_color.gifbutton.
  8. On the next screen, the PS3 will display the maximum resolution capable on the display (i.e., 1080p). The screen will display, "Do you accept the setting?" You will have 30 seconds to confirm your answer.2 Select YES and press the icn_btnx_color.gifbutton to save your settings. You have now completed the HDMI installation.
Dec 01, 2014 | Televison & Video
Sony bravia tv not working
Hi Elaine!
Please follow the steps mentioned below to troubleshoot the issue:
If the TV standby light is blinking for five times then you may perform the steps given below:
(i) Turn off the TV then disconnect all the cables from the TV.
(ii) Next, reconnect all the cables after two minutes.
(iii) Please make sure that the power cable from the TV is directly connected to a functional wall outlet.
(iv) Next, you may try resetting the TV to the original factory settings.
Please follow the steps that are mentioned below to reset the TV to the original factory settings:
(a) Turn ON the TV.
(b) Press and hold the Power button on the Remote Control supplied with the TV, then press the Power button on the TV front panel.
(c) Release the Power button. The TV will turn itself off, then back ON again.
(d) Next, release the Reset button on the Remote control.
If the standby light still blinks then the issue may be with the projection lamp in the TV and requires replacement.
Jul 12, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Have an hitachi 53uwx10ba red light on front is on but no tv
on some TVs, the lights do not turn off so that is not that big of a deal.  If you want to make sure, unplug the TV and then push and hold the power button for about 30 sec.  Then plug the TV back in and that should fix the light if it is stuck. (Pushing the power button wile unplugged will reset the system default!)
Nov 11, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Won't power, light goes green 5-10 seconds later red flashing light is basically what's its doing. at 1st i'd power down the tv for a min and then it comes back up with no red flashing going on.
keep pressing the channel up/down button and the screen will come on it may take a few minutes dont use the switch on the side of tv just use the remote buttons u could try the power button on the remote aswell
Dec 18, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Panasonic PT-51HX42 51" Rear Projection Television Logo
52 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
