Question about Jenn-Air WW30430P Stainless Steel Electric Double Oven
Jenn Aire oven JMC8127DDS beeps twice but won't turn on
Hello FixYa Experts: My Jenn Air oven, model number JMC8127DDS, is not working and I believe the problem is with the control panel which probably needs to be reset. It just beeps twice whenever a button such as Bake or Broil is pressed on the control panel, but the oven does not turn on.
This happened suddenly on Sunday. I baked a batch of cookies, then turned off the oven. About 15 minutes later I attempted to turn it back on and it wouldn't work.
The same thing happened a few months ago. At that time, A&E appliance repair came out. The guy spent about half an hour pressing buttons and finally ended up completing the repair by just resetting the oven; it was an inexpensive repair and no parts were involved. Unfortunately, I didn't write down the key stroke combination he used to reset the over. (I got the impression it was kind of like pressing Control-Alt-Delete on a computer). I can't get A&E out again until next week, but I am having 2 family gatherings THIS week for Christmas. PLEASE HELP!!!
Thanks!
Lori
  • ldieterle Dec 26, 2008
    Thank you so much!!! That was all it took. I turned off the breaker for an hour and now it is working again! I really appreciate the help.
    Happy Holidays to you.
  • 69 Answers
Hello, upon contacting Jenn-Air, they instructed to unplug the oven for 5 minutes to reset it, then plug it back in. steve
Posted on Dec 23, 2008
    President:
  • 2,110 Answers
According to Jenn-Air (Maytag) if you remove the power from the hood for 15 minutes it will reset the board. So depending on how long the power was out the outage would have done this. There is a good possibility that the outage ruined your board.
F7 code flashes on jenn aire 27 inch wall oven
The F7 code indicates that the touch pad either has a "stuck" or shorted key. Depending on the oven model, you either need to replace the touch pad or the controller (clock) and the touch pad. (Some Jenn Air appliances sell the two as one unit.)
Please add a comment with your model number to get additional information on the availability and price for the parts. (Parts may be available from a number of suppliers, including jenn-air.partselect.com.)
I hope this helps.
Mar 01, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
Most of the buttons on the panel do not respond when pressed. incl;uding, convection, setup, rapid preheat
Are the oven doors locked as well, check if the front panel lock is active. Press and hold both the upper oven Cancel and Cook & Hold buttons for 3 seconds (or a bit longer). (Off should disappear from the display and the Lock indicator will flash.)
If that doesn't help, try pressing Cancel. Then try pressng the Cancel and Cook&Hold keypads together. If this doesn't help, then the control panel or the control itself is damaged and probably needs to be replaced. (Touch pads like this have electrical contacts on a membrane that is impossible to fix long term by cleaning the unit.)
For a parts list and prices see: http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Wall-oven-Parts/Model-JJW9130DDS/1266/0125300/M0603043/00001?blt=06&prst=&shdMod= or http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170052&diagram_id=28429593 . Specifically part 1A and 2 are suspect. The control panel is the more likely part to fail (much like a membrane keyboard).
Most Jenn-Air appliance manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US . Fill in Consumer and then the model number and press the right arrow button. The direct link to the manual is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10176680.pdf .
I hope this helps.
Aug 11, 2011 | Jenn-Air JJW9130DDS Electric Single Oven
JennAir F8
Check out www.appliancetimers.com They can rebuild your clock for around $100. A new Jenn-Air is like 2 grand.
May 21, 2010 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air wall oven control panel not working
my jenn air wall oven controls are not working how do i fix it
Nov 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-air sce30600 just replaced membrane offswitch
sounds like more than switch issue probably main circuit board!!!! :) have you tried jenn aire support?
Jul 07, 2009 | Ovens
Some selections on the touch pad on my Jenn-air oven aren't working
Hi, There is a way to replace the keypad. Sometimes you need to replace the clock assembly. I could let you know for sure if I had the Model #
May 08, 2009 | Ovens
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
Control panel error
On most Jenn Airs, this means a key on the keypad is stuck. Try shutting off power, inspecting the keys to see if one looks stuck in or feels worn out. Rapidly press each key several times to loosen and clean the contacts. Turn the power back on and see if the problem goes away.
If this fails to help, you will probably need a new keypad for the unit. I don't know what model Jenn Air you have, but you can find parts for most Jenn Air models at Appliance Parts Pros. This is probably an easy fix, but if you are not comfortable or do not know how to safely work on appliances, you may want to call in a qualified tech.
Jan 09, 2009 | Jenn-Air Ovens
Jenn-Air WW30430P Stainless Steel Electric Double Oven Logo
1,327 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
