Question about Refrigerators
I just bought this fridge "used' it is real clean and the freezer works fine but the refriderator part will not get very cool. I set it on the coolest seting and waited two days.???????
  • 700 Answers
If it is a older refrigerator then i would take a look at the damper that the thrermostat in the refrigerator controls. it may be in a bind or the thremostat may be defective. hope this helps
Posted on Dec 23, 2008
Fridge not getting cold
Check the condenser grille on the back is clean and warm to the touch. It should cool down towards the bottom and the drier cooler still. If it's cold, suspect short of refrigerant. If it's hot, move the fridge away from the wall to help it cool down.
Aug 06, 2012 | Refrigerators
I bought a whirlpool fridge freezer last two weeks it was working fine but i noticed that the freezer is making too much ice when i set it at temperature 7 which is melting and i keep seeing water under...
Water under it is fine as long as it is not on the floor. It should be in a pan that came with the unit. You should have 2 temp setting for the unit..1 for the freezer and one for the frid. set the freezer for 5 to start. and then set the frig at 5. and adjust only the fridg side after a few hours. If this does not wrok call the place you bought it from as it may have a bad swthch on the indoor fan or a bad flapper door that allows cold air from the freezer to cool the fridg. But you have to start at mid range and adjust only the fridge side moving it up or down buy 1 number at a tiem.. Let me know know. I hope this helps Jon
Aug 13, 2011 | Whirlpool Heating & Cooling
The top freezer cools like a fridge, the bottom fridge is warm
The fluxating temps bottom to top and top to bottom freezing are a result of the "air damper and baffle assy" not functioning properly. I would attempt fo make my case with LG that this started while the unit was under full warranty and persists today.
Apr 04, 2010 | LG LRTBC1825T Top Freezer Refrigerator
My refriderator freezer not working and the bottom crispers on the fridge side are freezing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How is the freezer doing. If you have a lot of ice collecting in the freezer the door gasket is probably bad causing the compressor to run overtime which will probably cause the refrigerator portion to cool as well.
You might check the freezer and if very cold set it a bit warmer. I do not know what you have but these may save you some $$$. While you are at it check the freezer, refrigerator, condenser and condenser fans.
Good Luck,
Gilshultz
Dec 01, 2009 | Admiral Refrigerators
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
F&P E402B Active Smart Fridge Compartment not cool
You need to start with a clean totally defrosted unit. That means clean, vacuum and wipe as much as you can around the entire motor compressor area especially any coils you can reach. Then set temp around whatever normal is and see what happens. If still the same it's time to have a tech do pressure tests.
Mar 29, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
