Question about Kenmore 62622 Electric Dryer
No heat, timer not advancing
I have a Kenmore 65662, gas dryer. There was no choice for this dryer on here,,,maybe due to age, so I just chose any dryer in order to get on here. Either way, the dryer has been working great and now all of a sudden the timer will not advance and there is no heat. The motor is working fine, the drum spins, etc. Just no heat and timer not moving. Could you please help lead me in the right direction to possibly get this resolved?? Thank you!
  • leir91 Sep 06, 2008
    HI,MY KENMORE DRYER IS MODEL 11072622101.IT HAS NO HEAT AND THE TIMER DOES MOVE IN TIMED CYCLE AND NO OTHER SETTING,WITH NO HEAT IN ANY OF THEM.WHEN I CHECKED THE SEARS PARTS STORE ONLINE FOR HEATER THEMOSTAT ALLS I CAME UP WAS A THERMOSTAT,INTERNAL BIAS AND A THERMOSTAT,205*F?????????????
  • eagles99 Oct 05, 2008
    I have a new Kenmore Electric Dryer that the timer does not advance and seems to be running very hot. This is the 2nd new dryer that the timer doesn't advance. I have replaced the house circuit breaker and wiring. Original house (just bought and moved in) wiring was 12AWG and the breaker was 20amp and I was only getting 120 at the recept. The first dryer blew the fuse and eventually the dryer stopped working and had to be replaced again. I have since installed 10awg and a 30 amp fuse and I am now getting 240 at the recepticle but I am still having the timer issue. I have also verified that the vent is clear. Is it just bad luck?
  • 87 Answers
If the timer advances in timed cycle but not automatic, you have a bad heater thermostat.
Posted on Jun 13, 2007
2 Suggested Answers
  • 641 Answers
SOURCE: No heat,,timer not advancing
Check with a multi-meter for power on THE heating element's tags (115/220V). If it does get power, you should replace the heating element. In case of no power- you should replace the thermostat. Good luck!
Posted on Aug 04, 2007
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
My Kenmore dryer will not heat or turnoff. I have
the timer will not advance without heat.the dryer heats up when it reaches temp. the heat shuts off and the timer advances,when the heat comes back on the timer stops,send the model number next time,
Jul 31, 2010 | Kenmore Dryers
No heat during the dryer cycle
There are several things that can cause a gas dryer to have no heat. I can walk you through how to test the components if you have a bit of mechanical ability and an ohmmeter to test with. I will list the suspects here but to narrow it down we need to do a bit more troubleshooting.
Thermal fuse or thermal cut off - these two components can trip if too much heat builds up due to lack of air flow, usually a restricted vent.
Gas valve coils - these can fail as a result of age
Gas valve ignitor - This can fail as a result of age or vibration
Control/timer contacts - Fails due to age or heavy use
Let me know how deep you want me to go as far as troubleshooting with you on these and I would be happy to assist.
Apr 24, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Motor runs, but timer does not advance, no heat.
if the timer is on auto it won't advance if there is no heat,you'll need a meter to read out parts in dryer,is it gas or electric?try first by checking the thermal fuse on the blower wheel housing,if that's good check the heater if it's electric,if it's gas check the ignitor,sensor gas coilssend model number and if it's gas or electric next time
Nov 28, 2009 | Kenmore 63942 Dryer
Dryer heats timer advances however won't shut off
Timer replacement needed unless you can deal with it.
Jan 20, 2009 | Dryers
Kenmore Heavy Duty 80 Series Gas Dryer won't cycle/won't heat.
if you ran this unit awhile without timer advancing,,now you blew the thermal fuse,,,re place thermal fuse and timer..
Nov 27, 2008 | Kenmore 73952 Gas Dryer
Kenmore Dyer 65662
check the thermal fuse on the blower housing, remove the back panel and you will see a white fuse with blue wires connected to it it is to the left of the vent tube of the dryer if it shows no contunity then the fuse is bad and needs to be replaced
May 07, 2008 | Kenmore 67082 Electric Dryer
Apr 10, 2007 | Kenmore 62622 Electric Dryer
Kenmore 62622 Electric Dryer Logo
373 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
